WJM
Everything posted by WJM
  1. both the clutch and flywheel setups are IDENTICAL. I have done it before. there are ZERO differences.
  2. WJM replied to WJM's topic in Subaru Retrofitting
    Ummm...this turbo is no larger than the 13G. The exh side is SMALLER..and the intake side is only slightly larger. Lag? what lag?
  3. thats the point. Hard to make a long post w/out getting interupted and ppl closing your window.
  4. Lets not all bash the GL and FAST in the same sentence. Technically, Ive got the fastest "GL" in the country...since it looks like a GL Coupe with a body kit.
  5. WJM replied to WJM's topic in Subaru Retrofitting
    we dont know.
  6. WJM posted a topic in Subaru Retrofitting
    So we just got in a VF40...and much action. The VF40 is what is on the Legacy 2.5 GT Turbo, 2005 MY. Its not much bigger than the VF7...but flows MASSIVELY more CFMs on the exhaust side...only a teeny bit bigger...however, the compressor side is BEAUTIFUL and is definalty larger than the VF7...it looks to be TD04L-13G sized..but with a MUCH better compressor wheel. I hope to find a used one, as there are already people out there that have upgraded the turbo on the EJ257 in their Legacy GT.
  7. the VF11 will NOT direct fit on an EA82T header. the TWE DP is a direct bolt on to the stock turo...but is NOT a direct bolt on to the rest of the exhaust.
  8. Yeah.....direct for for sure...but the TWEs are better, and can be swapped out for 'shorty' new style IHI DP's when you throw a TD04 or better on there, and not have to redo the entire DP back exhaust.
  9. how much of one? anything more than 20 deg and I wouldnt want to do it...
  10. Ah, i see it now. Its a gen1 justy.
  11. subspeed does NOT make them anymore. Read all the text carefully and you will see why.
  12. TWE is the only one for the stock turbo. Call Folger SUBARU, talk to Mike Melton in Parts about them. They are the only ones in the USA that have the READY TO SHIP right this second. WJM
  13. ummmm....its not going into a suabru?
  14. Here's the rest of the results: http://www.geocities.com/wmaham1701/atlresults.txt Actually this course was VERY wide open. Atlanta has a HUGE lot to work with. At CCR and Triad, the courses have been not so high speed, very tight and technical and the Civics could not get the power down (main competition locally is a NA built civic, and one with a supercharger build, both with very good setups on them) and I've been able to beat them slightly at first...then I have started outrunning them by 0.5 seconds and more now. The ATL course is very nice pavement...only one spot with a washboard zone...the rest was high speed and VERY flowing...a national level course. I had never been on a course that high speed with the RX, the RX (along with the loose nut behind the wheel :-p ) is setup for the tight stuff...read: 2 inch dia undersized race rubber, ULTRA no-lag setup, and in low range its ALWAYS in the power. This course I should have gone with a stock size, i could have used 225/45/15's and gone in low still and been about 2 seconds faster alone from that. HOWEVER...if I had been able to nail the course, which i didnt, i could have got within 1 second of the BMW, if not faster than him.
  15. Actually, there was an STi in ESP that set FTD...45 some odd seconds i think...or was it 42..? I'll post the rest up tonihgt...there was A TON of ppl out. The Civic that mr Osgood drove had wider rubber, Koni's on it, a GSR swap with a turbo and Air/Water IC setup, full engine management...and a NICE LSD in the front.
  16. I had some SERIOUS competition. The WRX that finnished behind me was on 225/45/16 Victracers...I am #777 Street Mod, Will Maham. Class: STREET MODIFIED --------------------------------------------------------- 1. BRIAN FLANAGAN 93 325ISLO 47.474 47.235 46.736 45.652 45.652 2. MARC OSGOOD 93 CIVIC 47.338 46.777 46.334 45.800+2 46.334 3. SCOTT GRANDFIELD 03 COOPER 49.158 48.657 47.487 47.952 47.487 4. NATHAN PETERS 92 CIVIC S 49.936+2 47.980 47.621 47.609 47.609 5. WILL MAHAM 87 RX 51.297 49.015 48.806 48.711 48.711 6. MILIND BORKAR 03 WRX 54.312 50.017 50.256 49.212 49.212 7. CHRIS NELSON 03 WRX 51.722 51.959 50.817 50.192 50.192 8. SETH JONES 93 CIVIC 51.493 50.600 DNF 50.339 50.339 9. JIM GARRISON 04 COOPER 50.550 DNF DNF 50.603 50.550 10. WES PITTS 92 CIVIC 55.331 53.946 52.795 50.576 50.576 11. ERIC SOTO 92 CIVIC 52.430 53.610+1 50.966 DNF 50.966 12. GARY OSTEEN 02 A4 1.8T 53.108 53.409 53.114 51.164 51.164 13. KYLE BARBOUR 03 WRX DNF 52.635 52.418 51.541 51.541 14. DAVID GOTTSCHALK 02 RSX 54.670 51.973 51.634 51.892 51.634 15. RAZID AHMAD 02 CIVIC S DNF 51.916 51.819 DNF 51.819 16. JOHN FREEMAN 99 9-3 52.830 52.153+1 53.324 52.153 52.153 17. SCOTT MINARCINE 04 IMPREZA 53.701 52.991 53.417 52.859 52.859 18. JASON BERGER 05 IMPREZA 55.053 55.114 52.934 52.888 52.888 19. JUSTIN SHAHAN RX 63.645 58.936 57.880 57.068 57.068
  17. It will run all the time.
  18. Yes. A fellow FSP person and I looked at the rules, and it IS for FSP...and definalty legal for Street Mod.
  19. Correct. I was planning on a HUGE heat echanger for the water....and using the stock non-USDM Legacy AWIC core.
  20. I would.....but there is no room to do so....and I still need to get rid of the scoop to make the car FSP legal....FSP is a much cheaper class to run in than Street Mod. Im going to go with an AW unit, go back to the stock hood...and run SM some more and sort the suspension and driver out...then I'll move down to FSP i think.
  21. I am ditching the TMIC and FMIC air to air ideas....its time for Air To Water Intercooling! It SHOULD be far more superior if its built right...i had a few ideas that I need to research so I can make sure this is all going to work..... Dont know what I am going to use for the AW core yet...there are some custom ones that bolt on inplace of the stock WRX/STi TMIC, that are not too bad in price...kits are EXPENSIVE tho...I still might go with the stock JDM AWIC core that come on the legacys.... the actual exchanger core...its going to be HUGE. Im not going to falter on that one. THe larger, the better....more area for cooling that water down and keeping ti cooler overall. I've still yet to pick out what kind of 12v motor i need...Again, research time tonight...GT4 will be resting.
