95 legacy auto dies when coming to a stop.
bru73 replied to mikewilke77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtemp senser,iac most likely valve adjustment
swing out spare tire carrier
subaru made a jdm one called the gravel express
Markus56 getting lifted!!
worked on my 98 outback
How to remove fuel disconnect?
bru73 replied to mtnpat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtoo small picks work the best
Grinding noise changing from 4th to 5th
bru73 replied to mwynne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe best way to stop this from happining in the futher is dont drive with your hand resting on the shifter it keeps presher on th the syincro hud and bras brake and wares the groves of:banghead:
Automatic shifting issue
bru73 replied to ondarvr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy trans dose the same thing unless i warm it up i have tried all the different trans treatments and no change, past experince at the shpo the one two shift solonide is sticking i have even removed pan and valve body removed solonide and piston and cleaned helped for a wile. dose your trans down shift at freeway speeds??
High compression 2.2?
bru73 replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbuild a 2.4 i am building them for vw van convertions:banana:
EJ25 valve stem seals
bru73 replied to Ross's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa set of angled small hose plires they also sell the tool on the tool trucks
99 Impreza OBS Won't Take Gas Fill
bru73 replied to KitteesPJs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is the breather tube that goes into the body it is located on the right side on top of chatckle canaster this may sound dumb but i have cleaned spiter webs out of a lot of cars and problem is gome:banana:
Bugged About The Gas Milage
bru73 replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfirst of all what year is this car and what is the millage i have a 98 outback with 198xxx on itit whent down to 19.2 mpg used my scanner and watched my o2s very slow changed both cleared ecm and millage is coming back up
Stolen Rig (JEEP) MT Vernon WA
yes Pirate4x4 is a very good place to post this that sucks! I know the founder of Pirate4x4 i will make shure he blowes this up on the sight
Water Leak Into Map Light Assembly
bru73 replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfirst u must remove your front glass onc removed the water tray witch is part of the body you will see the factery seam seal check it real well for pin holes also check ware the roof pannel meets the inner panel the factery missed this hole spot with seamsealer to get the map light out use a small flat blade schrewdriver on the front edge and pop it down remove the too screws and it comes out 3m makes the seamsealer for this reapair:eek:
Do I register or sell?
bru73 replied to HankG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXo ya i live in ca also they have a fee for everthing and a tax for what they missed it is all bs if u sell it out of state and bring it back in they tack on a new fee out of state car reg one time fee of $300.00:confused::mad:
Legacy 2.5 GT lacking power...suggestions??
bru73 replied to hi8u3ri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmine dose the same thing mine is due to tne trans not downshifting and wanting to stay in converter lockup
1998 legacy exhaust
bru73 replied to True2Blue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpic!!!!!!
