Everything posted by skinny664521903
Replacing the transmission in my 78 Brat Have some questions
The subaru FSM says to use liquid gasket maker for the oil seals.
the wiring sins of my forefathers
Been doing a lot of wiring fixes on my 80 brat. These seem to be the correct wiring diagrams. I have the ones from the haynes manual if you want those as well but I think these are more accurate. Happy to see another Texas Brat!
fuel pump wiring diagram for 79 Brat?
Howdy I am having similarish issues. How do I know which wires are the a,h,f,and e terminals? Also you can find the wiring diagrams here. They are a tad bit different then my haynes manual and im not sure whats correct.
Ea71 pieced together
Can i get a copy to this write up please?
Some 1st gen brat problems
Thanks for the reply. Also could this be the cause of high idle issues?
So saturday was the first time that we've been able to drive my brat more than .1 miles. We took it up to 4th and eveerything seemed alright. As we go to park it, the car begins to idle a little high. When we got back the car had spewed oil all over the enginebay from the breather tubes on the valve covers. They werent connected to anything and the passenger side spewed more than the drivers side. This https://imgur.com/qKG9bU2 shows the routing for the pcv valve. We currently dont have anything connected to the pcv valve. It worries me if we do this and it spews oil again it will mess up my carb/motor due to oil going into the intake. Id appreciate some thoughts on whats happening. Thanks yall are the best!
best place to purchase weber conversion?
I found a thread that might be helpful for you. http://www.ultimatesubaru.org/forum/topic/100553-weber-carb-for-a-brat/
Yeah I got the $23 one just cuz mines kinda fucked up. I'm pretty sure it's opposite with the Carter carb.
The site says it's universally jetted but you may need to adjust it
Literally ordered one from carbs unlimited a couple of hours ago. I think GD suggested them in another thread. Look up the part numbers from the kit on redlines website then order everything separately on carbs unlimited. It's like 60 dollars cheaper than the kit.
78 Brat Wiring Diagram
I will second a request for these ^^^ I too have the haynes and need to get some serious wiring done on my 80 brat. Thanks for any and all help.
Broken bolt problem 1980 subaru brat
Did not lubricate the tap. Doing something wrong is definitely a possibility. The hole is pretty fucked now so we are going to try helicoils. Thanks all for the help. Ill update when finished.
Im going to start this off by saying I dont know the most about cars but I am learning. I also use the help of my brother a lot because he actually knows what he is doing when it comes to cars. So when I first got my brat we were replacing the water pump and a bolt broke off. We drilled the bolt out and got it out but it fucked up the threads on the hole. We tried to use a tap set to make new threads but none of the taps worked because the block was too strong. All of the taps would just round out. We drilled the hole out some more and tried to jb weld a stud into the hole and use a nut to tighten it but the jb weld didnt hold. Im pretty sure the water pump wont seal properly with only 4 bolts tightened. I was thinking of jbwelding some sort of anchor in the hole and then tightening a bolt onto that im not sure if itd work though. Need some help. Thanks a bunch!
1980 Subaru Brat Wiring Diagram
You are the best! Thanks so much!
Does anyone have a wiring diagram that they could scan for a 1980 subaru brat . My manual got ruined and I could really use it before the new one gets here. Thanks a bunch.
- 1978 Subaru Brat
1978 Subaru Brat
I love this build! Im stealing a lot of your ideas for my brat likethe switch panel and drilling holes in the wheels so you dont have to do a lug swap. BTW are those the front shocks if so whered you order them from i cant seem to find them.
Need help fin ding some stuff for my brat
*Rockauto.com
I know rick auto has individual tail lights but not sure about an assembly. That site didnt have the front socks either are they maybe the same as the rear ones.
Need help with some 1980 brat parts I need the alternator and water pump belt without ac and front shocks. The belt i ordered on rock auto didnt fit correctly and there arent any front shocks on rockauto. Any help is appreciated thanks.
1978 Subaru Brat. From death to life and everything in-between
How much did you pay for the brat.
1980 brat Hitachi carb question
Anyone know the correct height for the float. Thanks
Need help with 1980 subaru brat ej22 swap
Sorry for being such a noob but will this work with my 1980 brat. my brother says it will but i want to make sure before i drop $400. http://www.sjrlift.com/index.php/catalog/engine-swap-parts/ea-to-ej-swap-kit-detail
Ya i dont know much about cars YET but i bought this beauty as a fixer upper with the intentions of eventually swapping the engine well i finally got a job and the money is rolling in so now i can get the engine i desire. I dont even know what kind of ej22 i should get. Can yall help me on what i can get for the best price and power. i may go for the ej25 if someone can convince me.
My 1978 Brat
Insanely gorgeous!!!
