97 legacy gt wagon stuck in awd
Fairtax4me replied to derfster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReply #7. I can't blame the OP if he/she did not see it though, as we have cluttered the thread up quite a bit with off topic BS.
Slammed a curb... help me out guys
Fairtax4me replied to daredevil1166's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice tires. How does that thing ride with no rear sway bar? Ship at sea? That's a lateral link.
97 legacy 2.2 ?
Fairtax4me replied to jazzmandolin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom what I understand, all the wires are there, You just have to put the components in for the options you want. Stuff like that is easy to come across in a junkyard. I take it you want the non-interference 2.2?
curbs, a car worst enemy!
Fairtax4me replied to G-money22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPB Blaster... lots of it. And "the hot wrench". Those bolts are famous... or infamous... for causing problems getting the rear knuckle removed from the car. If you have to, cut the ends off and hammer it out.
Code P2096 Now what?
Fairtax4me replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy computer is getting ready to go on a ski trip through the back yard via window pane airlines. It locked 3 times trying to open the 05 FSM I have. Anyway... This is Subaru's definition for this code... DTC P2096 POST CATALYST FUEL TRIM SYSTEM TOO LEAN BANK 1 DTC DETECTING CONDITION: • Two consecutive driving cycles with fault That was about all I got to read before the computer locked up. It just doesn't like acrobat anymore I guess. I think it's about time to wipe this thing out and start over.
Fairtax4me replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm... That probably means the after cat sensors also adjust fuel trim and are not solely for checking efficiency of the cats. You might actually have to fix this one the "right" way. The P at the end of the second one probably means it's a "Pending" code. Which according to Innova means: Try unhooking the battery - for a half hour to reset the ECU and see if it comes back.
Oil pump O ring
Fairtax4me replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReally doesn't matter with anaerobic sealer. I took the front seal plate off a transmission to change the input seal before I put it in my truck over the summer. It had been sealed by the factory with anaerobic sealer, back in 1984. The sealer that got squeezed inside was still liquid and very pliable, not much different (other than little darker color) than the new sealer I used to seal it back up with. This was an area mostly closed off from the rest of the transmission. It did have a hole at the bottom for oil to flow out from the bearings, so it was exposed to gear oil the whole time. But it was in there for 26 years and didn't dry.
Headgasket?
Fairtax4me replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWoah woah... just a little TMI there... I mean whatever floats your boat, but we don't need to know about it too. Jk, I know what you meant to type. :-p Sure it's not leaking further back under the bellhousing? A separator plate or rear main seal leak will drip right on the Y pipe under the bellhousing and won't show up very easily. You have to crawl way back there and look close to see it well.
97 legacy 2.2 ?
Fairtax4me replied to jazzmandolin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou were looking for an early 90's wagon right? http://charlottesville.craigslist.org/cto/2155079741.html
Brake Booster problem?
Fairtax4me replied to fastrat37's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my old Ranger, the brake booster would freeze in cold weather. I figured out why when I finally took it off to replace it. It had a hole rusted in one of the top corners, and had a half cup or so of rusty water in it. Once the engine warmed, and the water melted, it worked fine.
Grandma Hits Pillar-Besides VC,how much can be damaged?
Fairtax4me replied to cmasonwhf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuys I don't see where the OP ever said the AT temp light was flashing. Or any other light for that matter.
Need stereo head unit advice
Fairtax4me replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru sells aux input adapters for their newer cd players. You might try calling one of our Subaru dealer vendors (who seem to be much more knowledgeable than most dealers) and see about the cost and compatibility of one of these is for your car.
Fairtax4me replied to cmasonwhf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe AWD system in the automatic will cause some minor "drag" around corners even when the car is brand new and working properly. Most people don't ever notice it, but you can tell it's there if you really pay attention. Crash damage was to the front corner, it's a pretty good chance the half axle was damaged, especially with other suspension damage. I would be pretty pissed about them critter-footing around like this, replacing parts that don't need it. That is adding significant cost to the claim, which ultimately ends up coming out of your (or your grandmothers) pocket, when they raise the rate on the next premium.
Possible Auto Trans issue on a 2002 Legacy GT
Fairtax4me replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA tuneup may be a good start. I've seen plenty of hard shifting problems turn out to be engine related, when people were convinced it was a transmission problem. Start with simple stuff. An air filter can do wonders if it hasn't been changed recently. Not sure if the P/O ever had the spark plugs changed. If not, a new set of OE Subaru or NGK plug wires to go with NGK plugs should do some good. You probably know what all else to do so I won't preach about what to change on a tune-up, but plugs and wires these cars seem to be very picky about. Before you change the plugs, try running a half bottle of Seafoam in the intake to clean it out. This has a tendency to foul the plugs if the intake is really gunked up. But if you're changing plugs anyway it's the the perfect time for an intake cleaning. Dump the other half bottle in the fuel tank on top of about 1/4 - 1/2 tank of gas to act as a fuel system cleaner. Also be sure to check under the hood for any loose/split vacuum hoses. Make sure the intake ductwork is clamped tight where it's supposed to be. All of the breather hoses are tight and where they should be.
How much oil consumption could a bad PCV valve cause?
Fairtax4me replied to Ross's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomething doesn't seem right, there will be some oil in the PCV hose, but the PCV valve is supposed to stop it from entering the intake. So either the PCV valve is not working properly, or there is something causing a LOT of oil to be pushed up into the separator, more than it can handle, and it is being sucked up into the PCV hose. Excessive blow-by is the primary cause of this. Check the routing of your breather hoses. Make sure they are all free of obstruction, not kinked, and connected tight where they should be. There is a small hose that leads off the PCV hose connector. I don't know where it goes to but make sure it is clear as well.
Rear drum removal
Fairtax4me replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf these are drum brakes (not parking brake) you might need to loosen the self adjusters before the drum will clear the shoes.
Fairtax4me replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the car feel like it's short on power at all? Idle low, or feel a little sluggish off the line?
'99 Subaru Legacy Outback, Overheating problem caused by repair shop.
Fairtax4me replied to jporter313's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAsk them to pay for a Subaru dealer or independent Subaru shop to install a used or rebuilt engine. Again a dealer or independent Subaru shop should be the most knowledgeable here. They can more than likely track down the source of the power steering problem as well. Is there a problem with the transmission now? I know you said they replaced a seal.
EJ non-turbo burned exhaust valves - consensus?
I would have to wonder about the knock sensor, and O2 sensor on that engine as well. To melt that many valves, sounds like an engine-control issue. How often do multiple fuel injectors "fail" simultaneously?
EJ2.5SOHC Oil Leak...on top???
Fairtax4me replied to citabrickr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOil pressure sensor. That's right between the alternator and power steering pump. But if the wetness is starting at the head gaskets, I would have to think the gaskets didn't seal properly for some reason. But the odds of that happening on both heads? Probably very low. Do a very through cleaning and careful examination. Are you sure it's not power steering fluid?
Fairtax4me replied to derfster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXApparently the wheel bearings (front and rear) are preloaded when the axle nuts are tightened. So leaving the rear outer cv axle housings in place would keep the preload on the bearings. Go on a diet.
2.5 dohc the engine I love to hate and love again
Imagine that! [/sarcasm] I've heard that you should use sealer on head gaskets for cast iron head and block engines. I've only done one HG job on a cast iron block and head engine though. Didn't use any sealer, and it worked out fine. At least until it went to the junkyard. Never use sealer on aluminum heads though.
Auto Tranny Help
Fairtax4me replied to markjw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI always check trans fluid on a perfectly clean white rag, and I dip the stick 3 or 4 times to get a good idea of the color of the fluid on the rag. If it's not clean clear red, it gets changed. It does look a bit dark in the pic you posted of the dipstick. The darkness in the drained fluid is probably mostly clutch material. You'll find out if it worked in 1000 miles or so. If it doesn't quit altogether, it's probably OK.
Fairtax4me replied to derfster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo extra weight or drag if you remove the rear diff and half axles as well. Did you have this problem before the swap? Did you put a jack under the transmission pan during the engine install?
Auto Tranny Help
Fairtax4me replied to markjw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$10 Bottle of TransX might help. Either way you get to spend money on it. You don't have to do a full flush though, a quick drain and refill will likely be enough to see if there is any noticeable difference.
