136
	Should have the latter half at least of a VIN stamped on it somewhere. Lower bell housing I think, passenger side? (not 100% so don't quote me). Engine size stamp is on the top of the block behind the alternator. Pretty easy to see. Old style tensioner could have been swapped. Betting the whole engine was swapped after the timing belt went and bent all the valves.
				Flywheel
Fairtax4me replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
A new OE Subaru flywheel from an online dealer runs about $230. If your local dealer will match online pricing (many will in order to get your business) you can probably get it for that or very close. If not, it'll be ~$325. Not what he asked, but Rockauto does carry some good parts. Shipping is a bear, but you can get many parts that a local chain store often doesn't have or even carry, and some of the same parts for quite a bit less $$. Of the flywheels offered by Rockauto, AC Delco is overpriced but generally high quality. Sachs makes OE suspension and clutch parts for many European makers. Sachs parts are good quality. The rest, I have no clue. -
	There was a change in the linkage, no real change in the trans itself. Not real sure of the difference between sensors, could be the difference between automatic and manual trans. Either way, on the manual trans it's on the passenger side of the trans near the dipstick. You should be able to see it from above with little trouble.
				just got a new scooby :) lots of pics
Fairtax4me replied to Meeky Moose's topic in Meet n' Greet. Your USMB Welcome Center
You sure that's not 9779.2 miles?! That car is pristine! Good find. -
				So I'm a bit of a stalker...
Fairtax4me replied to 98ImprezaWA's topic in Meet n' Greet. Your USMB Welcome Center
Can white girls even get weaves? -
	I'd get one that's made for an Ej22. They may be the same in appearance and fitment but the weight or balance may be slightly different. This can cause internal issues. The harmonic balancer is designed to absorb crankshaft vibrations caused by the various sources of movement associated with the engine. Changing the way the crank is balanced and weighted can amplify some of those vibrations and cause bearing damage, cracks due to metal fatigue, and overall excessive wear of the internals. Best to stick with the right part.
Hide ya kids, hide ya wife, and hide ya Soobs cuz they stalkin errybody round he'ah! -
	About 3 and a half hours? :-p The belt is squealing because it is slipping over the pulley rather than turning it. The voltage reads low because the alternator is not turning as fast as it should. In this case I would replace the belt, clean the pulleys with a wire brush and brake cleaner, and install a new belt set at the proper tension.
	TheImportExperts can put together a kit of OE brand timing parts for about 1/2 the cost that a Subaru dealer would charge, even the online places. Just have to give them a call. They do not, as far as I can tell at least, carry the OE brand water pump. You should be able to get a Subaru pump from one of the online dealers for around $65-70 + shipping. Unless the crank pulley has failed (the two sections are separated), there is no real reason to replace it. Save the money.
				Flywheel
Resurfacing should be around $40-60, and will work just fine. Some people don't even bother to resurface them. -
	MMO is mostly a cleaner. Run it for 50 -100 miles or so and change the oil. MMO thins out the oil, and can clog the oil filter with dirt and particulate that it disolves and breaks loose from the crankcase. If enough crud gets in the filter oil will simply "go around" the filter media by way of the bypass valve in the filter. Then you get unfiltered oil running rampant through your engine. Never heard of adding it to the gas tank. I use Seafoam for that.
	Welcome! Your English is better than some Americans. You spelling of some words isn't quite right, but it's good enough that we can tell what you're saying. Post some pics of your Brat!
Only a girl could claim to be a stalker and get a positive response.
