avk
Everything posted by avk
My understanding is that the towing hook recall is for those Legacies and Imprezas with an older type of airbag system, the one that has inertia sensors in the fender wells (although 1st gen. Legacies aren't affected). You know you have this system if the steering wheel has buttons to operate the horn.
For those who care, note that wires in boxed sets with a p/n starting with "SOA" are not the same as the original wires: they look like re-packaged aftermarket parts. The connectors are yellow brass rather than nickel plated. Original wires can still be ordered by p/n, they are sold not in sets but piece by piece.
The stalk is a part of the switch assembly, which attaches to the combination switch base with two screws pointing parallel to the steering column. I posted those part numbers on NASIOC and although still haven't done my own swap, another person did it on a '96 Impreza wagon. Still another did it independently on a '99 Legacy, using a salvage part.
95 Subie Oil Leak
avk replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The oil return hole is 6mm in diameter but apparently, on some engine blocks it was partially restricted by a casting flash which caused a build-up of oil pressure at the pump outlet. There's a mention of it in the Motor magazine's 3-part article on Subaru t-belts, cited a few times on this forum. The article says to clean the hole with a drill. Still there are other, more common causes for the leak. -
You can have a 2.2l and no power windows or locks, but only with AT. All 1995 2.2l models are like that. There was a thread no so long ago started by someone who bought a rebuilt 2.2 that came with 1.8 intake and electrical parts. It looked like the engine was that way before rebuilding and most likely, came out of a car that originally had 1.8l. It was not compatible with 2.2 wiring and ECU, but maybe that's what you could do to swap 2.2 in place of 1.8. The intake on 1.8 is made of two pieces (actually three), top and bottom (separate on each head). It should fit if all parts are kept. But finding a 2.2 car can be a better option.
Electrical problem
avk replied to mags's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Did you check if the alternator wasn't one of those included in the recall on '95-'96 models?
