lewisd
Everything posted by lewisd
My 99 legacy brighton wagon uses a 2000 air filter. completely different size. also found out my 02 senors (and entire car emission parts) are California emission spec. Go figure, I bought it brand new in Norfolk VA and been on east coast since. No MAF sensor either. NAPA has your rear brake shoes as well.
axles
lewisd replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've gotten mine from NAPA and Autozone and they have lasted. about $60 apiece. not many used subaru parts around here (not when I needed them). -
thanks fellas. Subaru parts are hard to come by around here at auto salvages. I got timken bearing and other parts to go with it. having heck of time with tie rod end out of knuckle now. local grage will press all together for $40-50. I've been saying one more year for the past 4 years at least now. LOL
99 legacy wagon EJ22. I've got the same exact codes throwing every time. trying to get CEL out for emissions inspection. any update on this?
thanks gbhrps, I checked them out. I didn't find anything about the if the stub slips out of the differential (as if you pull the cv axle and the differential shaft comes with it). Does it just pop back in or am I out of luck. Thank you for the recommendation. I'll register with his website and post question there as well. It's not a whine noise but a clunking sound that speeds up and slows down with car speed. nothing while sitting still.
1 Lucky Texan, on 10 Dec 2011 - 11:36, said: I came across this in search and believe I have this happened. 99 legacy brighton wagon with automatic and 270,000 miles. Original cv axle, boot is not cracked or showing leakage. I have seepage from the drivers side diff, smell as it hits exhaust, and the clunking noise under load while accelerating even on straight line. not while turning. clunking got faster as speed increased. no clunking while still and engine running. If diff stub/spline did "pop" out, how hard is it to get it re-seated and sealed?
I came across this in search and believe I have this happened. 99 legacy brighton wagon with automatic and 270,000 miles. Original cv axle. is not cracked. I have seepage from the drivers side diff, smell as it hits exhaust, and the clunking noise under load while accelerating even on straight line. not while turning. clunking got faster as speed increased. no clunking while still and engine running. If diff stub did "pop" out, how hard is it to get it re-seated?
the one that came with the arctic freeze bottle. it did not have the adjustable upper/lower range faceplate over the psi scale (wifey picked it up at store while out on errand) so I made sure the outside temp was 80 degrees which was between the 75/85 temp stated in instructions. I mean it is cooling really well inside so I will just hold off adding anymore even though it was below what it called for.
So I added coolant (r-134a) to the a/c in my 99 legacy brighton wagon and so far so good. I followed directions on can closely and made sure I used a gauge and checked it frequently. It seemed like a long time for the gauge needle to bump up PSI to where it should be according to ambient temperature (40-50 PSI). I stopped somewhere around 30-35 psi for now and inside was running nice and cool. I'm just concerned I will put to much in... any thoughts?
I had the same thing happen to my 99 brighton wagon (a/t). look up my past threads. Don't even have a MAF sensor (don't ask unless really interested). Occasional codes thrown. It seemed temperamental with the weather. I'm thinking vacuum leak in one of the old hoses but it's stopped doing it for a while now.
Tire switch?
lewisd replied to 1Subaru1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
greeat info. I to have 99 legacy brighton wagon and front tire blew out yesterday. not sure how much longer I want to hold onto the car and put more money into so I'm heading out to salvage yards tomorrow. -
was just reading this thread. I have the 99 legacy brighton wagon CA spec since new and bought it in Norfolk Va. wierd how that ended up there. didn't find that out till several oxygen sensors never matched year/model. issues as well as air filters. doesn't even have maf sensor. Anyhow it's going on 265,000 miles now (knock on wood). If anything I'm having more issues with ride but that's because it's still all original. they're def great cars!
Spare parts
may as well take the whole thing. LOL when emptied out turn it into a chicken coup. that's what folks in my area might do. -
Spare parts
you can say that again... I've had to learn about all the quirkyness of my cali emission 99 brighton, and I got it brand new in Va Beach! go figure done thread jacking.
