tundrabrat
11
Everything posted by tundrabrat
Finally picked up some 18gauge and began prepping... Then I made my first cut... And saw I had a little more work than expected. view through the tail light opening... 2 lessons to take away... Rhino lining holds up well even when the metal isn't really there and I'm really glad I chose to keep it dry this winter. I'm going to start prepping the area and hopefully be ready to start replacing panels next weekend.
Cam off to Delta Cam (torque grind). Heads in very capable hands being decked, port, new heavier springs, complete valve job... EA82 pistons and rings on order... Block is at the shop being hot tanked.
Wagonstien taking fully independent suspension to the next level
tundrabrat replied to Ioku's topic in Members Rides
keep in mind that if you go the STI route '04 is the only year that shares the lug pattern with other 5 lug subi wheels... '05 and higher STIs have their own pattern. -
We got snow up here... Come on up.
Glad to see my money went to good use. If the body's decent and you don't break it in half I may be a buyer (: I have axels and 2 complete ea81 engines, and wheels for all your pre '85 needs (:
tundrabrat replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is the first car in the line a converted Hatch to Brat?!?! If so that is simply awesome!!! -
new Brat artwork in my house
tundrabrat replied to TajMan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Lol... That's where I was going too. -
Been putting this off... but time to deal with it. I have a guy locally to "EXTRACT" the broken studs from these heads... These are the original "big valve" heads off of the original engine, studs were broken when I got it.
Broken Exhaust Stud Removal.
tundrabrat replied to tundrabrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good call... I'll call in a favor -
2 of the bolts are broken flush... -
I've been putting off dealing with this, the time has come... I have broken exhaust studs that need to be removed from my heads. The guy who had the car before me managed to snap these off on the original 85', big valve heads. Other than taking my time and drilling these out does anyone have suggestions/tricks to try?
Finished tearing down the engine... ready to send out the heads and cam. No pics because nothing interesting... though I now see the difference between hydro lifters and mechanical ones. I worked on the tailgate today... no rust but had a couple of dents I had to work out. Needs a little more work but so far so good... unfortunately I had to sacrifice the original painted pinstripes:(
Flat-4 machine work?
tundrabrat replied to dancinghobotom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What size pistons did you go with? I'm going with EA71 -
Cyclops Grill and light
tundrabrat replied to newgen85brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
3rd eye grill doesnt fit, you will be cutting the quad light grill... Specifically the one with the slats, not the honey comb. I've collected all the parts as well and I have the schematics (that I'd be happy to send you). I'll be doing this over the winter during the resto of my 85' as well. -
Milk in the Air Breather
tundrabrat replied to Fishead Tim's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah... Guess I should have just ripped that band aide off. -
Hmmm... Did your car overheat, if so did you grind the surfaces before you put it backtogether? Sorry for all the questions, just trying to narrow things down. -
How many miles since you did the HG? -
Any steam coming from exhaust or dip stick tube? Is it rough when it first starts? Does it look like coolant level is dropping? -
Looks great!
How's it running? Check your spark plugs to see if they're wet. -
Found a BRAT super B?
^^^ Always a good idea. 2G's is a lot for an older Subaru with a soft body, that doesn't run. If 2,000 is a realistic budget for you, I would look for a good deal out of state and possibly ship. If it has a "Super B" logo, it's fake... MOPAR wouldn't give up the copy right/licensing to that... unless it's got a HEMI -
Does anyone have a suggestion of what gauge sheet metal I should use for rockers?!?
This weekend I was going to pull out my front apron but found out very quickly this was easier said then done. After taking out the radiator I have decided that this will be one of the last things AFTER I pull the motor. That way I can have accesse to the openings through the frame... yes frame is fine. I moved onto fixing my front left fender... and buying some additonal body tools (good excuse to by tools) On a side note... I found a set of steel pug wheels locally so the 4" lift is on! Thanks 86gl-10trbosdn! Doors and rockers are next on the agenda and heads and cam will be going off to be reworked soon as well.
