Everything posted by svxpert
Important question... for me
svxpert replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpull the engine and do the job right. with the engine out, you can replace the separator plate and rear main seal in the rear.
Cleaning Block Surfaces on a 2.5L EJ25(1998)
svxpert replied to mnwolftrack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbrake cleaner and red scotch brite pads, or if its really stuck on, a metal wire wheel with brake clean.
Forgive me if this has been asked... location of TCM? - Now with photos!
svxpert replied to classact2575's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<i'm not 100% sure but, i'm pretty sure in the 1st & 2nd pictures with the big 'JH' on it is the Transmission Control Unit. is this what you are looking for?. >> yeah, if the JH part isn't the TCU, its the ECU. Either way, they are both bolted to each other with 10MM nuts. take the nuts off and disconnect the plus from both, then you will be able to pull them both down together.
Air Bags and possible Dangers Question
svxpert replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.drivesubaru.com/Win06_WhatsInside.htm lower down there is do's and don't for airbags.
2 ?'s b4 pulling pin on T belt tensioner
svxpert replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<2--this is not related. the cam casings have the two 1/2 moon cut outs that the platics inserts are to be bonded into. Should I install these when I install the valve covers (at same time) or bond them in the day before (hold them in place with some tape maybe?)>> they should be already bonded into the head casing.did you remove them? if there still on the head casing, leave them.
Timing Belt Adjustment
svxpert replied to Pilgrim 54's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles on the vehicle?
svxpert replied to Pilgrim 54's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Timing belt is loose and needs to be tightened up.>> your timing belt is loose on a 2005 Subaru? why do you think this?
Motor mount: how do I get this stinking bolt out?!
svxpert replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you lift the engine up at all?
Ouch - Timing Belt Parts Cost $$$
svxpert replied to stevetone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Was I close, or did I misrepresent the total that a dealer would charge?>> not sure what dealers charge these days, depends on location i guess. they have the timing belt kit on ebay that had these included: (1) Timing Belt (1) Timing Belt Tensioner Bearing (2) Timing Belt Idler (1) Timing Belt Idler Sprocket (1) New OEM Water Pump (1) Water Pump Gasket (1) Valve Cover Gasket Kit (with Valve Cover Grommets) (2) Camshaft Seal Kits (with o'rings) (1) Front Crankshaft Seal (1) Oil Pump Seal Kit (Oil Pump Shaft Seal, O'Ring, and 'Mousehead' O'Ring) (1) A/C Belt (1) Alternator Belt that kit came in at just over $200. that should be fine for 1990-1995 application. you can re-use the old tentioner as long as you load it right.
wheel bearing warranty question
svxpert replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi never heard of a subaru wheel bearing recall ever. better check the online recall sites for this.
Rear main and separator cover...
svxpert replied to dmr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<So SoA is paying the shop for 5.4 hours of labor, and the shop has now also charged you for 3 more hours (albeit at a lower-than-normal rate), so they're double-dipping. They're screwing you, and screwing SoA as well. just please tell me they didn't try to charge you 2 or more hours labor to replace the timing belt and tensioner (already covered by SoA warranty time).>> i would agree to this BUT, why is the headgasket still under warranty when you have 90,000+miles? is it covered till 100,00? with that said, if its only the "headgasket" that is under warranty, the other parts, tentioner, rear main, separator plate woudn't be. right?
how much should it cost?
svxpert replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat are you using to get them out? being a CA car, shouldn't be too much rust/corrosion.
Gasket for oil filter
svxpert replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno, seperate part, seperate part number.
svxpert replied to dmr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<< However, the dealer quoted 1.5 hours labor for each. >> ask the dealer if this is a quote from an engine that is still in the car or one that is out. i'm thinking its for the first one.
What is that hole for?
svxpert replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe knock sensor hole is on the shortblock not the intake manifold on the 90's EJ series engines.
AC Wiring Help for 98 Impreza Wagon
svxpert replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the sysytem charged with refrigerant?
coolant leak
svxpert replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I replaced the pump( with new not reman) and the car has been running great.>> did you use a new gasket?
head gasket question
svxpert replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I was reading the Haynes manual and it says to remove the cams, but they do not seem to be in the way of the head bolts so I was wondering if the removal was really necessary?>> i'm getting this strange felling your doing this while the engine is still in the car? are you?
Danger in driving w/no driveshaft on AWD car?
svxpert replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"but the front section to the bearing and of course the rear axles and diff are still in place."
Refilling coolant under vacuum success
svxpert replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin the picture above, theres a water jug with (looks like) plain water in it. was that used to flush the system first? or did you fill the system with just water?
Alloy wheels for 97 Legacy
svxpert replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<svxpert, Will the 16"'s fit on my 14 brakes with no issues? What tires are on them? Could you send pictures to LHROCKER@EARTHLINK.NET. I'm interested. Thanx, Pete>> pm'ed and sent pics. thanks
svxpert replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<Correction. Those are 97-99 2.5GT wheels.>> actually those wheels were used on Legacy GT's up to 2004. lhrocker, if you want a set of those wheels, i have a set with new tires on them for $325. i will not ship but i am in south NJ. thanks
T-Belt time, idlers question
svxpert replied to 86BRATMAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsubaru. thats the safest bet.
Rear Wheel Bearing Job Question
svxpert replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I've doused it with PB Blaster and have banged away on the threaded end with a 3-lb. hammer and punch but it won't budge.>> cut it off and buy a new one. so much corrosion on them makes it impossible sometimes to salvage. are you taking the hub to someone with a press to do the bearing?
No start, crank or click - back to the drawing board
svxpert replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<There's an alarm / door unlock system that is rather poorly wired in I'm discovering, I might try to cut that out of the car but I'm apprehensive about jumping into the CF of wires that is in there.>> if it starts when you used the trigger start, you could have a problem with the keyless. to unhook the keyless without cutting wires, look take underdash panel off (2 screws) there are two connectors that are blue, that make a Y connection. unplug them from the Y and reconnect the two blue connectors (original). your keyless/alarm is now disconnected. see what that does.
