Everything posted by 987687
so really, how complicated is it to wire an ej swap???
^^ good thoughts. I'd probably also leave the engine in the car until all the wiring is cut. Then plug the cut wiring harness into the engine to see if it runs. Is that silly, or a good idea from those who have done it?
Engine only harness - VSS Simulator
If my '96 legacy doesn't have a VSS signal the ECU goes into limp mode and won't let me rev the engine over 3.5k or something and retards the timing making it painful to drive... Not sure if the newer ones do that too...
eating alternators
987687 replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you unplug the connector on the back of the alt you can be sure there's no electrical load. If you spin the alt by hand (no belt on it), do the bearings make bad noises?
eating alternators
987687 replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you still have AC and the AC belt? Because that does have a tensioner/idler, but the alt doesn't. It's the crank, alt, and PS on that belt. Start the car with the alt/PS belt off and see if the noise stops. If it does, it's probably the alt. If it doesn't stop then you have a whole other problem going on.
Pushbutton Start (How To)
I'm really tempted be all the talk on here about it...
1991 Legacy
987687 replied to 92_rugby_subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe EZ36
What kind of muffler ???
987687 replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe could be cool and just keep it quiet I got my legacy when I was 18 and didn't want any loud exhaust on it ... And just recently spent quite a bit of time welding the muffler back on and fixing all the leaks so it's quiet again.
eating alternators
987687 replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't get much from auto parts chains besides little things. Fasteners, brake lines, basic tools, paint, etc. I don't usually get things that have very many moving parts because they generally suck. Unless they're a name brand part, in which case buying it at napa is stupid because it'll be 20% or more over what you pay buying it online or whatever.
Caliper question
987687 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a good thread over on nasioc about what brakes fit on what cars. etc. Take a look here and see if they're the same. They probably are. http://forums.nasioc.com/forums/showpost.php?p=18085854&postcount=1
eating alternators
987687 replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust get a subaru alt from a junk yard. You can probably get one cheap and they don't have many issues. Mostly brushes, cheap and easy to replace or have a shop replace. Return the napa alt again. I've had to return the same thing to napa a few times before because it kept being dead when I got it. I got an axle replacement that started clicking 3 days later. It still clicks months later .... heh. I'm not very amused though.
I did a push button start on my GL a while back. It worked great, but I never installed it due to a free key switch... But I had 2 toggles. One to turn the car and acc on, and one to turn on just acc. Then it had a few relays. All power went through relays, not switches. Safer that way. It was fused, and had a relay so while I was pushing the start button it turned off acc just like when you turn the key to start. Cool you installed yours though! My system has just been scrapped for parts :/
Who Actually Made their Bumper or Bumpers??!!
I've got those exact same tires! http://www.myspace.com/sandman660/photos/58459956
Lots of us have. It isn't to hard. Look here for some examples. http://www.ultimatesubaru.org/forum/showthread.php?t=113276
should i sell?
If it was me I'd fix it and maybe sell it, but for a lot more. I can do a wheel bearing and exhaust pretty easy, so just engine work I'd have to spend some time with. Depends if you can do the work yourself. If you can't do all the work yourself, probably your best bet is sell it. Good deal for both of you. If you can do the work, fix 'er up! She'll be worth much more.
Difference between 95 and 96 legacy.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^ good analogy. And all the 89 to 94 legacys didn't have auto belts, did they?
When I do mine I'm gonna get the whole car. I'll get one that has usable parts for my legacy too.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, 95 it started. My GL had the auto seatbelts. They worked awesome too. No grinding, ran nice and smooth and never had a hitch. The only problem with them is that I absolutely loathe auto belts. So I swapped in manual ones. Want to buy some perfect condition auto belts with the auto belt computer? haha
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I want to, or can wait for a part I'll usually get it online. But I'm sick of not having my legacy, or having it with a horrible exhaust leak so it was worth spending an extra $5 and just getting the correct part.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSitting at the dealer getting my seatbelts fixed under lifetime warranty. Got the correct gasket! Woo, $10 with my discount, so not bad. It was like $18 without.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGetting parts from a dealer is nice if you want to pay. But I don't have a dealer very close. The closest one is about 40 minutes, and I won't go there anymore. So the next closest one is about an hour 15. But I get a 15% discount from them... so sometimes it's worth it.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the reassurance grossgary. I was kind of in a bad mood because I'd probably driven 50 miles going back and forth to napa trying to get the right part, and it still doesn't work right. The gasket is to short so it leaks, whatever, it'll get me to the dealer. It's just frustrating trying to get something done and not being able to find the correct parts to do it. And I'm glad I'm not the only one that has issues getting the right parts with brakes, exhaust, etc. This is what you get for working on your own vehicle, you're not paying someone else to spend time getting the correct bits and making it all work. I'm just glad the part of the pipe I welded up doesn't leak at all I try not to ask a million questions because I like to figure things out for myself. Or I'm in the middle of a project and just want it to be done so I don't want to wait for an answer... I can be kinda impatient sometimes. Anyway, thanks for all the replies.
rear spoiler for an EA81...anyone ever try one of these?
The only problem is that it makes the lid heavier and apt to close on your head while you're rummaging around looking for something
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info. The napa book does have different sizes listed for 95 vs 96 exhaust gaskets. 1.75" vs 2". And mine has 1.75 doughnut. The one they sold me isn't tall enough so it still leaks. Grr, but I'll be at the dealer today so hopefully they can get me the correct part. I need to pass inspection this month ... I have no idea what's up with the rear O2, it looks like the bung for it is plugged up with a bolt in the cat. Maybe someone put in a resistor? dunno.
So I've been having a hard time lately getting parts that fit my 96 legacy. I've had break parts not fit, only to order parts from a 95 that fit. Some of the wiring from the 96 manual doesn't match up, but it does from a 95. It doesn't have a second O2 censor. Yet I've got a code for it once, but it never came back for the last year and a half. And most recently the first doughnut gasket in the system I got from napa doesn't fit. It's a 2" gasket meant for the 96. Out of frustration I asked for the gasket from a 95 which is 1 3/4" and fits except that it's a little to short. So what's going on? Is my car a 95 that was re-branded 96? Did someone have a complete 95 parts car they swapped a lot of stuff from? Are the early 96s made in october 95 essentially a 95 branded as a 96? I'm starting to get really pissed off making tons of trips to napa because the parts that are supposed to fit my car don't.
I use those waterproof shrinktube connectors in boats all the time. They work amazingly well! They can be submerged in salt water forever and nothing ever happens to them. I've never had an issue with them. As for soldering, I use high grade lead-based electronics solder and the correct flux. I make very nice solder joints, and I've never had a problem with that either. I haven't done much with car wiring yet, but TONS and TONS with boats. And on boats you see just about as adverse conditions that you see on a car. As for EJ swapping, I have it in the future of my GL. Why doesn't anyone ever build the wiring harness from the engine to the computer from scratch? Is that worse than pulling a harness and stripping it?
