coldfusion21
Everything posted by coldfusion21
I have had all kinds of problems regarding the window switches on my 90 Legacy. Seems the design wasn't the best and over time they stop working. Drivers side has been inop for some time (ever after repeated cleanings) and the passengers side is starting to go. My plan: I want to replace all of the window switches with my own DPDT switches. They will be of a return to center design with a simple cross over design to flip the polarity. Now, would it be worth my time to relay all the switches? Seems like all the window motor current goes through the switch and that may lead to increased switch failure down the road. Also, where would you mount the new switches? I was thinking on the dash around the radio area, and i want them low enough so the cup holder doesnt interfere to much. Is there a blank panel available for the lower dash cubby? Ideally i would just replace the ash tray. Just holds lots of coins and i actually use the cubby. Any thoughts or suggestions would be great. Jared
Just because some people don't know (or care) how much sealant to use doesn't means it a bad idea for the rest of us. I always use a super thin layer on any seal i replace. Not to mention you would have to be stupid to get it *behind* the seal as the act of installation pretty much removes any excess. good luck with your seal.
4EAT Diff Lock Switch
coldfusion21 replied to eulogious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am a volvo guy at heart and i followed one guys project where he did this to an all electronic volvo transmission, used a stamp microprocessor and now has a paddle shifted turbo volvo. I did some thinking and the FWD isn't worth it, I agree. I can always leave my switch alone and put in the FWD fuse if i really need it. I will look through the rs25.com stuff, but to test what they say i could check it as described with the FWD fuse correct? -
please do report back. I am planning on doing this soon in my 90 legacy. Trying to figure out how I am going to get the wiring diagrams though. Can i pull the TCU plug and check for continuity from the FWD fuse to the connector and locate the correct wire? I plan on doing a separate switch for FWD/AWD too. That way i can switch to manual mode (just like everyone else is doing with the resistor packs) and then either provide 12v (like the FWD fuse does) or nothing at all (like everyone else is doing) -
I am curious as to how the 4wd/awd system works on my legacy. I know there is the ability to force the system to be 100% fwd, but can i force it into 4wd or RWD? I mostly just want a system that i can tell to hold in 4wd because as it is now there is lag time between when the front wheels spin and power is transferred to the rear. If even possible. Thanks guys Edit: just found a thread that answered my question. So if i put it in 1 or possibly 2 i will have a 50/50 split, which is the best i can hope for? In 1 (possibly 2) does it lock the split at 50/50?
Got under and checked everything out. Rear discs, with some nasty pads. It is the L model, with the steel wheels. I figured nothing else would fit under those, but it looks like craigslist has lots of options for picking up some newer 16 inch alloys. Not to mention I may have found all four brakes off a '01 Legacy for under 100. When buying discs for this setup do I just ask for the 01 discs? Thanks for your help, hopefully by next rally cross season i will have a nice little setup.
Cant wait for next season. I only raced twice this year but both times were the most fun i have ever had. I'm really glad all the people at ORG continue to donate their time to make this a reality for us all. Thanks guys (and gals)
Well, any volvo made after 78 or so had awesome brakes, 4 piston front, single rear with decent sized vented front rotors (the vented ones were only on the turbo's). That's where I'm coming from, but my current other car is a 93 BMW 325is and it also stops on a dime compared to the Subaru. I will flush them, i agree that can really do wonders. What kind of brake pads do you suggest? There was a PBR ceramic pad I loved on the Volvo's, wonder if something equivalent can be had for my Subaru? Same goes for rotors, does any particular brand stand out? Tires are a non issue. They suck, but I come no where close to locking them up. My overall goal would be bang for my buck. I dont need STI brakes and don't want to have to pay for wheels to fit them either. But i'm hoping I can find some plain jane WRX brakes for cheap off a wrecked car. Plus some newer stock wheels and i should be good to go.
All is well!! Started on first crank. The HLA's are making lots of noise. LOTS. I have had that issue before, and after a couple hundred miles it went away. Hopefully this is the same or better. I plan on doing an engine flush with MMO and then continue running my dino oil. Hope that will help some. Other then that, the engine is easier to deal with now that the cruise control and AC stuff is gone. Can't wait to get on the suspension next.
I'm sure at high speeds you won't notice. However, i bet at low speeds and in torque steer situations you will notice it to be a good deal stiffer with alot more feedback.
Well, I would think the best bet would be the OBW springs with the OBW shocks, if it really is that easy. I assume the springs are of pretty equal lengths?
