Everything posted by Caramanos2000
1995 EJ22 interferance?
What do you guys think, an EJ22 interferance or non interferance?
Lights Are acting weird/speedo issues
Around 80k+ miles on it:)
1st issue in a 1999 Forester, the speedo doesnt work unless you whack the dash over the speedo, then it starts working....? 2nd When I honk the horn, brake etc... my headlights and interior lights dim.... Is this the alternator or voltage regulator?
Bought a 1999 Forester, MMO for oil?
No noise from the 2.5 just like how MMO has worked in my EA82. 10W-40 is ok though right I mean no harm done?
Marvel Mystery Oil, is 10W-40 good for a forester in hot weather?
I have an 87GL and use 10w-40 with MMO in it as far as oil goes. The 1999 2.5L NA forester has 87,000 can I use the same oil and MMO in it?
EA Seria 5spd How much can it take?
Can an EA series 5spd FWD tranny take 200+HP? If not how hard would it be to toss in a legacy FWD 5 spd?
87 GL Wagon PAINTED but Wont turn over :(
Sanded and re did all my connections at the battery, starter and alternator. So far its working good. Any ideas of what it could of been, before doing this my voltage was around 14v on my dash needle and varied depen ding on the vehicle rpm. Now its constant at just above 12v. Before doing this the car would also jerk when turning to the right, now thats also stopped.... coincidence?
Havnt tried it yet, at work.
Thats what I thought too and thats why I used a jump wire between the starter lead and the battery positive terminal but it wouldnt do anything at all. Will try cleaning all my connections and replacing my cable terminals and try again after tapping the starter. Will a starter from an automatic fit my manual car?
Would a bad starter work out of nowere like it did today? I mean will it not do anything one day and then work the next?
Ok guys this is the story: Have an 87 GL Wagon, 1 month old battery in it. Car wont turn over at all, just makes a slight clicking sound. Tried to jump start it and nothing, added a wire between the positive and alternator and nothing. Then i tried jumping the starter from the positive on the battery and nothing. Had to push the car to start it, after its on it runs fine. Even when its off all my lights and elec. works good, it just wont turn over. Someone told me maybe I have bad cable terminals and I should try replacing them, any other ideas? Here is my baby and this is me
Water in my interior
I checked this area, no dirt no nothing not even rust... The windshield is the likely culprit as the rubber seal is starting to buldge outwards.
When it rains I get water showering my feet coming from the pedal area. Its a 87 GL Wagon. You good folks have any ideas?
Mounting Speakers in fron door panel
Mounted some 6.5" speakers into the front doors of my wagon yesterday and they seemed to fit great.Now my windows wont open all the way lol. How do I mount them to the door panel instead of in the door? Is this ok to do ?
HElp with HID kit
I made something like that but slightly smaller and more rounded so I could fir it over the bulb. If I made it to big the light would hit it when I turned the high beams on :-\ Works now though, cant someone turn the sun off for a seocnd?
HElp with HID kit
Not a problem already have them up and running. I bought a Bi-Xenon kit off ebay it was $80 shipped priority (not from china). I will post pics tonight of the results
HElp with HID kit
I bought a 9004 HID kit, can I just use the connector it comes with or do I have to solder the wires because the 87 GL is wired different?
Which LED is more appropriate for the cluster?
Can I mount a hatch lift from an 84 wagon to a 87 wagon? Which one will fit and work best? I really have no idea.... http://cgi.ebay.com/ebaymotors/Pair-Super-Bright-4-LED-Bulb-Replacement-Red-168-T10_W0QQcmdZViewItemQQhashZitem35a4806cedQQitemZ230393146605QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories http://cgi.ebay.com/ebaymotors/2pcs-Red-194-168-T10-wedge-side-LED-lights-Bulbs_W0QQcmdZViewItemQQhashZitem35a42ea885QQitemZ230387787909QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories http://cgi.ebay.com/ebaymotors/2-X-car-Red-SMD-high-power-LED-Bulbs-1w-194-168-T10_W0QQcmdZViewItemQQhashZitem35a42f95d4QQitemZ230387848660QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
205/60 R13 Safe?
Can I mount and use 205/60 R13 tires safely on my stock wheels? Can I corner hard on them safely? Or Should I just stick to a decent pair of 175/70s?
Good find/good trade? 84 Coupe
What if I offered him the parts plus $100 for both cars?
I cant find any 5spd donor cars I also went to see a EA82T GL-10 with 39k on it. Engine ran GREAT but everything else was shot.
I spotted an 84 GL Coupe and stopped to ask about it. It has some rust on the botton panels. Engine is EA81 and looks clean and original, new brake pump, interior is PERFECT. Has 141k on the odo, automatic trans, car has no brakes, it leaks fluid badly from one caliper. We made an agreement I would give him a 3at, starter motor and an alternator for an EA82 and I could have the car. Should I go for it?
new cv axle compare to junkyard axle
I got crappy autozone axles for $60 each with a lifetime warranty:banana:
Single Range 5spd Slop
Can someone point me in the correct direction, my 5spd single range has lots of slop all around. The guides I found seemed to be for the 4spd, should I just go with those?
