Everything posted by Naked Buell
Ej to Ea wiring
Being the neutral wire from the ecu is only one wire, do I just ground the other wire from the plug at the transmission? Ecu is just seeing that as a open or closed circuit right?
Ej to Ea wiring
Hey thanks Matt. That actually helps a lot.
88 Rx Check Engine Light wire
Unfortunately, no I do not.
Ej to Ea wiring
Yes, I thought taking it to the clutch switch as well, but the 88 Rx doesn't have a neutral switch, hence the question what to do with it????? Thx
Ej to Ea wiring
Hey guys need your help. Almost finished with wiring the Ej into my 88 Rx but I have some questions. For the starter wire from the ecu, do I just splice that into the small wire already on the starter? And, second, for the neutral wire from the ecu, do I just ground that wire so the ecu thinks the clutch pedal is depressed for start-up?? My wifes RS was a manual and you had to have the clutch pedal depressed, even though the car is in neutral, for the car to start. Any of you that have done this, please chime in. Thanks guys.
Ej to Ea Alternator wiring
Thanks Matt. I will check it out.
Hey all. I am trying to splice in the wiring from my 88 Rx to a 93 Ej 2.2 and the wiring diagrams I have aren't jiving. On the Ea I have: 1 big white wire, black/white stripe, & white/red stripe On the Ej I have: 1 big white wire, black/white stripe, & yellow Obviously, big whites go together, I know the white/red stripe is the charge light on the Ea. Which one from the Ej is the charge light? Or, does someone know another way to figure this out?????? Please advise. Thx
Ej to Ea Trivia Question
Hey thx Matt for responding. I'm doing my best trying to understand what is needed. When you read through some of the info on the write up, there is things that are assumed to be known and some of us aren't 100% sure of things like some of you subaru nuts. That is what I need help with. Now see, I would have just wired it right to the rad. fan. Thx for the info.
So when you do a Ej to Ea swap, on the ECU, there is a wire for the radiator fan, I am thinking, the ECU controls the fan. But, on the Ea cars, you have a sensor on the radiator that controls the fan. My question is, Do I have to run the wire from the ECU to the radiator fan or can I just leave it the stock way on the EA cars? Thx guys. I appreciate your help. There is a lot of info on this site with you guys.
Hey guys. Working on my Ej into my Rx and was having trouble locating the Check Engine Light wire in the Rx to connect to the Ej ECU. Does anyone know off hand? Thx in advance.
88 RX
Hey guys. Need all your input. Jump down in the Vehicles for sale to check out all the pics of my baby. I definitely want it to go to one of you guys. Maybe, General Disorder. She needs the EJ conversion and the 5 lug swap and some tweaks Rick. Let me know guys. I appreciate your knowledge and input.
High Output Alternator for EA81
If it is like most of the Nissan Maxima's, it should fit. I've seen guys do that mod.
Kia Sephia Sporty
Hey thx. I did find what I was looking for at Napa.
interior fasteners
Snowing like a banshee here. About to go to town in the Subie and find me some right ones. thx carfreak. I was hoping someone had a part number but I can scan the books. Thx
interior fasteners
Hey guys, have a 85 Brat, I'm looking for the little fasteners that slide onto the interior trim piece and then you snap the whole piece in. Any ideas??? Not the normal size ones, the baby version ones.
Kia Sephia Sporty
I'm also sorry to hear about your father. Mine is getting up there too and has fallen off of 2 ladders that have changed my Dad in ways only a son can understand. Please don't think what you write about fixing or what you have found out and put on the site is pointless. When looking how to do something, I look for your threads first. I like how thorough you are and with the pics too. It helps out a lot and please please don't stop the great work. Your Subie Brother across the globe, Naked Buell, aka Joe PS, I'm looking for the little plastic push on fasteners for the interior trim around your head, its in a 85 Brat. Not the common size, the little ones that slide onto the trim itself and then you just pop the interior piece on. Any ideas to find them? Amazon has the normal ones but I can't seem to find the little ones.
Social distancing breach !
Ohh, you guys crack me up. Thx for the laugh. I'm up in Washington State in the mountains north of Spokane. We are good up here. Everyone stay safe and thx for the laugh during a trying time.
- EA81 oil pump replacement
Stolen in SW Portland - 88 bronze GL Wagon 915CNU
I would put a remote switch that only u know about, that shuts power off to the column. No power, car won't start. And, yes, I hate thiefs too.
Wagon Savage
A cool 80 wagon GL would be a cool find and Ej update.
78-79 Brat find
Just waiting for the muddy roads to dry up so I can take my trailer over there and rescue her.
New brat owner needs help!
Well if pump is pumping, take off the line right at carb, have someone crank and see if you are getting fuel right at the carb and then work backwards.
Wagon Savage
I will put that on my check list.
EJ22 wiring harness question
Life does keep us busy. High school and homework and some chores doesn't look so bad when you look back.
Wagon Savage
Hey guys, I have two wagons, ea82's and the neighbor said I could have if I take them away. I did see one with a 5 speed push button 4wd, I will let you guys know more when I comb over them. Anything you guys might be looking for, let me know and I will see what we got. Thx guys.
