Everything posted by 86subaru
Could it be that time again? Another Oil Thread! Hooray!
so using rotella 5w-40 year around is ok, + mobile1 oil filters in OHIO
fuel injector cleaner, recommended?
86subaru replied to photo2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXseaform , subaru has some also but never used it , napa sells it
ea82 turbo question [2]
ok, thanks
how hard is it to replace the carrier bearing in the drive shaft ? or just different drive shaft ? if it is going out what might happen if it is not replaced ?
exhaust is ok, all new, so it could be carrier bearing then , guess we will find out when we leave to go back home
ok, yes the rear end noise could be alot of things , but after pulling over and stopping ,the car is ok now , i am thinking the tranny could have been between gears climbing the steep hills , but my wife remembers smelling something like rubber burning
Columbus Ohio Mechanic???
have all parts ready to be installed , so when miles gets down there then the job will go smooth , ebay has good priced timing belt kits , + other parts that might need to be replaced
also a new radiator + tranny cooler was added , but i remember checking everything before the trip ,and the coolant was ok in the over flow tank, after the turbo wagon sat for several hours the coolant level went down several inches ,
while driving to cincinnati the turbo wagon ran great , 70mph , temp gauge in the middle , after 100 mile trip we stopped , i popped the hood to check a coolant leak ,which was a loose radiator clamp , i noticed the over flow tank full of coolant , no bubbles , oil good, ? 2nd question , also while driving there was a strange noise from the rear end , sounded like a flat tire at first , so we stopped ,i checked everything , no flat tire , cruise was set , pretty big hills to climb, , it is a 88 turbo a/t full time 4wd wagon , 123,000mi , rear diff fluid serviced , tranny fluid changed, good tires,after we started the car ran fine ,no noise , thanks, could i have had to much coolant in the over flow tank ?
best way to flush an auto tranny
86subaru replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa local quick lube place would not flush out my 88 turbo a/t wagon , so had to do it myelf
ea81 question
ok, been on the road for the last 5 weeks , so as soon as i get home + get back on city work ,i'll work on it, the turbo ea81 heads are sold , thanks
ea81 question
i have 2 ea81 wagons , 1 turbo 1 carb , the carb one has a bad tranny ,some rust, the turbo wagon has no rust but motor needs alot of work , thanks
i tried to send you a private message ,but your box was full , miles fox would be the one to do the work , i live in the western part of the state ,and he has done alot of work for me + i have learned alot
86subaru replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat i did was drain and fill , poured it into jugs then i knew how much i drained out , do this, drive it a few thousand miles and do it again
ea81 question
will a carb ea81 motor work into turbo ea81 ,both 1983 , no digital dash on either one , 1 is a manual 1 is a a/t
1987 GL-10 Turbo AWD Wagon
what i ment was a tranny cooler , light duty, i always change the oil very 3,000mi also , drain and fill the tranny will also help,i got my new radiator from the radiator barn 2 row, , advance auto had the tranny cooler on line
a/t or manual.,? if it's a/t then mpg will be 23-24 city 25-26 hi , main thing to do is keep the turbo motor cool , good 2 row radiator + tranny cooler ,
fuel tank quesion
i have a 83 a/t 4wd wagon , will the fuel tank fit onto my 84 4sp 4wd brat ?
bad timing belts from ebay make me mad
must be a mix up ,because i got the same and they fit great 5,000mi later
Ohio Junkyards?
86subaru replied to mrCharlie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbrims in KENTON,OHIO,it is east of LIMA ,OHIO,
transmission cooler ?
86subaru replied to 99subrew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi run 1 on my 88 turbo a/t full time 4wd wagon , and like it , got mine from advance auto ,on line [ light duty]
How long should clutch last?
not to hijack the post,on mine you have let out the clutch almost all the way before ingauging
need radiator
86subaru replied to supergn6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXradiator barn co. ,ebay had some
Vacation Time in a 98 imp ob, 125k
86subaru replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck your spare ,make sure it is full of air , not like me 1 time
Outback wagon repair costs
86subaru replied to LPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi guess it all depends on where you live, around here the dealer is 45 min away , as far as regular stuff , oil changes plugs, wires , cost about the same , but remember you will have AWD , as far as mechanics there are a few around here that are pretty good,
