naru
9
Everything posted by naru
Look for play in the joints(axle stub turns but axle doesn`t). Sometimes they can feel tight but still be noisy,but,if they are loose,you can be sure they are worn.
And make sure the throttle closes all the way all the time.
You need a ROYZE CA-2K 1990 W. Corporate Way, Anaheim, CA 92801 * 800-421-2011 * 714-533-1823 sales@royze.com - royze@royze.com Dealer should have what you need individually too. Complete used carbs,$50 at http://www.car-part.com/index.htm Get the right year.IIRC there are 2 versions 82-84. Nothing wrong w/the carter/weber 1bbls.
I think they are referring to checking the integrity of the connection between the ECU and the wiring harness as per page 44. It would have been better(but harder) to measure resistances at the ECU plug like the manual suggests.That way harness gets checked at the same time. IMO,your code may be caused by high resistance on the throttle sensor ground(35).I think the idle switch pulls the throttle sensor voltage high because of the poor ground. Or,the potentiometer has a dead spot at idle.
Broken timing belt,bad fuel pump.......
Still sounds like it might be a fuel delivery issue. Change the filter before anything else.Note how hard it is to blow thru the old one. Just because pressure is adequete at idle,doesn`t mean it is OK under load. You want to see the pressure at the same time the engine stumbles. Plumb the gauge VERY SECURELY,duct tape it to the OUTSIDE of the windshield and go for a drive. Normally,I would expect to see misfire/leaness trouble codes to be associated,but, you can never be sure about that.
That is some ugly noise alright. Quite strange the dash is still lit w/the alt.belt off. Must be a more serious wiring problem. I would concentrate on the noise for now. You should be able to pinpoint it using a piece of hose for a stethescope Pay attention to the water and PS pumps. Kinda sounds like it is at valve speed.See if a timing light flashes in unison when moved from cyl. to cyl.Consider a compression test and/or remove a valve cover for inspection.Might want to see if the noise changes any by pulling plug wires one by one.
No oil pressure, need advice
naru replied to oleman77's topic in Historic Subaru Forum: 50's thru 70's
The gauge.Stock are notorously low reading at low pressure. Try a mechanical one for a test. -
Pages 22,31 in the ea-82 manual here: http://www.finleyweb.net/JonsStuff/SubaruDocumentation.aspx
Probable causes of head gasket not sealing
naru replied to Andy FitzGibbon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"Though most gasket manufacturers do not specify a minimum smoothness spec for aluminum heads that have MLS head gaskets, they do recommend a minimum of 30 RA for engines with aluminum or cast iron heads and a nonasbestos or graphite head gasket. The reason for doing so is because soft-faced head gaskets require a certain amount of lateral support from the head and block." You should read the link.Quite good. http://www.aa1car.com/library/ar996.htm -
Got power to the relay coil/contact? (BW wire.) BTW,ECU activates fuel pump by grounding the relay coil.
EA81T starts then dies; video inside
naru replied to 555jay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check that the fuel pump has voltage up to the time the engine quits rotating. If OK,check fuel pressure. -
failed emissions test in GA - 1994 Loyale
naru replied to solakian's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subaru is full of shyte. Lots of peple(including me) have adjusted it. Not rocket science.
