Everything posted by 1-3-2-4
Oh lol no I'm not just replacing the disc I bet that's what the last owner did.. I wont know for sure till I see it first hand. The diff is not making any noise it's the bearings inside the transmission mainly when in 2nd gear. I'd say it's pretty tame however I've put 3K on it so far being this way.
Man and just to think last year in the legacy I was hitting snow banks and in like 7 inches of deep stuff :-| the car had a EJ22 but never thought about the timing belt floating thing.. Only reason I left the cover off was that stupid part that holds the bolt behind the cam snapped and took the plastic with it.
987687 I'm not pulling the engine to do the clutch next month I'm pulling the transmission because it needs to be replaced as well should be more then enough room to do what I need to do. Who knows what the last owner did.. they "SAID" that the car had the clutch replaced.. but who knows if it was done right or if they resurfaced the flywheel or whatever.. I've come to the conclusion the reason why the tranny is shot is because of a seal that leaked and it ran low to almost nothing and that was that.. It took me about 3 weeks when I got the car to keep checking the fluids until it holds steady now. I have no real problem pulling one or the other that's why I went out and picked up the engine picker and I have the transmission jack already. As to why not do the clutch now well I'm still putting it on a not so good transmission so what's the point in that?
I saw this early this morning I would think it would be the other way around? as far as being at BDC? so the pistons are retracted in the block? Having said that my gaskets as far as I know started to go around 221K Going to pull the heads next week. interesting thing to note is it really only overheats if it's really hot out and I'm moving slow or I turn the A/C on. I did a 651 mile trip and it never went hot coming or going Gaskets look in poor shape just looking at them installed...
Im going flat because thats less stuff to mix
almost everyone has the color I want to shoot (black) I plan on shooting flat black next year
let me guess the bolt where one of the cams snapped and broke the plastic on the cover? Haha I had that problem too.. I just left the cover off (it was the pax side) I'm glad the newer models don't use that setup anymore. I got a little scared because I took the car off-road into some mud and rain+ snow and all.. but it was fine.
I never knew summit sold paints however I don't think it would be as good as the nason paint?
Can't the clutch be changed with the motor in the car? I'm leaving the 3rd week of Aug for the transmission to be replaced. As far as that nut I guess I should be ok.. I have way more then enough extensions (seem to adopted some) but I will make a note of that.. I don't think my total extensions add up to 24" however.. this reminds me to pick up a feeler gauge tomorrow I'd have to check the FSM but I think it talks about how to find out what shim you need if you need to replace them. I'm going to be doing the timing belt at the same time I've been looking for 2 months on and off each time for Permatex Anaerobic, I go to the auto store (advance auto, auto zone) and I've never seen it in the store anymore.. I thought maybe they stopped selling it? If I can't find it local tomorrow I'm just going to order it online.
pending for the last week of this month I have a few questions getting to the bolts as far as the starter and bell housing is it going to be hard to get to those areas? I was not going to buy my clutch this week but next month but I need to get to the rear oil separator I'm pretty sure they make a clutch alignment tool just by it's self? I just have permatex ultra gray anything else I need to be looking for? Now as far as the heads go I thought I saw on some site or whatever about something pops out when you remove the cams? Also is goof off ok to use to remove the built up carbon never the outer part of the cylinder wall where the head meets the block? Any suggestions on a 12-pt 14mm socket in 1/2"
LOL I wish I can put a grill on my car still.. the car i brought somehow got bunched up in the front.. I'm about to remove the engine the last week of this month so I should have much room to hit the frame with a BFH. I was wondering if all that flat black was going to clash but I think it turned out really good.. it's like 5 coats, plus 2 coats of UV clear.
