Everything posted by subimonster
Let's see everyones OFF ROAD light set-up
what type of lights are those on the bottom of the bumper. got a enough light? i think not!
Solid Axle Legacy
to McBrat. how did you do the steering on your brat? that is the main issue i have run into with my design for my custom frame and four link set up.
Solid Axle Legacy
it would be sick to see that subi wheel when you get it done. hope too see pics soon.
Solid Axle Legacy
where in Washington are you from?
Solid Axle Legacy
i live in sandy Oregon. originally form rhododendron up by mt.hood.
27x8.5x14s on 93 Legacy w. 2" strut lift? Rubbing?
well thanks. it is nice too actually get a little praise for my subi because everyone i know around here doesn't like it because i didn't just slam it and go the rice burner rout. i have the auto in it with 261k on the original tranny and i have flushed it once but that thing just keeps ticking. i am very interested in putting a five speed in it if you know anything about that swap or where i can get a cheap tranny that would be great. and it is getting increasingly hard to find a good mud tire because the whole debacle with interco selling super swamper off those bastards but i have been able to get by on general, BFG, and good year so far.
i cant tell you how many times i have been pulled over so i could be reminded that spot lights are illegal but they are not really spot lights because they are fixed not moveable but they work awesome!
good luck finding them but if you had 15" rims a 205/70 15 or a 215/75 15 are really close to a 27" tire and it opens up the types of tires and manufacturer list alot.
Solid Axle Legacy
let me know how it goes doing this build. i have been trying to get all the pieces together for a couple of years to do this build on my 95' legacy. very interested in seeing some pics.
i have a 95 legacy with 98 ob struts on all four corners. all i had to do to fit even 28" tsl super swampers was cut on both sides of the small pinch weld right in front of the back tire and take a ball peen hammer and roll it under the car then sprayed some paint on it and it fit right in there on the stock 14" rim. i wheel the hell out of it and never have any problems so a 27 would fit beautifully if you just roll that pinch weld down a little.. it took me all of an hour and that was stopping for lunch in the middle.
lifting a legacy on OB struts
thank you for the info. with just the outback struts on my car though it already fit 28 inch tsls without rubbing, that is what i had on it. just wondering i have aome 15 inch offset wheels already to go on it i was just wondering what the maximum size tire i can get with the extra 3" lift was. but again thank you. here is a pic of it on the 28's right after i lifted it... they fit fine in my opinion.
Good Wheeling Shots! Add you favs! (Comment Free Thread)
- Let's see everyones OFF ROAD light set-up
Custom tabs welded to A-pillars not easy but very strong with KC daylighters. Working on putting some on the bumper cross bar then there will be more as tube work progresses.- lifting a legacy on OB struts
my 95' legacy sedan has 98 ob struts on all four corners. i want to do the high guys lift as well same as the green legacy. should i use a forester trailing arm in the rear to keep my tire away from the body more or will it fit fine? i am assuming the lift comes with the proper drive train drop brackets? also i am wanting about a 30" tire is that feasible with the 98 ob struts and an additional 3" lift or will i be running into issues with the struts at that point? Thanks to all help i can get.- Lifted Subaru's 2011 Edition
95' legacy with 98' ourback struts with 28x 8.50 r 14 super swampers and some 205 70 r15 snow tires, some rear pinch weld mods, slight fender trim. also entire front core support has 1/4 inch plate steel for bumper mount and rear diff welded. hoping to get another three inches of lift soon and 31's.- lift and tire size combo pics...
how did you get the toyota axles on the brat. i am planning something similar with my 95 legacy and would like any tips i can get.- lift and tire size combo pics...
swapped 98' outback struts with a little pinch weld modification in rear very little plastic inner fender rub at full lock while suspension is maxed out and some inner fender rub when jumped. 28x 8.50 r14 super swamper tsls also have a set of 205/70r15 snow tires with no rubbing at all.- need help!!!!
thank you. i do some extreme off roading with my car and i simply need bigger tires to keep the body off the rocks and what not. and thanks for the tip about SJR i thought they only made lift kits for the loyale and older body style subarus.- Subaru "Harvester"
the most awesome subaru i have ever seen!!!- need help!!!!
i need to get in touch with somebody that can make me some strut spacers and drive train drop brackets for my 95 subi legacy. can anyone help?- Does any one make a locker for a Suby?
my rear diff is welded and has been for two years now and i wheel my subi and take it rock crawling all the time and still drive it on the street and i havn't broken a cv or the diff yet. it will eventually eat through your tires though.- pics
it has outback struts on it but that is it. i want another 4 inches.- pics
i am running 28x8.50 on stock 14 inch rims. i want to go to 33's.- pics
i didnt do the stinger, i have a friend the is a fabricator and we steel plated the entire core support and front subframe to mount it to. the lights dont really glare on the hood as i have them pointed up a little bit and i did get the idea for the lights from my buddys wrangler. i will try to get pics of the light tabs soon.- pics
no they are just daylighters. i had a buddy weld some light tabs next to the window to mount them. sounds fun, i have never wheeled with another subi before only jeeps and toyotas and i have out done a few of them. would be cool let me know when you are going to be in the area. - Let's see everyones OFF ROAD light set-up
