Everything posted by rpiereck
The only problem is that the Forester only has one rear tow hook on the right side, hence the Loyale.
I lot less work than shoveling the whole thing!
I have been very busy lately with work, school and other stuff in my life lately, so I haven't been around too much; however, I wanted to share this with you guys: THE SUBARU TOW PLOW Ingredients: 1 driveway with 6" of new fluffy snow, plus 8" of hard packed old snow 1 Subaru with two tow rings on the rear 1 Yakima Load Warrior roof basket (others may work too) 1 large, heavy, cumbersome object that fit on roof basket (I used a plastic box with 100 lbs of my Army junk) 1 tow strap Optional: 2 carabiners, not the weak ones, mine were climbing grade 1 bungee cord Put roof basket on end of driveway, in a way that you may back up the Subaru to it. Place cumbersome object on roof basket. Connect tow strap to tow rings on rear of vehicle, in such a manner that the strap forms two even lines between the roof basket and the tow rings on car. You may use the carabiners to attach tow strap to car or roof basket, and you may use the bungee cord to keep your cumbersome object planted on the basket, unless you like seeing your stuff being strewn by the street as you plow. Get into Subaru and drive up and down the driveway to remove snow. When you drive you may want to drive to one side of the driveway, and then back down the other, so that your tow path is wider. After doing your driveway in a satisfactory manner you may also do your street (I did!). Keep you speed low, as the tow plow will tend to float over the snow and not do such a good job when you are going fast. I found out 15 mph was getting too fast for this. When your neighbor asks you what are you doing dragging a loaded roof basket with a tow strap, explain to him you are plowing the road. Marvel at the puzzle look in his face. You want pictures? Of course you do! Here is the tow plow connected to the Subaru Notice that the large, heavy, cumbersome object is essential to weigh down the roof rack for a proper plowing job. Side view of tow plow, notice the snow levels in front and behind it. Rear view of the revolutionary Subaru Tow Plow View of attachment on the rear of the vehicle, using two carabiners to connect the tow strap to the tow rings. I was worried that the muffler might melt the cheap Walmart nylon tow strap, but it was fine. I don't know if it was the outside temperature was too cold to melt nylon, or if the Loyale's exhaust has enough leaks that the exhaust gases are cold when the reach the muffler. Probably the latter. Here is the driveway before the tow job, notice the tire tracks through the new, fluffy snow. Here is the driveway after the tow job. The center was done by the Subaru Tow Plow, and the edges were done with a snow shovel. Disclaimer: No roof baskets were harmed on the plowing job, despite the flexing on the aerodynamic plate. I gotta patent this!
New old-school parts cross reference
rpiereck replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep, forbidden here too... -
I see on many forums that when people ask "what size wire should I use?" the answer sometimes sounds like either "the biggest the better", or an arbitrary gauge size without basis for the choice. The gauge size might be correct, or not. As an aircraft mechanic, I am obliged to use the proper size wire when I do repairs, and there are guides I must use. These two graphs are good references for making wire selections. For automotive applications, assume the circuit voltage to be 14v for this purpose. This graph is to be used for continuous loads, like driving and fog lights or anything else that must be continuously powered. This chart shows two curvers, 1 and 2, for wire that are either bundled or hanging in free air. That is due to the fact that wires in bundles can't dissipate heat as well as thos hanging in free air. For most add-on automotive applications the cable is hanging in free air (not bundled), so I'd use curve 2. This one should be used for intermittent loads, such as horns, brake and turn signals, etc. These are instructions for using the charts above. Granted, these are for installation on aircraft, but if it's good enough for an aircraft, must be good enough for a car, imho. I hope this helps anyone trying to determine wire size for any application.
H Braces
rpiereck replied to rpiereck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No Turbo here, but why would it fit on a Turbo, but not on a n/a? -
need date of wcss11 meet
rpiereck replied to 86subaru's topic in Meet n' Greet. Your USMB Welcome Center
I have been trying to convince the wife that we need some vacation in Oregon this year, and that we should drive the Forester down there. I love road trips, she's not too keen of them... If I do go I'll be in the blue Forester with Alaska plates! By the way, I looked at all the pics of WCSS10 and I didn't see one single Forester! Were there any present? I saw plenty of Imprezas, Legacys, Loyales, Brats, Bajas, etc I didn't see one single Forester or Tribeca. -
1985 Subaru GL Photo Shoot
rpiereck replied to Love_em_when_there_old's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Totally suck mate, sorry to hear about your Subbie, it was a nice little hatch! I'd be furious and ready to kick some rump roast if some punk kids did that to me... -
I'm looking to change the oil on the differentials of both my Subies: a 91 Loyale and a 08 Forester. Since this is Alaska and it's freeking cold, I am supposed to use either 80W or 75W/90 according to the owner's manual. Here's my dilemma: I already went to two auto shops, plus Walmart and my super market and they do not have either of those oil weights. I have found 70W/120 and 75W/140, the only two oil weights close to the recommended. Now, if I do get either of those two oils, would the lower operating temperature viscosity (120 or 140) be too thin for a differential? One in question, the 75W/140 is Royal Purple, the same brand I use for my Forester's engine, my oil of choice, and the bottle says that oil is formulated for limited slip diffs. I admit that despite me doing all my maintenance for the past 18 years and being a licensed aircraft mechanic I am a bit of a dunce when it comes to choosing an oil weight other than the recommended by the manufacturer.
Dyno #'s for Suberdave's Wagon
rpiereck replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I love to see when someone builds everybody else's dream car! Way to go, awesome wagon mate! -
I Own a 91 EA82 wagon, and just the other day I found out a guy nearby who's selling a late 80s (I don't know exact year yet) EA81 wagon for $100. It's not running. If I do buy it for parts what can I use for an EA82 wagon? I am even thinking of buying it to try to make it driveable and try to sell it...
I have a 2008 Forester and the hillholder will hold as long as the clutch pedal is pressed. For the owner of the 2008 model who said his hillholder will release at the lightest lift of the foot on the clutch pedal: your system needs to be adjusted. My Owners' Manual outlines how to adjust it, it should be in yours too.
Meeting in Fairbanks, AK
rpiereck replied to rpiereck's topic in Meet n' Greet. Your USMB Welcome Center
Well, we had two Foresters and one WRX show up... we waited outside for half an hour, and we spotted a few EA82s turning into the parking lot... but drove past to the movie theater. :-\ After freezing out in -25F weather we decided to warm up a a local coffee shop for chat about cars, the cold outside and life in general. Later when things warm up a bit we'll do this again, I'll post it here in case anyone cares to join us. -
Any Subie owner in Fairbanks, AK is invited to show up tomorrow, Saturday, December 28 for a meeting. We'll be at the theater parking lot, facing the street. I'll be on my blue Forester a little prior. Anyone is welcome, bring whatever ride. From there we'll find a nicer place to go, possible go for a cruise, some coffee whatever. If you wanna go, PM me and I'll send you my cell #. If enough people show up and there is an interest we'll make this a monthly meeting.
Monster Loyale spotted in Evergreen, CO
rpiereck replied to rpiereck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It sure does looks like a monster! Funny thing is, with the lift and all that Loyale is still shorter than the truck next to it! -
That's a brand new plate to commemorate the State's 50th anniversary next year:
