Everything posted by sparky11
Subaru XV - Ute ...
Add the six cylinder and that should solve the power and towing issue. Too bad they won't build it.
Unacceptably poor fuel mileage. (cliffs at bottom)
sparky11 replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour running a 2.5, I'm running a 2.2 and if I remember at 75 it shows 52% load and doesn't want to stay in closed loop. Yours should stay in closed loop at that low load.
sparky11 replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt 72 mph with the drag of the board rack and soft sticky snows, you are probably in open loop most of the time due to the load on engine. I've driven with similar setup while watching data stream on scan tool. The mileage, speed, load correlation is easy to see.
SOLVED - Ignition Relay 91 Leg; Starter Failure
sparky11 replied to Cinder55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXContacts and plunger
sparky11 replied to Cinder55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, just jump from positive on battery to solenoid terminal to verify starter problem. On mine I opted to replace the contacts and plunged both. At 186,000 miles and lots of cycles it made sense to me. Now ready for the next 186,000.
Two questions about seat heater
sparky11 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo timer either, just off, low, med, high. Of course should turn off when ignition switch is off.
sparky11 replied to Cinder55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably just worn starter solenoid contacts. Easy $10.00 fix. Just replaced mine for same symptoms. You can hear solenoid engaging but nothing else happens.
Subaru" conditioner"
sparky11 replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this conditioner specified for 2005 and.up? Changed the coolant in the OBXT 2 months ago and didn't add any to the system.
Front end Clunking sound going over Bumps 2005 OB
sparky11 replied to studogger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles are on your OB? If the lower arm bushing is just slightly cracked and torn but not completely it is probably nnot the source of the noise. Mine are quite substantially torn and ripped but not completely and are quiet but sloppy. At 72,000 miles on my OBXT, my upper strut mounts are still quiet. Usually you can determine if the upper mounts are bad by jacking up the car unloading the struts and prying up on the tire or pushing up on the tire and feeling for any vertical movement in the strut mount bearing. There shouldn't be any at all. Also check for a loose disc brake caliper mounting bolt or caliper frame bolt. I had a caliper frame bolt come loose and it sounded just like a bad upper strut mount. Only made noise over medium rough surfaces. Bad inner tie rod ends can make the same noise too.
sparky11 replied to studogger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the front lower control arm rear bushings. They are notorious for cracking / tearing or ripping completely out. Mine are almost completely torn out. I will NOT be using the factory part. Upgrading to a urethane bushing set will cure.that problem and make the car steer better.
205 75 r 14 on a 90 legacy?
sparky11 replied to Captin Hook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been running 98 Outback alloys with 205 70 15 Michelin X radials on my bone stock 97 Legacy Brighton wagon with no issues. I swapped them out with new 205 70 15 Cooper Glacier Grip II's on 98 alloys with no issues other than they rub the front inner liner on full lock on a bump, and just barely. Yes clearance is tight but they work and I haven't had a tire damaged.
My Outback with WRX wheels
sparky11 replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNICE, NICE, NICE -- The WRX wheels set it off just right. I miss my red 98 Outback!! I leased it new in 98 and had it for 2 years -- now I wish I had it back.
inner tie-rod help
sparky11 replied to dgarlepp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo special tools needed. I use a large pair of channel lock / water pump pliers or a pipe wrench to grip the large end and just let the lock washer open up on its own as it spins it out, as the washer is soft metal. Easy change out.
Dragging front brake or stuck caliper
sparky11 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have never used speed bleeders, I either have someone pump the pedal for me or I use a Mighty Vac brake bleeder system.
sparky11 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXService the brakes first - easiest and cheapest place to start. Only replace parts if servicing fails to correct any sticking or noise issues. Soak bleeder with a rust penetrant first the day before if you think they are going to be a problem. Open bleed screw a few turns to make sure it turns freely and to make sure it is clear and close it back up lightly. Remove lower caliper slide / bolt and pivot it up. Use a big pair of channel lock pliers to retract the piston after you reopen the bleed screw -- I use a hose and container to catch the old fluid. Slide the caliper off the upper slide pin and hang of the side with a wire or set it on the suspension. Pry the pads out of their slides and remove the stainless steel slide insert. Clean the pad slide hardware and the hardware mount areas in the caliper frame using a wire brush and a flat blade screwdriver if needed. Clean the pad ears that ride in the caliper frame. Clean buildup from inside the caliper, around the piston / boot area and outer pad contact areas, being careful not to damage the piston boot(s). Clean and re-lube the slide pins. Add a little lube into the slide pin boot. USE LUBRICANT APPROVED FOR THIS OR THE BOOTS WILL BE DAMAGED!! I spray every thing down with brake cleaner after I'm done scraping and brushing. If re-using the pads, I always lightly sand them to break their glaze and spray with brake cleaner. Dry fit the pads back in the caliper frame with the hardware reinstalled to make sure they ride freely -- if everything is good lightly lube the pad ends and install them in the caliper frame. If the pads are stiff or stick in the frame sand/grind the ears and ends until they move smoothly. Make sure that the noise reduction shims are in place --hopefully you removed and cleaned them as well. Lubricate the piston and outer pad contact areas of the caliper and reinstall. Repeat for the other side. If you are using new pads, remove and turn the rotors or replace them. Dry fit the pads in the caliper frames to make sure they slide freely. I have had to grind the ears on some aftermarket pads because they fit so tight they would stick against the rotor. Rear drums -- remove the drums and clean out all brake dust from the drum and from the brake assembly /backing plate. Make sure the adjuster turns freely. Spray a little rust penetrant on the threads to free up and lube it. De-glaze the shoes and spray with brake cleaner. Pry shoes from backing plate and lube the shoe / plate contact areas. I always remove the rust lip on the drum and buff the inner and outer hub mounting areas and never- seize / lube the central hub mount lip. Check shoe adjustment and parking brake adjustment. Lastly bleed / flush completely all the old fluid out of the system until you get clear fluid from each wheel. Brakes service is not hard but as they say "God is in the details!!"
sparky11 replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen was the last time you serviced / cleaned / lubed the brakes? The pads could be sticking in their slides and dragging slightly on the rotor. A flex line starting to go bad could also be the cause. A sticking caliper is usually from lack of lube on the slide pins. Of course only lube the caliper slide pins and the pad ends. This should be done annually. Rear shoes should be service in the same manner annually also. Changing the brake fluid every 2 years or 30,000 miles will keep the master cylinder, calipers and wheel cylinders working for the life of the car. Never retracting the caliper or wheel cylinders without opening the bleeders will keep from backing dirty fluid and particles into the master cylinder and causing a failure there.
90 ej22 swap in 98 Outback
sparky11 replied to sparky11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Subaru360 for confirming I had the right combination. Jerry
sparky11 replied to sparky11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLOL I couldn't find a specific answer to this question UNTIL I started this thread and then the answer pops up in the like threads box!! The answer is yes if I have the correct EGR available head, which I do so I found the answer to that part of the question --anything else I should know?
I searched but could not find specific information however I am looking at a 90 ej22 and want to drop it into a 98 Outback. If I switch the heads with good 96 heads and use a 95 Intake manifold, all of which I have, this should work right? I have the appropriate y pipe also. Any problems I may encounter with this? Maybe a crank angle sensor?
Vibration when in gear (Automatic)
sparky11 replied to Old Pearl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have 2 new Generic Chinese made front CV axles on the Brighton automatic, replaced the broken one under warranty from Advance and NO vibration at idle in gear when stopped. Was really bad though with the broken inner joint. I would slip it into neutral at long stops to stop it. I didn't realize it was from the new axle because I replaced the engine at the same time and thought it was a problem with either the motor mounts or the aftermarket head pipe I used which was not exactly right where the cat bolts up. (I won't use an aftermarket head pipe again!) I found the broken inner joint when doing maintenance to the car so I got another under their warranty. We'll see how they hold up.
sparky11 replied to Old Pearl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA bad, worn, broken inner CV joint will cause an annoying vibration in gear that will go away in neutral. I had a broken inner joint that did just that. FYI it was a new Advance Auto Axle Assy and the inner joint broke in the first month. I didn't realize that that was causing the vibration for months.
intermittent vibration like wheel out of balance but that's not it
sparky11 replied to bbenton8's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the center drive shaft u joints and carrier. Also could be a bad CV joint on a front or rear half-shaft, usually inner.
Wagons only - post your pictures here!
sparky11 replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://img205.imageshack.us/i/brighton.jpg/ Camping with our two wagons. The pearl white OBXT and spruce green Brighton workhorse. Of course they both belong to the dogs!!
late model hesitation from stop.
sparky11 replied to Gentz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdon't forget that the 2005 is also a throttle by wire -- no mechanical connection to the engine throttle body.
Flood damaged Legacy
sparky11 replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBottom line is a flood damage car with no verifiable history should be AVOIDED like the plague it is! I HAVE repaired 2 flood damaged cars with great success--HOWEVER THEY WERE DONE WITHIN 24 HOURS OF BEING FLOODED, and they had water only up to the seats. 1 was an 85 Honda Accord back in 86 when it was relatively new and it was covered by insurance. I replaced all electronics that were on or near the floor including the main ECU. There was an identifiable water line inside so we didn't have to guess. We took out the seats and carpet and trunk coverings, pulled off the door panels etc to clean and dry them and the interior. Opened up the main harness covers, pulled apart all harness connectors, cleaned the connectors , etc and dried the interior. Changed all the fluids, serviced the brakes, repacked the rear wheel bearings -- you get the Idea! Many but not all electronics are powered even though the ignition is off and they are not sealed for moisture if they are in the interior of the car. Water and electricity don't mix so usually there is damage to them you can't detect visually even if you dry them out. Take it from someone who is both a professional mechanic and a fire / flood restoration tech, I would not attempt to restore such a no history vehicle unless it had historical value or was exotic and even then----???
