What would you pay?
Fairtax4me replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAbout 30% under market value. That is a ton of crap to have to hunt up manuals and information about when it all breaks.
Shifter Linkage Replacement
Fairtax4me replied to doc526's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat' silly spring is 100% required for proper shifting. It's incredible how much difference it makes just to have that spring.
Tensioner brakcet
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah there's a bracket that bolts to the block. It fills out the area kinda between the oil pump and cylinder head. Courtesy of THIS THREAD on Legacycentral. Looks like lots of other good info there too.
Injectors... nope... worse
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it can, depending on the type of failure. In some cases the sensor can fail and not set a code right away. If the sensor doesn't respond to spark knock, the ECU has no way of knowing it is happening. If the condition that is causing the knock continues (poor fuel, advanced timing, high engine temp, etc) it can crack the piston, damage the piston crown, break the ring lands, break the spark plug. Spark knock creates higher combustion chamber temps, which only worsens the problem, since high temps also cause spark knock. So theoretically, a bad knock sensor can lead to combustion conditions that can cause major engine damage. That will relieve the pressure, but there will be still fuel in the rails. The better thing would have been to remove the feed line from the filter and blow the fuel out of the rails first with air.
Just installed motor, now low idle
Fairtax4me replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you not disconnect the battery while you had the engine out? Double check all of your vacuum and breather hoses for connection.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, the burnt valve was on number 1. I'm very inclined to think this must have been a contributor to the burnt valve. Thinking back, when I went to look at it the seller started it and I remember it ran funny for a few seconds then cleared up. (cleared up as well as an engine with a burnt valve could) After repairing the valve it was fine for a few days, then I started noticing it having this trouble when starting. When I looked at the car I remember finding some nasty dark brownish-greyish crud on the bottom of the radiator cap and all around the neck in the radiator, and I just brushed it off as needing a flush. I wiped all that out later when I was putting it back together after replacing the valve. The same crud has since returned. So now I'm thinking it must be combustion byproduct deposits making their way up to the top of the radiator. I'm pretty positive this must have been leaking before the burnt valve. The coolant got low and the engine got a little hot, if not overheated, with a college student behind the wheel driving up a mountain with a cracked knock sensor.
Me and the forester are fixina duke it out! :mad:
Fairtax4me replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's your MAP / Baro pressure value during all this? Throttle sensor values?
replaced HG, valves hitting.
Fairtax4me replied to papalobster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuessing this is a dual cam Ej25? Agreed. If the pistons hit the valves it would happen once and then wouldn't run anymore. It's probably lifters or the belt slapping.
Is this repairable?
Fairtax4me replied to Qman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust patch it up with Lexan so you can see the pistons moving. BTW I think the mouse is probably pissed that you wrecked his/her kitchen.
93 legacy awd 4eat to 5met
Fairtax4me replied to General chaos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think you need a computer. There is a pin that you ground to tell the ECU whether to look for auto or manual trans. The pin changes depending on year. Someone here knows though, it has been discussed a few times. Anything before 98? I think? is going to have a cable clutch, and that is going to be the easier swap for your year, but either cable or hydraulic will work the same. Cable and hydraulic pedals are different so get the pedal to match the actuation system you want. Brake pedal (the skinny one), you should get both pedals and the brackets too as the brake pedal bracket may be different. You need a flywheel and bolts. The crankshaft bolts for the auto trans flex plate are shorter than the manual trans flywheel uses. You need the longer bolts for the flywheel. Bolts to hold the pressure plate on the flywheel. Clutch kit you know. You will need the manual trans mounting cross member. The one on the AT is entirely different. Driveshaft is a different length, you know that already.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, it's not the side I replaced. I never did find actual wet coolant on any of the plugs, and plug appearance didn't offer any immediate clues. So I did a leak-down test today after work. Put shop air on number 4 and the coolant in the radiator immediately pushed up and started bubbling over like a boiling kettle. Testing the other 3 cylinders got nothing more than a small whiff of oil fumes from the crankcase. Now I have to wonder just how long it has been like this, and could it have played a part in causing the burnt valve (overheating) that put it on the market for sale to begin with. I get the feeling the PO didn't know of any issues with it losing coolant. I may do an oil analysis on it to see if there is bearing wear from overheating.
1995 4EAT transfer clutch reassembly question
Fairtax4me replied to jboymechanic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found one photo in the 95 FSM that shows that spring and that looks right.
Zero Compression on #3 (ej22 1999)
Sounds like it would work, but good luck getting a wooden block and a hammer between the engine and frame.
Grease for spline/ clutch fork
Fairtax4me replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually any type of lithium base grease will do. You need something sticky that will stay on the splines and not fling off onto the clutch disc and flywheel/pressure plate surfaces. Some people use a light coating of anti-seize. I have found a copper spray grease that I like to use because it's less messy.
Interior plastic parts getting soft, gummy, sticky?
Fairtax4me replied to Infidel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used to see this fairly often. Oil causes it. Oil from your skin or from lotion. Mix it with heat and it breaks down the vinyl on an almost molecular level. If you catch it early you can sometimes clean it with a mild degreaser and prevent further damage, but the texture of the vinyl (the top layer) is usually already lost by that point so it will just be a smooth spot on the door panel. Better than goo though.
2.2 HG orientation
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight. The Ej22 uses graphite layered gaskets. The gasket can only go one way because if you put it on wrong the hole for the oil feed won't line up with the port in the block. Does the "OY" look like this? Looking at the mating surface of the block, the oil feed is on your top left hand corner. Doesn't matter which side of the block you're on.
2.2 HG orientation
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should be a mark or lettering indicating which side goes toward the head or block. It will only go on one way. Symmetrical as it may look, the port for the oil feed galley in the block is where the copper ring on the gasket goes.
ej18 rod knock?
Fairtax4me replied to kc8apm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can have an oil analysis test done to see if there is high copper content in the oil that would indicate bearing wear.
Viscous Coupling Questions
Fairtax4me replied to Tmb9862's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAhh, you can cut that in half easy. Timing belt kit. Lots of folks here have used Mizumoauto for parts and have had good luck with them. http://cgi.ebay.com/ebaymotors/Timing-Belt-Kit-Water-Pump-Subaru-EJ18-EJ22-90-Feb-97-/220747435314?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru|Year%3A1996&hash=item3365928d32#ht_3721wt_835 Exedy clutch kit. Exedy/Daikin makes Subaru OE clutches. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270727015352&viewitem=#ht_2545wt_896 I can get you a center diff and ship it for well under $100. Or ask Nipper (he lives on LI) about where to find a good cheap junkyard to get one yourself.
Coolant bubbles
Fairtax4me replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bubbles are pressure being released. Either the cooling system has a large amount of air trapped in it, it is overheating and boiling, or there is cylinder compression being pushed into the system past the head gaskets. Bleed the system first. Park it with the front end uphill and run it to operating temp with the radiator cap off. If the radiator has the bleed plug on the top right side open it as well.
Fairtax4me replied to Tmb9862's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeat is the major killer of the VC. If your tires are not within 1/4" circumference of each other the VC is being worked constantly, which creates heat in the unit. If your tires don't match, buy 4 new ones and that may remedy the problem. It's not difficult to change and junkyard parts often work just fine. The VC/center differential unit is contained in a single housing. I'm not sure of other differences between years, but size-wise I'm pretty sure they are the same.
95 Impreza Smoking Issues
Fairtax4me replied to Tracon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's grease or oil that is either dripping or being blown onto the heat shield on the cat. Exhuast doesn't just come out of a pipe. There has to be a hole. If there's a hole in the cat big enough for you to see visual smoke, it's going to be so loud you'll think you're in a race car. Plus it will be blowing a massive cloud out the tail pipe. You won't get a little bit of smoke out of a small hole, and then not get smoke out of the big hole at the end of the pipe.
Embarrassed to even ask this.....
Fairtax4me replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as you used the notches, not the arrows, to time the cams you should be set.
Fairtax4me replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou know I've never bothered to see if the exhaust pulls any. When you set the crank did you use the notch on the reluctor tooth for timing? Did you have the cam sprockets off? You made sure the one with the notches on the back is on the drivers side head right? The notches are for the cam position sensor.
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've decided since both heads have to come off I'm going to put a set of Delta cams in. Just can't decide if I want the torque grind or the street grind. It isn't too happy going up the hills around here so I'm thinking it could use a little extra bottom end power. Anybody know which is better suited for an automagic? I'd still like to know exactly which side is leaking so I'm going to try a few more things to see if I can figure it out, but I'm thinking I'll just do both sides anyway.
