Everything posted by svxpert
Engine and waranty
svxpert replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits not going to qualify because its out of the car. there is no way of knowing the true milage they will say. why didnt you just fix the original engine in your car?
98 2.5 damaged cam bearing cap advice needed
svxpert replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi dont think subaru sells just the new caps. i have never seen a part number for one. if this the case, just make sure the surface is as level as you can get it and buy or find a nice bolt.
tranny oil frothy on dip stick.
svxpert replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow do you flush a manual transmission? i have only heard of it with autos.
97 legacy 2.2 headgaskets
svxpert replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot likely to be external, those problems didnt start till the 2000 2.5
svxpert replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+ what maintenance have you done to it?
enhine oil cooling unit
svxpert replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou already answered that question. its for cooling the oil. take it off because you dont have the correct water pump to support it.
Check Engine light - possible timed service message?
svxpert replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1
svxpert replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot on a 1999 subaru
In Dier Need Of Parts!.....
svxpert replied to Loyale93v's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow was it stripped? did you strip out the threads on the mounting holes? these dont just strip. plus if your belt got loose, chances are you damaged the valves or pistons on the engine.
Noise post cam belt r&r
svxpert replied to RMDAV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, being the car is 13 years old, granted only 105,000 miles but the age is more important. They would have told you they recommend the following parts be replaced: All Timing Belt Idlers/Tensioner Camshaft Seals Front oil Seal Water Pump Thermostat Reseal Oil Pump Accesssory Drive Belts you didnt tell us how much you paid to have your belt done. This will usually tell us what was done. I used to cam belts on SVX's for $250, that was 5 years ago. No most owners would want those other things replaced too. I didnt hammer them because the engine was opened up at that point and it was easy to do cam, oil seals, oil and water pumps and the accesory belts.
Ej22 timing belt issues
svxpert replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<So can It run with maybe 1 tooth off but tick? Also the rad it not installed.>> i dont think the timing belt has anything to do with your ticking.
crank postion sensor 97 2.2 question
svxpert replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany check engine light? did you replace the coolant temp sensor?
svxpert replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<still no start, new cam sensor, coil , fuel filter , plugs wires, check all fuses, grounds , and getting fuel , newer timing belt, water pump, just cranks,>> are you getting spark?
'99 Legacy Outback engine flutter... HELP!
svxpert replied to darrenbrigman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I do have a mechanic buddy who says that the problem is a bad inner CV joint, but after putting it in neutral and bringing the engine up to about 1200 rpms, the flutter could be felt. Then he said it has to be a motor mount. I think he's just guessing at this point.>> yeah, dont think he's a car mechanic. did you check the coil pack? no need to keep replacing plugs like you did.
03 Forester head gasket need help
svxpert replied to tnjauto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdepends on how bad you overheated the engine.
head gasket replacement
svxpert replied to curtisbad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<spent ALL afternoon driving around town looking for a dang chiltons with absolutely no avail .>> get a subaru service manual like davebugs said.
Overheating after a new head gasket install
svxpert replied to 41magmag41's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid a qualified subaru mechanic that knows what there doing do the work?
need help with decision
svxpert replied to Dave P's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 3.0 takes premium fuel. they changed that with the 3.6 H6
02' Legacy 4cyl. Going for valve job, what else while there?
svxpert replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<< It has 135K miles. The headgasket was replaced less than 1 year, about 10K miles ago... together with all belts, not sure about seals. I am not doing it myself, it's at the shop now. >> why are you doing a valve job now?
Trouble removing cam pulley
svxpert replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgwilson87, can you post a picture of the front of the pulleys where the bolt is? thanks sorry to hijack the thread...
timing belt how to with picks
svxpert replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Q: could i have reused the the wp gasket, most of which had been compressed?? i saved it just in case. what do you think?>> for the money it would save, how much is the gasket? say $8? i wouldnt risk it. Time>money
Where can I buy clutch and flywheel bolts?
svxpert replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Thanks guys, and I agree going to a regular bolt store I may not like, it seems like all flywheel bolts are usually designated specifically for flywheels, the pressure plate ones arent as big a deal, but I'm not sure of the diamter and pitch on those....>> yeah, the flywheel bolts have a thinner head to them so they dont stick out as much.
My EJ25D is almost done
svxpert replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice paint job! did you have to use oversize pistons?
svxpert replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice article. i would add/change the following: 1. dont use sealant on the water pump gasket. if your having trouble holding it on, use a small dab near the outside of the bolt hole. 2. if your going through all of this, replace the radiator hoses. even the small one coming off the water pump. 3. use small binder type clips to hold the timing belt in place while lining up the marks. these are strong enough to hold the belt on without damagine the belt.
Sand Cast Blocks-EJ-22
svxpert replied to Quidam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmost, if not all subaru blocks are sand cast. thats how most manufactures make aluminum blocks. what are you exactly asking?
