Everything posted by shortlid
CV boot catalytic heat 3.0 ?
shortlid replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for info, will clean and repack and replace with OEM boot.
shortlid replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo the dealer said I can replace with a factory remanufactured axle. for $213 is that the going rate for a remaned one? Any online sources?
shortlid replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis has always been an issue for Suabru had to reoplace the inner boot on my '99 Legacy L wagon with EJ22 casue the cat cooked it to death at 60k. Now my '03 Legacy GT seadn with EJ25 did the same thing at 90k.
Head gasket letter from Subaru
shortlid replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe I was hoping I would not have to post on this again. Here is the situation my Mom is the orginal owner of a 2003 Legacy GT sedan from Cherry Hill, NJ Subaru was a exec. car. she had both head gaskets replaced at 70,000 by SOA under warrenty, however at 95,000 the dealer that is near where she lives now in Michigan said the head gaskets needs to be replaced again? This should be under the EJ252 warrenty correct!
Replace water pump when doing T belt?
Ok first timing belt replacment for a '03 Legacy GT sedan 95k on it now. Should I bother with the water pump replace at the same time on the EJ251? Also in my old EJ22 days we use to replace the oil pump during a T-belt chnage? Same issue with teh EJ25??
New Hampshire Soob Repair shops
shortlid replied to slickjesus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am in Southern New Hampshire and would like to find a good independant Subaru repair shop. My '03 Legacy GT sedan has 95k on the clock and I will need to get the timing belt done at 105k P.S. found one called Farr Auto in Hempstead, NH he owns a '03 Outback with 280k on the clock, his wife drives a '07 Forester. Any mechanic that bought and sold Roos for two years is Ok in my book.
What is the trailer weight rating of a '03 Legacy GT sedan in automatic
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a sedan, I have two small utility trailer I do dump runs with. Have towed trailers with my '99 Honda Accord Ex 4 cyl. 5-speed for thousands of miles, so experince is not a issue.
Tire rim bolt pattern
shortlid replied to roger1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the reply and info. Any links to the rally rims, I would rather not expose the stock alloys to winter salt.
What is the max trailer towing capability of a '03 Legacy GT sedan in automatic. Also is there a plug and play set-up for the trailer wiring?
shortlid replied to roger1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo 5X100 bolt pattern wheels fit my '03 Legacy GT. Will a 15" wheel fit as well for snow tires, the 205/55R16 are too wide, and too low profile to really do well in deep snow. Thinking about some 195/65R15 stock steel wheels for the car, will 15" rims clear the calipers on a GT?
Manufacture interval for timing belt on '03 EJ25
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, thanks bro;)
I am looking through www.mysubaru.com web site and can't find SIA interval for a timing belt replacement for a 2003 Legacy GT sedan?
ATF temp LIGHT KEEPS FLASHING
shortlid replied to Scarpachy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Guys, Guessing maybe a Thodlebody cleaning might fix it up.
shortlid replied to Scarpachy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTransmmison is running great no binding shifting where it always has. However, she did say that this happened after a long crank, where the car would not start. Then she tried it again and it started??
shortlid replied to Scarpachy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy Mom's '03 GT sedan just did this. Cold out of the garage A/T temp flashed for a Three mile trip to the Mall. Restarted after got there light came on for test and went right out??? A fluke, or worse???
15 in rims?
shortlid replied to rangermatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is what I did with my Toyota Highlander with 16" wheeels. Use the 16" alloys for summer tires. and 16" steelies off a base model for dedicated snows. Works well for Northern New England set-up!
Head Gasket failure....
shortlid replied to Loyale93v's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am in New Hampshire and I had my grand fathers '99 Legacy L wagon with teh EJ22. Greta car but when the rust cancer starts there is no way to stop it. eventualy the safty of the car in a wreck is comprimised. I would find a EJ22 powered Subaru furthere down south for her.
got any idea what's up with my brakes
shortlid replied to farmerlucy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA failing brake hose can do this with pressure build in a particular calpier it serves.
Warped rotors - who's experienced this?
shortlid replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHigh temp paint, on the center hub area on outboard side, and inside inm hub area. Mask off the braking surface and to the lip and inside as well. Keeps them nice here in New England allot longer!!
New from VT. 2 quick q's
Allot of boost yes, but handle it MUCH better than the earlier open deck N/A EJ25's
EJ22 is a bullet proof motor had one in a my '97 Legacy L wagon that I got from my grandfather in Woodstock, Vermont best Subaru I have owned. He could not see well drove it down a 15 foot imbankment. Tow truck brought it out too the branches out from under it and drove it for another 60k!!
How's this for some snow tires?
shortlid replied to georgefgd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVermont plates make it go through the snow that well you know.
Stealerships replacing heat sheilds??
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe reasons this will likely be our last Subaru are more to do with the head gasket issues and A/C system issues. I think this Subaru just had too many GM influenced parts. Alternator issues, says Delco on it, etc. Hopefully Toyotas share has helped FHI with quality. This '03 is not anywhere near what the '97 Legacy EJ22 powered "tank" we had before was, even with three times the amount of miles on it. The older legacy never gave us any issues.
shortlid replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNipper, they could not have been that worn down I replaced the rotors and pads front AND rear 10,000 miles ago!
Welcome fellow Northern New Englander. Soobs are popular in Burlington, VT for sure. What trim level do you have?
