brysawn
Everything posted by brysawn
Are you planning on running a larger tire?
Thanks! I can't wait to get in a D/R and go wheeling. That must have been around 6ish (going to the sounders game)
WCSS - New Users?
brysawn replied to 92_rugby_subie's topic in Meet n' Greet. Your USMB Welcome Center
I'll be there. I'm not registered for the show, but I'm thinking about it -
I'm not sure if it would be my 6 lug, although a couple of my studs may be crooked, the wheel is still bolting to the hub flat, centered, and tight. I changed around my tires to see if they were balanced differently, but same issue. All my suspension is tightened properly, and nothing is loose. So maybe I'll have my tires checked.
New Webpage for my car...
brysawn replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wow, that wagon is packin' heat -
The car is a '94 Loyale. Up until the time I put my new tires and wheels on my car, it has had no alignment or shaking issues. Even when my car had the 2" lift with stock wheels/tires it drove straight, and didn't shake at any speeds. But when I put my 27's and did my 6-lug conversion, it now shakes pretty badly after 40mph. My tires were mounted and balanced at Les Schwab at the same time, and all the beads look good, they hold air, so I'm not really sure what it is. Could it be misbalanced tires? I didn't think it was my suspension, because before the big tires, everything was fine (I really don't think making my hubs 6 lug affected this) My car still steers straight and everything. Just gets terrible shakes.
One of mine is ripped and clicking
By "look" I mean a thorough inspection. I thought something should be bent, or shifted while driving, so I put it on the lift and poked around. My lift blocks are still in the correct position, my tie rods aren't bent, my ball joints are in the right spot and functioning correctly, and my strut "looks" okay (it's tough to see if its bent with it being in the car). Everything is solid, no knocking, or odd noises, and my tires are all balanced, so I'm not sure why I'm getting the shake after 40mph
Yeah all my tires are balanced, by the same place, at the same time. So I figured it was an alignment issue. No bent struts, tie rods and ball joints all look good too.
Well I would love some help with mine than. My lift blocks are cut and installed as they should be, but I still get the steering wheel death shake over 40 mph
they all have camber problems
Finally "finished". 1994 Loyale, S/R 4wd 2" homemade lift 6-lug hubs using toyota studs toyota 4runner sr5 wheels homemade rack General grabber at2 in 205/75/15 all done by myself
It rubs in the rear, so I have some more trimming. But I've been driving it a little. So here's the finished (almost) project: Thanks a lot 3eyedwagon for helping me out and answering my many many lift questions
Yeah, that's what happened. The drivers side rear, is a bit crooked. I'm not too concerned now, but it'll be changed soon. Also, my rear wheels aren't centered. They are really close to the door
Right now I only have one 6-lug hub. So here's my car with the 2" lift, and one of my wheels/tires on. It needs some cutting, I'm not really sure how to go at that
If my car was 4x100, I could run so many of my cool wheels.
I was so excited to go to this! But no D/R
You would use 1"x1"x 3/8" (some use 1/2" but it doesn't need to be that thick) square steel tubing. Two of the blocks are cut at 15* with the holes centered, and the other block is square with the holes cut at 15*. All pieces are an inch wide
Oh thank you, that's good to know. I like the at2's because of the size they come in. If I were to get a 215/75, I would just go for a mud tire
The spring was never removed from the strut, just the entire strut from the car
I got my lift finished up and installed, but my car sits crooked now. My passenger side is 1" higher than the drivers. I'm not really sure why. My rear struts (when out of the car) were within 1/8" of each other, as were the fronts. I don't understand
Grinding noise when turning
brysawn replied to brysawn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Naw, it wasn't that. Any other ideas? -
Yeah, Mount Vernon is pretty far. I welded mine today, and I used the perfect fitting pipe, and cut the eyelet off without even touching the strut. But it's a little bit crooked (it's tough to keep it lined up by myself, especially for my first time), not enough to where anything will happen, but it still bothers me. There are no holes, or burns in the struts themselves, and I tried to keep them cool, but monitoring the temperature is a bit tough with an arc welder. The rubber bushings did melt a little, but I have it on the car and it seems alright, there is no way these welds are going to break
that's a little far
