Everything posted by oleman77
Easy way to replace oil pan gasket?
oleman77 replied to sjschlag's topic in Historic Subaru Forum: 50's thru 70's
Dude just pull the engine and do it all in one day. Ive had mine out twice now, the second time had it on the ground in 30 minutes. You don't even need a engine hoist, just grab a buddy and you both can pull it out of there easily. You might want to do some other work to it while its on the ground but dude really you can get this done on a saturday easily. Power wash it and engine bay while its out too! If you lived nearby Id give you a hand.... -
Hey guys, i have a 86 EA82 that had all the smog stuff removed before I got it. The carb that was on the car was from a Nissan and was junk so I replaced it with a Weber. Emissions testing isn't required where I live but I have the car for sale and there is a person interested in it but lives in Albuquerque where emission stetting is required. Does anyone have an idea if it will pass an emissions test? It doesn't have a cat either. Thanks for the help fella's...
Ok fella's, after several days of looking I finally found my problem. It ended up being a fuel injector(s). Not sure which one it was but I changed out the fuel rail and both injectors on #2 & #4 cylinders (left side). #4 is the cylinder that had the burnt valve so I suspected that injector but changing out the rail with both injectors in it I'm not positive. #2 injector wasn't even the right one (it was black) which makes that one suspect as well. Regardless the miss is gone! After injectors where changed I rechecked my vacuum. Its still low but did improve. Went from 13" to 15". Still 5" away from 20" but will keep looking. I plan on removing intake and installing new gaskets at a later time when I have a free weekend. When I do I will look for possible leaks while its off. Anyway stoked that the miss is gone.....ya baby!
Ok guys, new OEM spark plug wires have been installed. Does appear to be running better but still have a miss. I also checked my vacuum and only have 13.5". I know thats low, should be like 20". I checked all vacuum lines with both carb cleaner and starting fluid and found nothing. Obviously have a leak but cant find it. Need some help finding it fella's, I'm out of ideas.....pete
Timing belt was the first thing I did check. I originally thought my problem was the belt was a tooth off. The dude I bought the car from told me both cylinders on the drivers side had 0# of compression and the passenger side had 110#. Well after checking I only have one cylinder (#4) with 0# of compression, the other 3 are at 126#. I did however order a new belt, idlers and water pump and will install it when the head comes off. Thanks for your input, I appreciate you helping me try to figure out my issue...
