Everything posted by 86subaru
seafoam ea82 help
there is round black canster ,with 3 black hoses , if i remember it is the bigger of the 2 , start car , pull hose and put it into seafoam can let it suck into the motor , + pour some into carb or spfi ,but not to much , then put the rest into the gas tank , there might be a few other vacuum hoses ,
Loyale stumbling badly while cold
maybe bad plug wires, or vacuum lines , give it a tune up , also drain and fill tranny , check timing ,
Newbie and aftermarket ATF coolers
86subaru replied to sparkydave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi got my tranny cooler [ light duty] from advance auto on line , 37 bucks i think shipped + new 2 row radiator for my turbo wagon , no i am not going to tow anything ,just piece of mind , i am going to run the ac this summer , so the motor + tranny should be cooler, i ran it going though the new radiator + tranny cooler
found a 83 a/t brat in a local yard,what should i grab
a friend of mine cut the top off ,so he could put t-tops on his brat , i gor alot of good parts
Please help diagnose my friends dead twagon
if it will not even turn over , check the cables going from the battery to the starter , this was my problem + ground+ fuses ,
A $250 Exhaust on an EA81?(pics and video)
how loud is it ? thinking about doing it to my 84 brat
Power steering pump whine
86subaru replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlucas power steering stuff , helped mine , i lost my power steering ,drained the little tank and added lucas ,and it came back
Pneumatic Suspention Tip #64009
been there done that , i replace mine with manual adjustable struts ,fronts and backs
need car fax ,
bump:banana: :banana:
need car fax ,
could some one run a car fax for me , jf2kd83a9lo750270, pm me with results.thanks
88 turbo just would not start,
is has started up every time now , just the 1 time ,and my wife got a ride to work , ,but sunday i will clean the starter side of the cable,thanks again
ok, thanks
battery clamps tight and clean, fuseable links are clean and good, when she turned the key nothing , like when you have it in drive and try to start it , no grinding, , all the dash light come on , , it started right up after sitting 1 hour , also started right up this morning ??,is there some kind of safety switch that may be going out , even if the shifter is in park ,causing it not to start ?thanks
so you think it is a dist going bad
my 88 turbo a/t full time 4wd wagon , just would not start, my wife said i put the key in and nothing ,all dash lights came on ,but no start, sooooooo i came home picked her up ,went where the car was and it started right up , things that are new, timing belts, tension pullies , idle, water pump, plugs, wires, cap/ rotor, fuel filter, radiator , temp sensor, , any suggestions ? my wife said it sat about 1 hour
Need to brag on my dealer
86subaru replied to mikkl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame with wagner subaru in fairborn, they have been there since 1977 , ,they are just subaru , same people all the time + have ea82 parts in stock 90% of the time
Which ECU's are interchangable?
i just got one from a 86 mpfi xt ,will sell cheap + shipping if it will work for you
Any special precautions I need to take before/while recharging A/C?
86subaru replied to eseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have recharged my own system a few times ,i bought a kit from a local auto store ,and followed all directions + asked a local shop , and the shop showed me the correct way to do it , no i do not do it for a living or even work on cars for a living , and yes it can be dangerous ,but if all directions are followed ,it's not that hard to do
86subaru replied to eseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis might be be a dumb question but what name brand should i buy when doing it myself? + some of the cans says oil for your compresser , how often should oil be added ?
leaking coolant somewhere
ok, thanks
ok, also new water pump, gasket ,o-ring, heater hoses, water pipe was good, also, + oil line + coolant line from turbo replaced , thanks
my 88 turbo a/t full time 4wd is still using coolant , aleast 1 time a week i have to add coolant , i repaced radiator , hoses , added tranny cooler, no coolant in oil, compression is good, no bubbles in radiator , no coolant on garage floor , no leaking on top of motor,
another rare car found..
my wife drives a 88 awd a/t gl-10 turbo wagon ,
88 gl sedan fwd exhaust mod?
real nice
2row radiator /tranny cooler update
put in a new 2 row radiator + light duty tranny cooler into my 88 turbo a/t turbo wagon , before if running ac on regular setting 4th speed on fan it would be 2 bars from red , driving 70mph , now ac on max 4th speed 70mph , 1 bar below red , the cooler was hooked up to run though radiator + tranny cooler , + all new antifreeze of course , so my point is if you have a a/t in a turbo run a light duty tranny cooler + going to drain / fill tranny again
