Everything posted by 1-3-2-4
Coolent temp sensor on it's way out?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's under the intake manifold right passenger side? I just know it's in a tight spot but what do I need to remove to get to it?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo has not happened before but I've noticed in the last 48 hours it seems to take longer then normal.. Also it was 3 seconds continuous cranking It idles fine.. would live data from my scan reader tell me anything? Might not really matter much since I can almost see the outcome of this. One thing I have not really checked for is if it's worst when the car is cold or warm or the same when cold or hot.
I just came back from a quick bite to eat and I go and start the car and I'd say it took about 3 seconds of cranking before the car started.. a quick search here says the coolant temp sensor? I think the sensor is located right under the throttle body right? One thing I must ask is it really needed to drain the coolant out just to change the sensor?
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you see these are not the akebono's I changed my mind at the last min.. I also called rockauto to make sure they were an axle set since the price was so low.. ($25.51) anyways my other concern was if it had the gap on the pad side which it does.. pads are ceramic pictures from my htc evo
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgeeez... I'd say like 10-15K
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think they are warped but the depoits left from the pads what I'm talking about now is metal on metal.i drive about 28k a year so I got decent time from them.
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice pads delivered tomorrow but I doubt the rotors are good anymore.. I cringe when I need to put on the brakes so I try to be as light as possible. I might upgrade to slotted when I get the rotors this week
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmostly mid/high speed.. but remember I still have the other tie rod and lower ball joints to replace.. but I do remember when replacing the rotors with new rotors the brake judder went away.. My guess is the pads have uneven wear on them.. I'd say it only took about 72 hours on the new rotors for me to feel it again.
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I can remember with the Hwak HPS pads (my first time buying something other then OEM) did not dust crazy but it was still a decent amount.. but the Hawk's are not a full ceramic pad as far as I know.. speaking of pads anyone have the part number for the brake shoe? I know it's on this site someplace I just forgot to write down the number.
My '95 Legacy: Trashwagon10
I just ordered myself came to $25.13 4 the large one and 2 #74 LED's all in white.
Pine Barrens New Jersey ALL Week long
I was waiting for someone to PM me when they were going to go.. it seems like when I go I'm going to have to go alone last year it got called off.. I brought a tow strap and everything.
http://legacygt.com/forums/showthread.php/10-dollar-10-minute-gauge-mod-124039.html
True but I think I need like 6 or so.. I forgot what the total amount was like near $30.. I'd have to double check
lol to show you how much I wanted to do this and fell off is I have the bezel for the gauge unscrewed for about a year now... damn LED's cost a lot to change plus having to sand them down..
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah they have them but higher on the pads and shipping.. so I think I will stick with rockauto anyways.. besides I still need to get that motive power bleeder.. I tried one of those one man bleeder cheap kits with my impreza once.. man what a huge disaster! Also I want to say is I have brake judder now from what I understand is the pad material on the rotors... OK however back in march I replaced my front rotors only and I broke in the rotors/pads as if it was new but it still was not long until it came back again.. and it's not as if I ride the brakes (I have a MT) I'm sure it's due to the cheap non ceramics pads?
your needles are white, right?
the foreground lighting on the dash in the picture are the lights above the speedo and tach that shines down on the gauges? It seems driving with another color would be annoying I was going to do something like that but I want everything white but not that annoying bright foreground flood of light.
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've already ordered many of things from rockauto.. just that the akebono pads I need for the front are delayed one business day
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was looking at this link here.. http://www.speedycarparts.com/sku/Subaru_Legacy_Akebono_Brake-Pad-Set_1995_1995_W0133-1616583.html $50 a pad????? So that would be $400 for 8?
noisy lifter
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow.. 2,500 for the trips I'd do I need to find stores that still have cases of oil... I used to buy them at walmart but they dont seem to have them anymore.
brake pads
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey are a little pricey :-/ btw I've had hawk HPS pads before and I hated them
What the heck lights do the foreground lighting on the gauge cluster?
brake pads
I'm about 85% sure it's the pads that are worn (I get a scraping sound when not on the brakes) and sometimes not when going straight.. anyways anyone know of some decent better pads then these autozone specials that were on the car? these are the pads that came with it when I picked up the car last year and I can say thank god it's time to change them out they dust like mad... back when I had my 03 Forester I put on Hawk HPS but I hated that the first few stops took a lot of heating up the pads for it to have a decent stop. I think I will be going with the Akebono ProACT Ceramic Pads
noisy lifter
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat? what does everyone here change oil at 1,000 miles?
noisy lifter
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell it's been awhile since I did the oil change about 4,000 or so miles ago. Also cam towers = gasket covers?
