Ozsubie
Everything posted by Ozsubie
I've got a MY06 Impreza and for a new car it has it's fair share of rattles, but hey the 90's Imp's may be better put together, but definitely take some for a test drive to see for yourself. Also if you're going to be towing it may also be worth checking out the mid to late 90's Liberties and they also seem to be a bit smoother and less prone to rattles than the Impreza's. The 2.0 in the MY06 is adequate and can be got going quite nicely, but it's not going to win any traffic light drag's, but again the 90's Imp's are better as they have less weight to haul around. Also, watch out for the road noise level's in the Imp's as they can make a bit of a racket on our australian coarse chip bitumen roads.
I've got a 06 Impreza that's doing nearly exactly the same thing, haven't taken it in yet to get it fixed under warranty. OK when cold, but start up hot (usually worst after about 10 minutes standing while hot) and it hunts around at a very low idle speed, if you bring the revs up with throttle usually it will stall when you take your foot off, very annoying!! Seems to sort itself out though after you drive off, so problem only shows up just after starting while hot.
a ticking that comes and goes
Ozsubie replied to matts87glsedan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also, the oil pump seals may break or wear causing air to be drawn into the pump and aerate the oil resulting in tappet noise. -
1987 gl-10 knock control unit help please?
Ozsubie replied to wes200x's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The knock control unit (as found on the flapper type EFI systems) probably wouldn't cause the rich air/fuel mix even if it wasn't installed. It's only function is to retard the timing if it detects detonation, it doesn't have any control over the air/fuel ratio. I had rich running on my EA82T (flapper type AFM) caused by a half dead oxy sensor in the exhaust. Note that I said half dead because it wasn't dead enough to throw a fault code, but it was dead enough to be giving a low voltage output which the ECU interprets as lean and then throws more fuel in to try and correct the apparently lean mix. Other than that I'd be checking things like the engine temperature sensor is within specification. -
It might just need some more cranking. I knew a guy that started a EA82 that hadn't been run for ages and it didn't want to go, but it turned out the hydraulic lifters had "un-pumped" while the thing was standing and the valves weren't opening properly. After a fair bit of cranking and getting some oil pressure up to the lifters it burst into life. Hopefully it is as simple as that, good luck!
undoing mag wheel lock nuts
Ozsubie replied to suburpy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe a big pair of Vice Grips?? I think that what those locking plier things are called? -
1985 subaru would not turn over...clunk..
Ozsubie replied to bk2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, unfortunately it's certainly sounding like a cracked head or head gasket, but Northwet makes a good point about the intake gasket. I've heard of people adding some sort of conditioner in the cooling system to try and seal a cracked head or leaky head gasket, but I've never heard of any success with this method, usually just clocks the radiator and other things you don't want clogged up. Probably best to save your money and not bother with it. On the suggestion of using water instead of coolant, the only reason I can think that you'd want to do this is to save some $$$$. You'll probably find that it will start drinking a bit of coolant now, and it can get expensive to keep adding more coolant, where as water is cheap to use as a top up. Using water isn't going to do your cooling system any good in the long term, but sounds like this motor hasn't got much time left anyway. Also, water will be no good if you are in an area where the temps drop below freezing. Providing you can still get the motor started and keep it topped up with coolant you could keep driving it, won't really matter too much, just as the crack/head gasket leak gets worse it will get to the point where you won't be able to keep any coolant in the motor because it will just blow it all out the overflow -
Does the engine run rough for a short time after restarting? Are you having to top up the coolant?? Just thinking along the lines of cracked head/head gasket and getting water in a cylinder while it's stopped, and then getting hydraulic locking when cranking on the starter. -
I Purchased the 1987 GL-10 Wagon (Butt?)
Ozsubie replied to harrellee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Doh, for some reason my browser didn't load all the replies and I was going to mention the belts being right the first time, but looks like you already know that. For the other problem I'd check the choke isn't stuck on for starters. Good Luck -
Hmmm, well if the timing is OK I'd check for any vacuum leaks as this will make the motor run lean, although I'd expect you'd have noticed problems at other RPM's also. One problem I had with mine was the diaphram in the vacuum advance broke and this did funny things with the timing, plus created a vacuum leak, although symptoms weren't the same as you're describing. You can check the vacuum advance by disconnecting the vacuum advance pipe and putting another piece of pipe on the fitting then trying to suck air back though it. You shouldn't get any air, if you do the VA unit needs replacing (and good luck finding another one!!) Other than that the only other thing that has made mine cough and splutter at RPM but run fine at idle was condensation under the distributor cap.
Mick, I'm from Oz also. Depending on which EFI setup you've got on your turbo you might not have a TPS. The early EA82T's only used a switch arrangement on the side of the throttle body rather than a TPS that appeared on the later turbos. The switch setup is probably more common in Australia as the later series turbo's were never sold by Subaru here, but of course there are some around that have been imported. If you're running the older EFI system you'll notice that the distributor has a vacuum advance unit on the side of it. If you have this type of distributor then I'd check the timing and make sure you're not running too much advance.
Silly EA82T coolant problems
Ozsubie replied to drewcifer85710's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just to answer your question about the coolant being right up to the cap in the radiator this is how the Subaru should be. If the coolant isn't right up at the cap that's when you've got problems. -
Any comments on Valvoline Oil Filters?
Ozsubie replied to Ozsubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Removed the Valvoline filter last night and put the Ryco on, and it made absolutely no difference to the lifter tick, which I guess I had fairly much expected. I'm a bit more confident in the Ryco being a better filter than the Valvoline though so not all is wasted. The Valvoline filter is nearly half the price of the Ryco so you'd sort of expect it to be not the best quality. I'll probably just let the lifter tick go for the moment and see what happens, as it's really not bad enough to worry about subjecting the engine to the ATF trick. Thanks Skip for the link to the oil filter test, I'm suspecting the Valvoline filter may be similar to the Penzoil filter in that it's a rebadged Fram. If I get bored one day I might open it up and see if it's got the tell tale cardboard ends. Also... was reading a repair manual and it said lifter tick could also be caused by a loose cam belt??? I don't think the belt would be loose, but I'll check it soon, but I can't figure out why a loose cam belt would make the lifters tick. Any one seen lifter tick being caused by a loose cam belt? -
Thanks for the comments. I'm in Australia and normally use a Ryco filter and have never had problems with them. The valvoline filter has made in USA on the box, but that's about all the info it gives. Searching on the internet it seems Fram and Valvoline are quite often mentioned together, so I'm guessing the Valvoline may be a re-badged Fram. I'm getting the general impression Fram is not highly regarded so I'll probably ditch this filter in the next couple of days and go back to my regular Ryco filter. -
Has anyone had any experience with Valvoline Oil Filters. My EA82T has developed very light lifter tick and the only thing I can think of that co-incided with the tick starting was the last oil/filter change. The oil is the same as I always use, but the shop was out of stock of the normal oil filter that I usually buy, so I bought a Valvoline Filter instead. The lifter noise isn't bad, you can't hear it in the car, and it isn't enough to worry the knock sensor, but it is noticeable standing outside the car. Incidently the lifters are always dead silent at start-up and only start ticking after running 15 - 30 seconds. Could the oil filter be causing this, just wondering what others think before I go out and buy another filter to put on.
I had a very strange one with my Auto EA82 in that if you screwed the speedo cable down tight onto the attachment at the gearbox you'd get quite a noticeable whine at certain speeds. The noise would disappear by selecting 4WD. Leaving the speedo cable attachment slightly loose at the gearbox would get rid of the noise in 2WD mode.
Another thing to check that I don't think has been mentioned here is to look (listen?) for any vacuum leaks. If air is being drawn in that the computer doesn't know about then you can get the weird behaviour such as stalling out etc.
I think codes 11 and 12 are fairly normal if you have the connectors plugged together and the engine not running, but the ignition switch in the on position. Does the car run alright for the first minute or so from cold startup, and then play up after it has warmed up slightly. If so, I'd check the O2 sensor. Had similar with my EA82T. Would run perfectly for about 1 minute after cold start, then cough splutter and carry on after that. Turned out the 02 sensor wasn't totally dead, but was giving incorrect readings stuffing everything up, but not bad enough to trigger the ECS light. In my case simply unplugging the 02 sensor made it run heaps better so it was easy to work out what it was. Other than that I'd be having a close look at the engine Temp sensor.
Need Help Convincin' The Fiance
Ozsubie replied to the_bard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the above problem as well. My significant other half hates the Subaru because she thinks it get's more attention that what she does!! Personally I think it doesn't get enough attention, and she gets too much, but that's another story. Anyway, I think the only way to get around this is to stretch the budget and get something she likes, and then get a Subaru for yourself. In my case she will bag the Subaru out every chance she gets, but at least I get to have one!! Good Luck. PS. If you only can have one car and you need something reliable, as someone else suggested go for a Legacy. They are a different car to the older L-Series, but they are similar in many ways. If you know your way around the older models mechanically, I think you'll find yourself in familiar territory with the Legacy. -
I'm on the lookout for some Gen 3 EA82T or Multipoint FI heads. (Without cracks). They're damn difficult to find in Australia, just wondering if they are more common overseas. If anyone has any that they want to sell (and ship to Australia), or knows where I could find some could you reply or email me with details. Thanks
You may want to have a second look at the crack in between the valves. As Skip mentions, it doesn't usually cause problems, however sometimes these cracks can extend down deep into the head and may cause problems. I've just had the heads off my EA82T and a very innocent looking hairline crack between the valves actually extended nearly down to the valve guide. You could only see how far it actually went after the head shop cleaned up the head and put some sort of die in the crack to highlight how far it extended.
Info. on Scorpion 4x140 14"x6" Wheels
Ozsubie replied to Dante's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I notice that they have those rims on their website for $185AU, up $10 on what was quoted above. I was very interested in getting a set of these, but when you consider you can get 2 and a bit Speedy sunraysias for that amount it's hard to justify. I decided to go with the Speedy's. The only problem with the Speedy Sunraysias is the offset. They're just a bit wide (for the L-Series) and mud will flick up from the tyres and rain down on the car (sometimes very hard if it's got rocks stuck in it and you've got some pace on). Makes you wonder if Scorpion would sell more by pricing them a bit more reasonably. At that price most people stay well away! -
EA82T guys - oil and coolant usage thread
Ozsubie replied to Dennis ex24's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My EA82T doesn't lose any coolant (on the odd occasion when I've managed to get it totally sealed), but it seems this engine just isn't happy unless its weeping coolant from somewhere. As soon as I fix one leak, another one would start somewhere else. Currently it's got a very minor weep around the dash temp gauge sender where it screws into the thermostat housing, but I've left that one go, and no others have developed since. Also noted that the coolant would also go down after a bit of serious hill climbing while off road, but found that was caused by coolant slopping out of the reserve tank with the car at a nose high angle. Oil consumption is about the same as what you say with 10W-40. Probably most gets drawn into the intake via the PCV as the air intakes are always oily on my vehicle. -
EA82T Blowing coolant EVERYWHERE
Ozsubie replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it's of any consolation, the EA82T in my wagon has just done it's head gasket also. Not quite as impressively as yours, it's just pumping out coolant into the reserve tank and overflowing that while cruising at highway speeds. Not too bad around town though. I'm not looking forward to having to repair it, or the costs either. It's currently having a rest in the back corner of the shed until I get some money and feel like repairing it, meanwhile I now have to be seen driving around in a Toyota RAV4
