violent shaking stall - 5 trouble codes
Fairtax4me replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe if they drove it that way for miles at a time. Sounds like the belt jumped and the car died within a few seconds. Not enough time for the ECU to run the fault diagnosis for the P0420. A current P0420 can not be set without the car being driven. The code must be old.
Fairtax4me replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuessing this is a 2.2? If the timing belt jumped there's a good chance it has valve damage. P0420 and P0325 are both common codes on these. You can search the board here and come up with plenty of threads on how to fix them.
96 OB Transmission Problem
Fairtax4me replied to TOsborn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry going back to a conventional 80/90 gear oil. Synthetic fluids are thinner and tend to be more slippery which doesn't help the synchros. Standard 80/90 conventional gear oil will not be as thin at operating temp as the synthetic.
Cam Slipped , What to Do?
Fairtax4me replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut a wrench on it and turn it back to it's proper position.
New wheels for my Cutie Car!
Fairtax4me replied to 98ImprezaWA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXContinental makes very good performance tires. But like any other performance oriented brand, they don't wear long. You'll probably be lucky to get 20k out of them driven aggressively.
Friend with 96 Legacy L problem on hills
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo they sell turbo muffler bearings too? I need about a half dozen of those. And some blinker fluid refills.
07 2.5i wagon, bad brake switch and "OIL AT TEMP" light flashing
Fairtax4me replied to kero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXE: DTC P0719 BRAKE SWITCH CIRCUIT LOW DTC DETECTING CONDITION: Brake switch malfunction, open input signal circuit TROUBLE SYMPTOM: Gear is not shifted down when driving a down hill. 08 FSM was the closest I could find, but that's Subaru's definition for P0719. Anyway, short answer is the TCU relies on input from the brake switch to determine when to downshift. An erratic signal or no signal can confuse the TCU, it recognizes there is a problem and illuminates the AT OIL TEMP light as a signal that something is wrong. The BCM (Body control module) reads the signal from the brake switch is erratic, stores the code and illuminates the MIL.
Rear Axle Removal 98 OBW
Fairtax4me replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA big brass hammer can help keep the end of the axle in usable shape. Hold the brass hammer against the axle and pound on it with a mini sledge.
Broken steering gear boot
Fairtax4me replied to dromond's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe other scenario is the boot cracked and fell apart from age, allowing rocks/dirt and other debris to get stuck to the rack which will then get pulled into the housing when you turn. It drags the dirt in along with it which destroys the seal. Low steering fluid will make a whining sound when turning. A bad differential will whine at speed (50mph or more in most cases) and change pitch, or disappear entirely, depending on load. A leaking rack will not stop leaking. Swap it with a junkyard rack and put new boots and tie rods on it then you won't have to mess with it for a long time.
Hmm what's out of alignment?
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThree's a crease in your upper radiator support beam. Might not account for all of that but it needs to be pulled back out about 1/2" probably.
1997 Subaru legacy out back overdrive not working?
Outback also has 4.11 final drive ratio which raises rpm over the base model Legacy which generally has 3.90 FDR. I don't know whats in my 95 AT wagon, it runs 2750ish at 70mph. My 96 MT sedan turns 3000 at 70.
Steering rack bushings
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust put the Whitelines on my Wagon. I don't feel any difference in NVH, and the car tracks perfectly straight now. Plus the polyurethane won't deteriorate because of oil. I got them from "fast-imports" on Ebay for $37ish shipped priority mail.
3rd gen Legacy hood adjustment?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo the hinges bolt to the top of the fenders?
impreza rs curbed repair
Fairtax4me replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may have just shifted the cross member or bent the bolts. If the bolts are bent you'll have a ton of fun getting them out.
Sti
Fairtax4me replied to koolaidman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXX2 on bad turbo. Pull the intake tube off and I bet you can wobble the compressor wheel around like a joystick.
In The Middle Of A T Belt Change
Fairtax4me replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe screw driver method works fine. I used a 1/4" allen key on mine. Just don't forget that it's in the bellhousing. It'll get bent when you try to start the engine. Put a breaker bar on the crank bolt and turn it until it's at TDC. Stick your screw driver or allen key into the hole it eh bell housing, and while pushing inward, rotate the crank in either direction a few degrees. You'll feel the tool skip then pop into one of the holes in the flex plate. Then the crank will not be able to turn in either direction.
96 impreza outback noises HALP
Fairtax4me replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere should not be so much slop that it makes crunchy and grinding noises. There are 8 or 9 bolts that hold the tail housing section on, and you have to remove the linkage for the shifter. Then there are two alignment dowels that can be knocked out with a punch and the tail housing section will pull off. The paper gasket will hold it somewhat so you may need to tap it with a mallet to get it loose. You can see the dowels in this pic. One at the top and one at the bottom. The transmission is laying on it's right side in the pic. The transmission output shaft (the long one) and the center differential have to be pulled out together. They will come out by hand with a bit of wiggling.
Rear Vibration
Fairtax4me replied to JamieSueLue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like it's dependent on speed. Try getting the wheels balanced.
surging while going down the road?
Fairtax4me replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny recent work done? Plugs, wires, filters, PCV, when were they done last? Check engine light on? If not, does it work during the bulb test?
SPFI Coolant thermosensor location and resistance chart
Hey does anybody have links for the info in the first post? The links are broken.
Can I drive with the AC compressor removed?
Fairtax4me replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust add a can of refrigerant with oil when refilling them system. Or you can pour about an ounce of the oil called for on the AC service information sticker under the hood directly into the low pressure side port, then spin the compressor hub a few times by hand to cycle the oil through the compressor.
Fairtax4me replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless they drained it, a junkyard compressor will already have oil in it. Just don't flip it over and let any spill out through the hose ports.
Radiators: junkyard vs aftermarket
Fairtax4me replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXX2 You can often find good radiators in junkyards, but should should know what to look for that may indicate a problem. You take the same gamble as with any other junkyard part.
Fairtax4me replied to bstone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeen driving my sedan for almost a month with no AC belt. Do seal up the ends of the hoses though. What was so hard about removing the compressor? Just remove the 4 long bolts from the side and it lifts straight up.
Fairtax4me replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWarranty? Should have said that before. Take the damn thing back can tell them it's messed up. No reason to take it apart if you can get another one for free.
