Everything posted by Txakura
What to check for inoperative cruise control?
Txakura replied to jeryst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it's a factory cruise it will have the vacuum pump. If the dealer installed it, they may have not felt that was necessary, hence the surg-o-matic source of major irritation. (different thread on that one) -
92 loyale 4wd push button axle seal????
Txakura replied to jazzmandolin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IIRC they are directional with 'chevrons' in the seal, so there is a right and left side seal. Mike can I leave my car with you for the weekend? -
Does camber affect understeer/oversteer?
What car? and I dunno, my 1990 Legacy has the panel lights on a ring on the headlight stalk instead of the rotary hahnyocker on the the dash (?) -
I really liked the Wagon Mafia. Those shots rolling down the highway are great, probably really woke up the general population from their little driving comas. Also rare to see the wagons on pavement !
Album is here http://s33.photobucket.com/albums/d59/Triquel/WCSS%2013/ Some pics here I love this thing. and 35 years later you can do this... a carbon fiber WRX. How's that for evolution? My son couldn't come, but his rabbits did. It's important. Absolutely amazing. Like a trip back in time to the dealer lot. WOW The RS visits with NED the almighty. Don't buy a car from that guy with his fingers open, he's telling GD some tall tale about how 5 Suubies couldnt pull him from a ditch tethered together
There were dealer installed vacuum cruise systems, 2 or 3 versions of, IIRC. I seem to have 2 of them, and one factory set up. If your cruise panel is to the right of the wheel in a rectangular slot (normally used by the power mirrors) it is a dealer add on. Mine went bad at the little switch box itself, the 'on/accel' button was simply not working. Unfortunately I followed the whole system all over the car before I figured that out. My non attractive repair was to wire a small non locking push button switch from radio shack to the circuit board and bore a fugly hole in the panel and mount the switch on it. It may be the panel itself, pop it out of the dash and carefully take it apart at the seam. Rig a temporary switch to bypass the one on the board and see if it could be that simple. Also: The cruise control brain box is behind the glove box, there are switches on the clutch and brake pedal. See if one of the switches has fallen away and is not allowing it to work. Check for voltage at the brain box. Good luck and welcome to the board. -
Re gearing 88 gl 5spd trans and rear Diff.
Txakura replied to ski4living's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I need to know more about this. 'Retrofitting' I presume. :cool: -
WCSS convoy from vanc/p-town fri afternoon
Txakura replied to subinewby's topic in Meet n' Greet. Your USMB Welcome Center
Leaving now. Be safe everyone. -
Strange electrical symptoms. What could it be?
Txakura replied to nickolai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
nvm, I had thought it was the regulator and a diode failing, but that wouldn't put out 14.2 at an idle -
Good Lord, come stay at my place when you finish that one up would ya?
Wow, lot of views, no posts. I was able to get it to take a charge of about 20 oz of R12 and as I was charging it the compressor shut up. It still rattled a bit on the way home, but it was making cold air. I suppose the PO probably ran it low and kept running it until it didnt work at all, or it all bled out through osmosis. Mainly works now, it's too bad we cant be grandfathered and still service those without the conversion.
Coming to WCSS? What are you bringing?
Txakura replied to 92_rugby_subie's topic in Meet n' Greet. Your USMB Welcome Center
if I can get some small stuff sorted... the RS as it still has it's R12 A/C! -
post it all in the for sale section, you might have something useful to a fellow member - give it some time, if it doesn't go anywhere you can always send it away then
The compressor makes a very loud rattling sound when engaged, I thought maybe low on freon/oil might make that noise. In my shop we have a manifold and several pounds of R12. I have never serviced A/C. There is no procedure in my Chiltons. Most searches here talked about the conversion to 134a. Before I waste extremely rare and valuable R12 to a line leak or bad o-ring... what should I see for normal pressure on the gauges when I connect them? could it be that the compressor itself is simply bad/ going bad (no cold air at all, loud rattling) TIA
My 1st Baru.....1985 GL 2 door nonturbo M.P.F.I.
Txakura replied to bRees's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No. GD was being kind. -
different size tires question
Txakura replied to Skysm182's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.miata.net/garage/tirecalc.html -
The problem was mainly me. The 4/2 lever was always a little off, it had 98% of full travel to the rear before hitting the center console. It had even less travel after dropping the transmission for the lift. I made a 1.75 inch spacer for the linkages, and cut and welded the D/R lever to a new length and angle. When I posted this, and did not mention the drop, I had the linkages rigged for test flight only. I freaked and posted too quick as it SEEMED like it should have all worked normally. So, TY all for putting up with me and trying to help me out when the problem was the owner/operator. :-\ It works great now, and adding one turn to the lo/hi rod has really tuned that to be better than it ever was.
1988 gl wagon tach not working
Txakura replied to methusalah's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Loose connection on the back of the instrument cluster? I have some similar issues on a 90 Legacy, gauges drop off, come back on... that's where I was heading to check mine since none of the systems have anything in common other than that connection at the cluster itself. mine is the tach and fuel gauge. -
question before i swap transmissions
Txakura replied to man on the moon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine did not appear to be leaking, I was driving the donor engine around and knew how it ran. It had a lot of weepy gaskets, valve cover, valve grommets, oil pan, etc etc. I'm just throwing that out there, I'll never move another engine without changing that again. It was the ultimate burn, and it crapped all over my nice clean engine crossmember too. it drips like he// on the cat and gives that ultra sexy cloud of oil smoke when you stop and comes through the vents to perfume the interior. IT was SOOO not worth the hours to remove and reinstall the engine just to spend 15 minutes replacing the gasket. Rant over, I hope you get a D/R going. Good people here, they'll help you through it. -
Power windows and Turning signals not working.
Txakura replied to travis1990's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You found all the stuff under the passenger seat, so I'm not sure what else you've followed around. Do you have power at the main switch panel? The main switch panel wiring comes through the door and enters behind the driver kick panel into the car. Do you have power at those connectors but not in the door? -
Mine too. I did a d/r swap in my s/r 90 Loyale. With the matching 3.9 ratios it was simply a transmission swap. I was also able to take the best bushings from both linkage sets and get a better feel at the shifter with less free play. Members of this board sent me the 3 pieces I needed to make the nice d/r console, where the s/r had only a boot and carpeted floor hump. My donor car was an 87 GL wagon. Everything was a straight across deal, you do have the vacuum ports on the left fender up by the wiper motor to cap after you go to the mechanical linkage from the previous vacuum set up. btw, I used that time to pull the engine and re gasket it, just dont ask me about the one gasket I DIDN'T change, the rear main, that let go two weeks later so, uh, if you have it all out anyway... you might as well change the ONE gasket that requires the engine to be removed to change it inspect your clutch, yadda yadda yadda -
Hmm. Ok, now I know the dif between the hi/lo rod and the 2wd 4wd linkage. It refuses to come out of 4wd, is this the thing I have read about where you have to jack the car to take the load off and run in reverse to disengage? rolling backwards and forwards has done nothing
