			ccrinc
				Posts1028
				Days Won9
Everything posted by ccrinc
	Need Dist Drive Gear from EA81ccrinc replied to colosuby's topic in Old Gen.: 80's GL/DL/XT/Loyales... I see you're in Colorado? How many do you want? (If you'll come and get it) Emily http://www.ccrengines.com
	"Carburetor is a French word meaning 'leave it alone' "! Emily http://www.ccrengines.com
	If the engine's shaking like that, are you sure it's firing on all cylinders? Like, is there a plug wire loose, or a bad spark plug? Another good possibility...a vacuum hose broke in the cold or came loose. In cold weather, you're going to have a lot of lifter noise anyway, but it wouldn't make the engine shake like that. Emily http://www.ccrengines.com
	If you want to temporarily seal a small leak, use table pepper. (about a MacDonalds pack worth) OK, it sounds weird, but the stuff works! Ask any old timer who's been around cars for years. And it will NOT hurt any of the components either. It flows to the point of least resistance (the leak), gets stuck there and swells up, temporarily sealing the leak. Also, if you think about it, it's totally bio-friendly, and sure a lot cheaper than any stuff you buy for this. ps: Bars and most of that stuff can definitely screw up the entire cooling system on a Subaru. May be ok for an old Ford or Chevy, but not a Sube. Emily http://www.ccrengines.com
	About the octane: you need HIGHER octane at lower altitude because there's more oxygen in the air for the mixture to combust correctly. I drive a '92 turbo Legacy Touring Wagon LE, and here in Denver I can use the "premium" 89 octane. But at lower altitude I have to use 93-94 octane, or it will start detonating (pinging) like a demon! :madder: While the pinging itself is just annoying, and you don't feel a loss of power, if you use lower octane you're putting yourself at serious risk of burnt exhaust valves. And believe me, they WILL burn...we see them in EJ25s all the time. Emily http://www.ccrengines.com
	1.8ltr turbo and dual exhaust portsccrinc replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales... As Skip was so kind to email and point out to me... the intake ports are dual, the exhaust ports are single on all EA82 heads. Geesh! I can only blame it on being exhausted and too darn late to be posting stuff. Emily http://www.ccrengines.com
	1.8ltr turbo and dual exhaust portsccrinc replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales... ummm, the MPFI and Turbo versions of the EA82 are dual, the carb and SPFI are single exhaust ports. Remember however, that the pattern for them is different than the EJ series of engines. Emily http://www.ccrengines.com
	Yep, that's what we use. Technically, Permatex 599 Ultra Gray. Also on practically all other mating surfaces: cam towers, etc. Emily http://www.ccrengines.com
	Wellllll.....I suppose I might have bad information. I mean, Subaru put the wrong EJ22 crank pulley bolt torque specs in the their first factory manuals, didn't they? :moon: I mean, I couldn't be wrong?!?!?!?!?!! I will go back to the factory manual from whence I got the info originally, and doublecheck it. But I'll tell ya one thing: my turbo at the alledged 160hp will leave any Outback with the same hp eating dust! Emily http://www.ccrengines.com
	With all due respect to the work that has been put into the cars101.com website, the info I have on the EJ22 turbo engine is 190hp at 5600 rpm which I got from the Subaru factory technical manuals. I also notice that the Touring Wagon is not included in 1992, but that's what year mine is (pardon the dangling participle) . I know that they are the same engine, and that they were available '92, '93 and '94. (Not sure about '91) Emily http://www.ccrengines.com
	What in the world is this freaking seat belt for?ccrinc replied to Danbob99's topic in Old Gen.: 80's GL/DL/XT/Loyales... Is it possible that the receptors have accidentally gotten buried beneath the back seat? Happens all the time in my car.:santa: Emily http://www.ccrengines.com
	Ej22t?ccrinc replied to tjdrury's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX 190hp stock Emily http://www.ccrengines.com
	EA-82 Rod bearings and Piston Ringsccrinc replied to Flow's topic in Old Gen.: 80's GL/DL/XT/Loyales... Dusty, We use turbo bearings in all our EA82 engines. Suggest you hand sand the thrust bearing. (very fine grit emery paper with some oil on it). Place on very flat surface and sand with a light round motion. NPR manufactures rings for Subaru. You can sometimes find them repackaged under the Michigan Clevite brand, or go to a quality import parts store and ask for "genuine" parts...you'll usually find they sell NPR. Emily http://www.ccrengines.com
	Looking for good head gasket sealantccrinc replied to Beowulfs_Ghost's topic in Old Gen.: 80's GL/DL/XT/Loyales... We like a light spray of Permatex Copper Spray A Gasket on both sides of the head gasket just before installation. Helps them keep from slipping and helps them seal well. Emily http://www.ccrengines.com
	Ummmm, we also do the ER27. What? Did I miss answering another email from somebody???? And yes, we do shortblocks too. Truly, if I miss answering somebody, either shoot me another email, or call me, or leave a number where I can call you...we are soooo busy there are times I dread looking at our email. I swear, some days, I just wanna retire! Emily http://www.ccrengines.com
	First, to convert to an EJ25 in a '96, you'd have to change the Y-pipe of the exhaust. ('96 EJ22 has single port exhaust, 2.5 has dual port exhaust). You'll also need the 2.5 intake manifold. Otherwise, you don't need to change the wiring, ECU or much of anything else. But my main question still remains...why would you want to? For a lousy 30hp? Part of which you lose because the 2.5 is a heavier engine. The unreliability of the 2.5 is ridiculous, the fact that it's interferential is also a huge thing to consider. And they're a LOT more money to buy! ps: the '96 EJ25 had hydraulic lifters, they changed to solid lifters in '97 to gain the extra 5hp. Emily http://www.ccrengines.com
	Didn't wanna post them here. If you need 'em, go to Marketplace :wave: Emily http://www.ccrengines.com
	Turbo Rod Bearings, Where to Buy?ccrinc replied to RallyKeith's topic in Old Gen.: 80's GL/DL/XT/Loyales... THe NDC number should be something like CB2300, not the one you quoted. Are you absolutely positive these are NDC? Also, Michigan Clevite frequently repackages OEM bearings. You can tell by looking at the end of the bearing. It will have NDC stamped on it. Emily http://www.ccrengines.com
	Piston slap? BS!!!! The "new" style of tensioners are garbage and actually make a noise that nearly perfectly mimics piston slap. It's the piston slap that will usually go away after warm up when they expand and stop wobbling (best word I can think of to describe it). Incidentally, tensioners do not "pump up". If they're off, they're off, and you're in trouble! Wish you luck in getting this resolved. Emily http://www.ccrengines.com
	It appears that these people don't know squat (or won't admit it because in many cases they're not allowed to). If any of the tensioners on any of the EJ25 engines break while you're driving, you have valves bent, broken, maybe even piston damage. Part of it depends on how fast you were going when the part breaks. I'm amazed you actually were able to drive it to the dealer! On the DOHC engines, if the belt is off by as little as 3 teeth, your engine can and probably will suffer significant damage. I know the SOHC engines are touchy too, but not sure how many teeth off will cause damage. Overfilling an engine with oil won't cause bearing damage. Sheesh! :moon: It can cause seals to blow out, but you gotta have a lot of oil in there! Emily http://www.ccrengines.com
	Where can I get a ignition amplifierccrinc replied to FlyScooby's topic in Old Gen.: 80's GL/DL/XT/Loyales... Radio Shack Emily http://www.ccrengines.com
