Everything posted by Setright
Well, I think it may just be normal. The overflow bottle has little hole in it to allow air to travel in and out. Some of the coolant vapour is escaping through there and causing the smell. It's worst on my car after a coolant change. Which I think supports my theory. Keep an eye on the coolant level, if there is a leak, it will drop enough for you to notice within a few days of driving. But don't panic if the level fluctuates or indeed drops slighlty over a month - some of the coolant just evaporates out. My girlfriend can't smell it. Maybe some of us are just too sensitive. She doesn't here any of the rattles either. Wish it were me, motoring would be far less stressful :-)
35 Mpg
Setright replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Not sure how you wanna convert but I recently squeezed out 14 kilometers per liter on a long trip through Sweden. Hmm, 1.609 km to one mile, and how big is your US Gallon? 3.9 liters? I guess that only gives me 34 mpg. -
Yeah, as Blitz says you need to check for pressure. You can do a simple test from the comfort of your driving seat: Engine at normal temp. Switch off. Wait a second, turn the key back to ON, but don't start the engine. Watch the temp needle, if it moves all the way back up to normal operating temp, you have a problem. If the system is air pocket free and at the correct pressure the needle will move up to a point just below normal operating temp.
Living in Lund, eh? I am just across the strait in Copenhagen! I can't understand that it would easier to source parts from the states? My local dealer gets all his parts from the distributor, which is in Sweden Anyway, next time you have trouble we should consider meeting up. I have plenty of good tools and experience.
Yes, just to add to the consensus: Copper anti sieze and roughly 15ftlbs. I have stopped using my torque qrench on plugs cause off access problems on my IMpreza - old Legacy was better. I tighten with an eight inch handle and stop when i feel "resistance". Don't force them. Of course if they are too loose they cannot dissappate the heat.
Sure. There would be no real problems. The viscosity ratings are the same, so flow is not affected. The main advantage would the increase in dispersants found in the Diesel specific oil. They help keep the Diesel soot in suspension in the oil and therefore ferry it to the filter. The only disadvantange I can think of is fuel dilution of the oil. Perhaps the Diesel oil does NOT have additives to combat the attack of petrol. Therefore, a long drain interval - over 6k miles - might affect the lubrication performance of the Diesel oil. I have considered this myself and I will be running some Mobil Delvac through my engine soon, just to keep it clean. I'll bet it's a better and safer way than using an agressive aftermarket oil additive.
Yeah, with the moly coating still intact, the slap sounds like gurgling in the cabin heater. My EJ20 was doing this when I got it at 40k miles, now a further 40k miles down the line it's pure metallic slap. If I have people in the car when the engine is cold I like to say "Hey, have you heard my Impreza Diesel?" and open the throttle a bit.
A 7-series Beemer is going to be easy to beat for most fast, small cars. The BM is just to big, heavy, and intimidating to throw around corners. The WRX handling is so forgiving that it would easy to stay within the limits and still leave the BM behind. In snow, there is NO CONTEST. In a standing start the BMW would either spin it's rear wheels and get nowhere, or with the TSC on it would just crawl forward. The WRX would fly down the road. WRX vs. BMW M3 - that's more tricky.
head bolt Q
Setright replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes sir, you must replace the bolts with brand spanking new ones! Don't go through a HG without doing so, you'll be setting yourself up for a new HG replacement... -
brakes come on
Setright replied to curt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If the car moves forward after the engine is switched off, you are experiencing some serious transmission "wind-up". The auto box is not working right anymore. Search the board for "Duty solenoid" to read more on this.. -
Come on! Piston ring seating takes place within the first few hundred revolutions a newly honed engine makes. Not thousands of miles. The oil can't get in the way of high points left behind the by the stones of the honing machine. These have a tiny surface area and the pressure is too great for any oil to hang around.
First off: Congratulations! Since selling my EJ22 powered Subaru, I have missed that engine. The big deal about the EJ22 is that everything is so well designed and in balance that it just runs smooth and trouble free. Oil and coolant passages have really been thought about, and it pays off in the long run. All the way up to 300k miles. As with any car, make sure there is oil, coolant, and fuel in it. If you don't have the owners book, get a hold of one. If offers good sound advice on keeping your Subaru running. As mentioned already, stick with Genuine Subaru oil, air and fuel filters to keep things sweet. NGK "V Groove" are the spark plug of choice. Happy motoring...
Filters?
Setright replied to derekho55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Geniune Subaru filters are very good and not too expensive in my opinion. Oil and filter should last 6000 miles easily if you are a running a good quality oil. 3k changes are only for cars that see trackdays often. Air filter is between the same 6k or up to 18k if you rarely experience dust. Both should be done once a year, whatever the mileage.
