86subaru
Everything posted by 86subaru
power steering pump Question
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok, thanks ,the car has 180,000 mi ,new clutch, timming belts, water pump, seals, gaskets, fender, hood put back on, so it needed some work ,thanks again :wave: -
on my 88 gl manual 4wd wagon it seems like there is no power steering , pretty tight , has it gone bad ? thanks for the help :wave:
ok , sure or i will try to do it myself
bump:wave:
yes we did the x pattern , we did not bleed the master cylinder , how is this done ? :wave:
i also had the oil seals replaced 3000 miles ago :wave:
i have a bad tick but only when it gets cold outside below 20 degrees , the gauge reads good cold or hot outside :wave:
mine does the same thing 86 spfi a/t fwd sedan , the colder it gets the longer it lasts , but none of my other spfi motors does this , lucas may help yours or x1r which can be found at napa , :wave:
i think it is a 19mm , it screws in , right behind the thottle body ,
Thermostat question
86subaru replied to MaroonDuneDoom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
will cats drink it ? :banana: -
ok, me and miles fox swapped out the rear disc brakes from a 88 xt onto a 88 4wd manual gl wagon, we put on new pads rotors were good , and we bleed the brakes twice good pressure , why are the brakes still low ? and only the front brakes are grabbing ?
just buy it dude , :banana:
well as long as the body is good, and you can do the work your self, i bought a fwd a/t gl-10 turbo wagon for 60 bucks and it needed a headgasket , a full kit at napa was 275 bucks , but there must be 100 gaskets in the box, just my 2 cents :wave:
spfi acts like carb w/bad accelerator pump
86subaru replied to MilesFox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no we have not , may change the 02 censor ,thanks -
bump ,any help ? thanks -
also the car sat for 6 months without a hood , and aleast another 6 months just sitting . : -
adjustable ride height?
86subaru replied to Jack in Norfolk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have a 88 gl-10 a/t wagon and it works just fine -
Need Help Convincin' The Fiance
86subaru replied to the_bard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well i have 7 subaru's 1 - 2000 outback, 86 spfi sedan, 86 brat, 88 full time 4wd, 88 gl 4wd wagon, xt parts, 89 gl full time 4wd wagon, i tell her to take her pick -
Need to restrict airflow through raidator... Ideas?
86subaru replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
or just stay home :grin: :grin: -
tried but no go , :cornfuzz:
thanks for all the help , :wave:
