Everything posted by shortlid
Anyway to install rear fog lights in a Roo?
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCny-Dave understand, that is the same guy that runs around with high beams during the day!
No Radio signal when rear window defost on?
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks guys going to try pin this down soon.
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, I will check it and yes rear defrost works fine. Also radio signal is great as soon as a turn off the rear defrost, soon as I turn rear defrost on can't get any signal?
Ok have a '03 Legacy GT sedan with the antena built into the upper part of thye rear window. However I have noticed this winter that is the rear window defoster is on no AM or FM stations come in AT all? Is there a fix for this?
Can PCV be replaced in cold weather
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk the PCV screws into the block corrct or is it up at the intake end?
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do this but then people can't tell if you are changing lanes.
2.5L vs. 2.2L in buying a new (97) legacy outback.
shortlid replied to Nick12684's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepends on the price? What they want for it.
I tried to replace the PCV on my '03 Legacy GT. However it was - 3 degrees last night and the hard line that goes to the PCV was too hard to disconnect from the PCV. You guys have any ideas?
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep all the SAABs and Audi's and Volvos I have seen with them in the states have BRIGHTER red rear fog lights
OK,so I use my '03 Legacy GT sedan as my foul weather transportation. I use to have a '99 and then a '01 SAAB 9-5 that has a rear fog lights that were great keeping in attentive drivers from rear ending you in heavy rain, heavy snow or well FOG. I know UK requires them on there vehicles. So if Subaru's are sold in the UK and other places in Europe it would have to be equiped with rear fog lights. Anyone know if we can activate this feature on the state side Subaru's
Carbon Build-up SeaFoam Product Question?
shortlid replied to pdigiacinto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just sprayed Deep Creep which is Seafoam in a aresol cna down the tB of my '03 Legacy GT with EJ25 and boy did it make a diff. much more throdle response now.
Any way to Disable DRL
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou were correct on my '03 just unplug the white connector to the black box next to the steering shaft! Easy peasy!
CV boot catalytic heat 3.0 ?
shortlid replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice so I can do this peice mail, this would require just, brake cleaner, CV greese and and a new OEM boot.
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTried to search to DRL nothing came up?
I have a '03 Subaru Legacy GT sedan. I Dislike Day time running lightsan dwould liek to disable them on this car. However I cna'tfinda fuse dedicated to this. Is there any way to accomplish this?
What is Subaru Long Life coolant
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk so Peak Long life is the stuff to get. Thanks
Will Subaru 17" OEM wheels off a '05 Roo fit my '03 GT sedan with 16" factory alloys
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny one have pics of newer 17 inch on older Roos.
shortlid replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, can I seperate the inner fron the outer cv to get the new boot on the inner?
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the link, 225/45R17 is the size I need.
OK, want to do a drain and refill with 50/50 distilled water and correct coolant. Should I use good old green stuff low silicate, organic non-silicate coolant, or the exspensive Subaru Long life in my '03 GT with EJ253? Looks like the new Blue stuff was in 2009 + Roos only?
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSweet now on the hunt, guess will need 205/50R17's to keep outer diamieter about the same.
Will Subaru 17" OEM wheels off a '05 Roo fit my '03 GT sedan equiped with 16" factory alloys? Some have said 15" steelies off the L or Brighton '03 Subaru will not clear the front brakes of my '03 GT. So though maybe I could go the other way for summer tires and keep the 16's for snows.
subaru OEM ATF ?
shortlid replied to ivantruckman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe shift quality has deteriated. Hoping full syn and filter change will help. Also ATF WAS changed 30k ago.
shortlid replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan I clean the inner joint, re-pack it and reboot it without taking it completly out of the car?
subaru OEM ATF ?
shortlid replied to ivantruckman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, so If I am going to drain and refill a 4EAT in a '03 Legacy GT sedan with 95k. Any quality Dextron III product will work. I am going to replace with Castrol Full-synthetic multi-import ATF. Also replacing the spin on automatic transmission fluid filter. Dealer wanted $38 for it got a WIX version for $8!
