136
ECU may need a reset. Did you mess with the solenoid on top of the valve any? Maybe try removing the solenoid and make sure the valve moves easily. (just flip it back and forth with your fingers, should be smooth as butter) Be sure to mark it's position so it can be installed back in the same place. Did you disconnect any vacuum hoses when you did the cleaning? Double check that they are connected tightly and aren't split.
Not sure what relays there may be under the dash on the passenger side. Those should all be on the drivers side. Have you pulled the kick panels off to see what all is under there as far as wiring is concerned? Someone on here has a FSM for the 92 model year on his website. I can't remember who it was but I'll look for it and post a link for you when I find it. Found it. Courtesy of Log1call. The file is 1992_legacy_full http://cid-4ca3c3459aaa7f7f.skydrive.live.com/browse.aspx/.Public
Car has been doing this off and on since I got it. But now it has gone from doing it once and a while to doing it every day, to now doing it every time I push the pedal. It's coming from the engine compartment, I believe from the pivot inside the bell housing. Is it possible to make enough room to get in there and get some grease on the pivot ball without separating the engine/ trans?
Maintenance kinda depends on what you've done to it and when. The timing belt should have been done at 100k. That's the biggest concern with the 2.5, next would be the head gaskets. If they've been done then you shouldn't have to worry about much beyond regular fluid (motor, trans, rear diff, antifreeze, brake) and filter changes. It's a good idea to throw a power steering fluid flush in there every now and then too. Top speed, not real sure. Most cars are limited to around 120-130mph range. Best fuel efficiency is gonna be under 3000 rpm in 5th gear.
Swapping the knuckle is pretty easy. Disconnect the brake line and hose, remove all brake components. Loosen and remove the axle nut, then drive the axle out. Pop loose the ball joint and tie rod end. Then remove the two large bolts that hold the knuckle to the strut. The axle won't come out all the way until you get the ball joint loose from the control arm, or separate the knuckle from the strut. You may want a ball joint separator, to get the ball joint and tie rod end loose, but it's not 100% necessary. You can loosen the castle nut to the end of the stud and then wail on it with a hammer to knock it loose. A pic for reference...
That sounds like worn brake pads and a loose tie rod end or lower ball joint. I see no reason to replace brake calipers unless they are leaking (around the piston) or the slide pins are completely rusted into the caliper and they can't be removed. Most of the time a new pads will suffice, and put some new grease on the slide pins. But if the slide pins are stuck, they need to be removed and either cleaned and lubricated (high temp grease) or replaced. The rotors may be grooved. You can have a machine shop turn them for a small fee, but they're only like $25 for brand new ones. You should just go ahead and replace them. All this can be done easily by the DIY mechanic with basic tools. It always helps if you can find a friend who knows more about it and get him/her to help. The ball joints are pretty easy to replace actually. (or at least should be) But you'll probably need a ball joint separator. They're $10 or so at most parts places. A split steering rack boot is fairly easy to replace, but the inner rod end may be loose if it has been exposed for any length of time. That is also easily replaceable, but requires an alignment afterwards. If you're gonna replace the boot, you might as well get the rod too. The wheel bearing is the hard part, and the easiest way is with a used knuckle, but I'm not sure you need one. You can do a few basic tests to detect play or wear in a wheel bearing. Searching the forums here should yield a few threads detailing the procedure.
Brake job on an ABS equipped vehicle is no different than any other vehicle. Unless the backing plates have holes rusted through them don't worry about them. They're not worth replacing unless they're literally falling off. Not worth paying dealer prices for new ones either. If you're hell bent on replacing them just get some from a junkyard that look decent. Might cost you $10 for all 4.
