Everything posted by john40iowa
front end noise?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe car went to the good shop today and we got the answer. It confounded the mechanic, who thought it was the strut tower; a closer look revealed it be an issue with the hood. Apparently it was loose and had be tightened a bit... go figure.
HG oil Weep?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for pointing this out, as it is very valid. The car is '99 Forester, with the 2.5 SOHC (200K). Good condition and daily driver. No, I don't want to make things worse and can wait it out, there is no problem here in terms of urgency. It has actually been a very reliable car and owes me nothing. Gaskets who knows- 2004, I suspect inferior.
HG oil Weep?
After now about 70K on the rebuild, I am noticing a little oil weep on the drivers side rear of the engine, about a year or so. It does not get any worse, nor enough to effect the oil level much between changes. However, I was wondering if any ya all have heard of stop leak helping with this issue? Or maybe switching from the synthetic to Dino would help. I am not talking about the coolant goop, which has been added religiously with every change, and that system is fine. Thanks for any insight.
Replace or rebuild advice
john40iowa replied to methusalah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the timing broke, it is likely it was never changed. What other deferred maintenance was not done? The bottom end of the end of the engine could also be so so or worse. Sounds like a really good deal if the rest of the car is solid.
vacuum Line ?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think your correct, which would be 4mm. Worth a shot, and ordered on Ebay- they have a nice selection.
vacuum Line ?
Today I was replacing the vacuum hoses on the intake. I discovered there are two different sizes not counting the brake booster. I did the 1/8 I.D. (3mm) The remaining lines are little bigger and more robust. Does anyone know this size for these? Thanks for any pointers! '99 2.5 SOHC
Glove Box Disaster
john40iowa replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't know about alternatives for repair, but might consider the junk yard. They are not heavy duty, but most cars today are made like this.
Good BRZ Review
I am probably in the minority (Yea its quieter, and safer all that), but I like the frame less windows. There is just something cool about grabbing a door top with the window down.
front end noise?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't Know if it is a factor, but discovered the tires were all overfilled; the fronts have something near #40psi. No I didn't do it, I know they are supposed to be in the neighborhood of 28-32 psi from the door panel.
front end noise?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is good advice. Looked at the end links and they are fine. I need to remove the undercover and really take a good look at things. Thanks!
front end noise?
'99 Forester A few weeks back a pedestrian and dog were in the middle of the road, strange since two perfectly good side walks were open. Anyhow on this road I had to take the shoulder area which was rather pot holed. Didn't appear all that extreme, but noticed there after a kinda of "Clunky sound" from the front end anytime a bump is crossed. I thought it might be the undercover, so I put new clips in that hold it on. No change:( The kyb struts have 50k and look fine as do the original springs. It was aligned about 5 months ago by a very good shop. It tracks and runs fine, and stops smoothly. Just this annoying plastic rattle trap sound at each bump, for lack of a better description. Any thoughts of the culprit here would be greatly appreciated.
new tires
john40iowa replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't know if it is a factor; any tires with this aggressive of a tread pattern will be somewhat noisy.
Three months under water...no problem!
john40iowa replied to Deener's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are a great car, but not indomitable. Sure, for a dune buggy it might run mold and all. Otherwise, I would not want to count on any car submerged under water. Just My 2
Imprezza Review 2012
john40iowa replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis that really a plastic intake on the engine? Not to impressed with these on other engines......The interior is really sweet, though.
Belt replacement ?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor clarity The timing belt is not due yet. That is way beyond my expertise and time available. Gladly we pay a good shop to perform the 100K service; I ordered a brand new tensioner and long bolt. Thanks for the sound advise, this will be followed.
Belt replacement ?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. With 200 K and irritating squeak the tensioner is going as well 2.5 sohc
Belt replacement ?
Sorry to ask a dumb question. It has been something like 25 years since I have replaced an accessory belt; next week I will replace them and the Tensioner as well. To save unnecessary steps, with the tensioner loose do I still need to loosen the alternator? Not lazy, but don't want to "Make work" either. Thanks in advance!
Vacuum Hose search ?
john40iowa replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks everyone, Now I have something to work with.
Just for general purposes I am going to replace all the intake vacuum lines on my 2.5. It is a little confusing trying determine the amount and what to order from those online. Any pointers as where and what to search for? Thanks!
Is this a good deal? 2008 subaru wrx, 40k miles for $17,500
john40iowa replied to krnsamiam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree totally. Obviously, you could take this a piece at a time- Tires now, brakes a little later. This would not scare me away at all from a rust free California car.
Forester starts, then drops rpm... stalls
john40iowa replied to murpheeee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis might work in your favor in terms of getting a better deal. I would bet it is something relatively simple.
atf quickie
john40iowa replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe previous responder is bang on. My job gave us a brand new '04 Town Country. What a joke, the tranny went out at 70K, and three years later. We took care of that van.
john40iowa replied to krnsamiam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you really want this car, I wouldn't let five hundred sway your decision. I would go with the first one over the second one "Modified, but restored to stock intake/exhaust." 40 K is a baby to me, obviously in the proper hands. To me both these these cars you listed are basically the same in terms of value and mileage. Good luck regardless. my two...
How hard to change plugs on 06 Forester?
john40iowa replied to mattri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou also might put a little tape over the extension end (another wards cramming into the socket until is joined firmly to the wrench) before starting. Several times I have the extension and socket remain deep in the engine as I pulled out the tool:(
seat opinions needed
john40iowa replied to kona's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI vote for Cloth. My friend has the '00 Outback. The cloth seats are supportive even on long trips, and after 200K still look newish. What little I seen of Subaru leather has not impressed me in anyway. The cloth on my Forester's after 13 years on the road, are just now showing the beginning signs of love. Just my two
