86subaru
Everything posted by 86subaru
  1. maybe 1 time a year it will get below zero , thanks again for all the help,
  2. owner says when it is well below zero -10 -15 ,the engine will tick for afew minutes and then go away ,
  3. none found all were crushed went to 4 places
  4. will look, writing down everything , never seen any newer subaru's there ,but you never now
  5. if i remember there was a nice 3 door coupe where i am going , some one wanted the tail light lens from it + wiper arm , if i can get it cheap ,i will
  6. what engine parts should i grab if i find any 95 legacy 's , i will have my own tools,
  7. 1500 dollars , it's pretty close to me , wondering if the heads were replaced or just the gasket, the tires are all the same, timing belt changed, newer brakes, no keyless remote ,the headgasket was replaced about a year ago+ new water pump + exhaust,
  8. good shape, good axles, hg replaced, everything works including ac, but over 200,000mi on it , owner says hi way miles, can buy it fairly cheap, any opinions? kelly blue book still list it pretty high ,thanks
  9. pedal stays hi , when your going to stop, like 55 mph you have to press the pedal hard to stop , if you pump it alittle it helps , but the pedal always comes back up
  10. no i have not , the brake fluid is new , no broken or rusty brake lines , how do i check the tbs ? something in the manual says if the brakes get worn down alight will come on ?
  11. my 95 awd legacy a/t wagon runs great, but 1 question the brake pedel seems alittle low ,if you pump the pedal the brakes seem to brake better, but both me and my wife were driving 88 without abs, the owner before says new brakes were put on ,so iam thinking bleed the brakes ? is bleeding the brakes the same way as a ea82 model ? thanks
  12. thanks, is there light around the fan switch on the dash ? all controls work and the green lights come on , seems to me there should be ?
  13. just bought a 95 legacy l awd a/t wagon , runs great , no torque bind, axles good, etc... , is there a rubber cap that can be taken off to inspect the timing belt, i looked but could not find anything ,if i remember the belt needs to be changed every 90,000- 100,000mi right ?
  14. got the 95 l legacy a/t wagon bought and home, my question is what years will fit on my 95 legacy + since the l model has no map light is there wiring there and screw holes to put one there
  15. already have it ,but the link you gave me does not work
  16. owner says no torque bind and all power windows work , forgot to ask about cup holder , front seats look good ,but will check everything out ,155,000mi on it
