3
Everything posted by logic23
The tail section and solenoid were both used. Both old and new display same symptoms: working sometimes with no pattern to when it stops working. The strange part is that the FWD light doesn't always come on. IF its not getting a signal from duty C solenoid will the light still come on? I'm guessing the fuse and the light are both connected to the trans computer and teh computer turns the light on and off. Customer is driving the car now with the FWD fuse in letting me know the conditions when it is on/off. I plan to pull the code next week. It still seems like a bad connection somewhere. bad computer.
Ok heres the update: I put the FWD fuse in and no light on the dash. I drove the car for a day or so and it came on at some point. When the light came on I took the fuse out and continued my drive in AWD...NO torque bind. continued to drive with no problem for the the next day or so. Then the torque bind/ flashing AT light came back. put FWD fuse in and no light on dash. Any thoughts? sounds like a loose connection or bad wire.
OK folk lets see if any one has dealt with this problem. I have a 97 OBW in my shop that has a supposed rebuilt transmission. When the car came in it had a slight torque bind problem. The a/t light also flashed as soon as you started the car then turned off after several flashes. I assumed the normal solenoid problem so I replaced the whole tail housing with a used one (dont know if it was good). Got it all put together and started the car: No light and no apparent bind. Drove for 20 min and started to notice a slight bind on real tight turns. Turned car off and restarted and the light flashed 16 times then went off. So the question is does the 16 flashes mean anything? Has anyone seen this problem when the car heats up? Any thoughts? Thanks y'all.
OK I have a 2.2 engine that I'm resealing, replacing pulleys timing belt and water pump. It is out of a 97 impreza outback. So my question is does any one no for sure that a California emissions 2.2 has the same belt as federal emissions. I called the dealer and gave them the vin and they said it took belt 13028AA102. This belt is the federal emissions belt. When I took the engine apart it had a 13028AA150 which subaru says is CA emissions. I checked all the sources and from what I can tell they are the same belt with 211 teeth same width, etc. ANY THOUGHTS? I'm also tapping the head for the EGR I can post pics if anyone wants.
Hey "the group", I took some pics of a timing belt/ cam switch job. heres the link to the pics http://www.facebook.com/photo.php?pid=66521&l=5b48c08a6b&id=100000515483785 This way you can hold the cam gears so that you can torque them correctly. This is the old timing belt. MAKE SURE YOUR CRANK GEAR'S TIMING MARK IS LINED UP. When the crank gears mark is up the pistons are 1/2 the way down so that the pistons can't hit the valves if the cam turns too far.
