Rpm90001
Everything posted by Rpm90001
  1. I used 3m ultra pro black 08672 this is recommended by subaru as an alternative. I used it and have been leak free. George
  2. All done, 1broken spring and all 4 corners if I held the piston the strut body weight would be enough to expand them. They were shot. Also replaced the springs with oem with sensatrac struts. Car sits like a 4wd... Well not really, but a lot higher than before. I do now remember why I hate working on suspensions! Spring compressors are a pain On Subaru front springs...
  3. Sounds like a crack head needed a ride. They will find it in a parking lot someplace out of gas.
  4. If you happen to get a p0325 pick up a knock sensor while your there. I just had to replace mine 122k.
  5. So you are going to pull the engine twice? Seems like a bad plan. Exedy KSB04 is $145 with free shipping on Amazon...... yes they sell the alignment tool seperate - probably $4 or so. The ksb04 kit from amazon does come with the alignment tool. Nice kit, I just installed on myself when I did the HG
  6. is there a top and bottom to oem springs? I dont see any markings other than an ogange and yellow dot painted on the center of the springs how do i tell what end is up? Or does it not matter Thanks, Geo
  7. yep, they are shot. If i pull up there is some resistance, but pushing them down just about nothing. 4 new ones going on
  8. I'm sure mine are bad, I have them apart, how to tell if there bad? I see no leaks, but I can expand and contract them with little resistance. Is this the only sign? 122k. I have new ones, but just wondering how bad they are. Thanks, Geo
  9. I just ordered them from amazon. I was thinking of making them, but for $ 10.69 it was just better to buy them. Advanced auto wanted $87 so I thought $10.69 was a bargain. http://www.amazon.com/TYC-800119P2-Subaru-Replacement-Filter/dp/B002VF3234/ref=sr_1_5?ie=UTF8&qid=1310604989&sr=8-5
  10. Thanks, just called original owner, she did not even know there was a filter in there. Must of came with out...that seems funny to me...but any way, I'm going to order a pair if I can just add them. Thanks, Geo
  11. I have a 00 legacy l and just went to check the cabin filters and when I got it apart, there was none in there. I don't know if the original owner Took them out, or never came with them. If they were not an option, can I just order the filters and put them on the open spot behind the door with 4clips? Looks like they just slide in and close he door. I just want to make sure they just leave the filters out, and all need parts are there. Thanks Geo
  12. Yes, the fluid does need to be changed from time to time. Just like any fluid. The fluid is what causes your clutch to engage and disengauge when you press the pedel. Just like brake fluid and your brakes. I know most people never touch the clutch fluid unless there is a problem, and know cars it was never changed on. Not commonly touched.. But not a bad idea to check a service manual to see if there is a service life.
  13. No shims with the new pads, I used a brass wheel on the the caliper bracket, super cleaned the hardware seat area, used new hardware kit and pads were very tight. There was crappy castiing marks that cleaned up with the file. Had the same problem with my truck. I used thurma quiet pads on both.
  14. Well I got 1 side finished, new pads were very tight. Took a very fine file and cleaned the edges of the tabs on the pad. Got them so there was some light drag, but solid in the clips. I could not finish the passenger side due to a defect in the rotor. There was a large chunk out of the inside lip of the rotor. How this could get past quality control is beyond me. I will have to finish it up tomorrow.
  15. actualy ordered on line from home, picked them up on the way to the cottage. Still pretty cool to sit here on the dock and keep up with usmb!
  16. thanks, i do think the pads were a little tight. I too had to pry them out. I just bought rotors and thurma quiet pand and a large jug of fluid and caliper grease. I got everything for 94 bucks! Used a promo code i found on line and got 40 dollars off 100. And picked them up in the store 20 minutes later. I will post how i made out when i get done. Im out in the middle of a lake now enjoying the day.
  17. This info came from tegger.com I believe in another post you changed the T stat and cap wit OEM. If you are sure there is no air in the system I just don't have any idea accept failed HG. Sorry so long..I ran across this on a Honda forum...credit to them, sorry so long. Not all applys to your problem, but still a good read. Bubbles in coolant expansion reservoir back to top Bad radiator cap Failed head gasket Failed water pump seal admitting air from suction side Air in radiator, but expansion reservoir full back to top Coolant leak Too much air in system after fluid change Bad radiator cap Bad seal between radiator cap and expansion reservoir Failed head gasket Low coolant level Can be caused by many, many things. Among them, Failed head gasket Worn water pump seals Lack of maintenance Hoses leaking Radiator core leaking Radiator upper tank cracked If the coolant is allowed to get low, the water pump can't circulate it through the radiator at idle, so heat cannot be removed. Normally the pump can circulate even low coolant if the pump spins fast enough, so a low coolant level generally will not cause overheating at speed. If the low coolant level is accompanied by an expansion reservoir level that's much higher than normal, your rad cap or head gasket is suspect. Age, or the use of inexpensive silicated coolants will wear the water pump seals rapidly, causing premature leakage. The water pump has a small "weep hole" in it, and a noticeable drop in coolant level over several months is normal. You need to keep an eye on the level and top it up once in a while. Air in the system is very bad. Your cooling system is meant to operate with all parts and surfaces completely immersed in coolant, as that's how the anti-corrosion properties of the coolant work. Air equals corrosion. Also, with air in it, the system cannot be pressurized, which is one way boiling is controlled. Boiling (or vaporization of the coolant) is just as bad as a low level. If the engine starts to overheat at idle, or in heavy traffic, and the gauge goes down when you rev it, the coolant is probably low. Best to check. Radiator or block internally clogged with rust, scale, silt, gel, or externally blocked with road debris The radiator is the engine's main heat exchanger. Unless coolant can pass freely through it at the speed the water pump and thermostat want to push it, it can't get rid of the heat it needs to get rid of, and deposits prevent fluid movement. Any deposits at all in the radiator are bad and are caused by one of more of the following: Incorrect coolant Mixing incompatible coolants Old, corrosive coolant Use of tap water to mix with aftermarket coolants When you pull the rad cap off and shine a flashlight inside, the coolant should be transparent (plus whatever color it was when put in), and the fins should be clearly visible. If the fluid is murky, brown, smells like rubber, goopy, or if the fins have white, crusty deposits on them, you've got circulation problems, and likely corrosion problems inside the engine. Old coolant gets acidic and corrosive, and will eat all sorts of internal parts, from your head gasket to the water pump impeller. It also cannot carry heat as effectively as fresh coolant. Inexpensive silicated coolants (the cloudy stuff) can cause silt to build up in the engine's water jacket as well as the rad, providing an impediment to free flow of coolant. Honda emphatically recommends that you use their coolant and no other in their cars. Coolant should be changed every two years with a non-silicate, non-borate type. Long-Life coolant is supposed to be good for five years, but I've never personally been comfortable with that. I change mine every two years or less. Mixing coolants of different formulations can destroy the corrosion-inhibitors, leaidng to rapid corrosion, water pump, thermostat and radiator failure, as well as head gasket problems. From Valvoline's Web site comes this PDF file on that subject. If that PDF doesn't work, try here for a local copy. More on coolant and coolant compatibility from Car and Driver magazine's Patrick Bedard: http://www.caranddriver.com/article.asp?section_id=27&article_id=2334&page_number=1 http://www.caranddriver.com/article.asp?section_id=27&article_id=2264&page_number=1 It's always best to be safe and use Honda's own Type 2 premix. A radiator problem peculiar to Northern regions is external corrosion of the fins. This is caused by winter and road salt, and reduces the fins to a white powder. The fins then crumble and fall off, and once they do, that section of the radiator cannot exchange heat with the outside air. Run your hand gently over the fins at the middle of the rad's core, at the very bottom, under the bumper. If they're crumbly, you'll know. Warmer areas may suffer from sand, pine needles and other debris embedded in the lower half of the rad, which prevent air movement through the rad and thus impair heat exchanging. Bad radiator cap The radiator cap does several things. It seals the system against the outside world (main seal function) keeps the system pressurized when needed, so as to raise the boiling point of the coolant allows excess pressure and coolant expansion to vent to the expansion reservoir (pressure seal function) allows coolant to return to the radiator when the engine cools down (return seal function) As you may have gathered from the above section, the radiator cap has three seals, any of which may fail independently of the others: The main seal is the one that seals the cap against the top of the filler neck. Just a rubber gasket that operates just like one on the lid of a pickle jar. Simple and reliable. A failed pressure seal will allow the coolant to boil at a lower temperature, and coolant will be able to travel freely and foamily to the expansion reservoir. This will cause localized hot-spots inside the engine, which can lead to premature head warpage, and may hasten head gasket failure. It will also cause the rad coolant level to be low, just like a failed head gasket. A failed return seal will prevent the coolant from returning to the radiator as the rad cools off, causing a vacuum that can collapse the radiator's hoses. This will prevent the coolant from circulating if the hoses don't re-expand as the engine warms up. A bad rad cap can cause similar symptoms to a failed head gasket, so it's a cheap first step to try before bringing it in. If you replace the rad cap and you still have bubbles in the coolant (or foam in the reservoir), then suspect the head gasket. If the engine starts to overheat at idle, or in heavy traffic, and the gauge goes down when you rev it, the coolant is probably low. Moreover, a neglected cooling system can load up the cap with crud and corrosion, preventing proper coolant flow in and out through it. Peel the seals back with your fingernail to check for goop. If you find any, a blast with a garden hose and probing with a toothpick should clear most of it out. But anyway, a new rad cap is less than $20. Make a habit to change it every 5 years, just in case. It's pretty important. Bad thermostat This part is the traffic cop that controls when the coolant is allowed to circulate and when it isn't. It's the device that's meant to quickly allow the engine to warm up to its design temperature, but no hotter than that. Thermostats can stick shut or open, get lazy, or fail to open at the correct temperature. Depending on how and when they fail, they will cause either overheating or underheating. Overheating usually happens when the thermostat fails to open, or fails to open enough. If it fails to close, the engine will run too cool, causing all sorts of other problems. A cooling system full of rust, scale, silt, or gel will interfere with the thermostat's operation, causing even more cooling problems. Gunk can plug up the thermostat, causing overheating, or make it stick open, causing underheating. Incorrect installation of the thermostat (can be done, even by professionals!) will also interfere with thermostat operation. Normally mounted in the top of the lower rad hose in modern Hondas, the thermostat senses engine heat in the coolant. It is supposed to open up when the coolant in the block has warmed up enough, allow the cooled coolant in the rad to flow into the block, pushing the hot coolant from the block into the rad. When the thermostat is closed, a small bypass hose allows coolant to circulate through the engine block, around the business end of the thermostat, through the water pump, and back around again. This keeps block temperature even, and helps the thermostat warm up as well. Once the thermostat opens, the bypass is closed off by means of a special extension on the bottom of the thermostat. Aftermarket thermostats are highly associated with overheating and underheating. Most Hondas require 78C (172F) thermostats (that's the opening temperature). Too many aftermarket thermostats are wrongly rated for your car and are poorly made. Your emissions system may not work correctly with a different rating installed. In addition, some aftermarket units lack a bleed hole, the absence of which can trap air and lead to overheating. A new genuine Honda thermostat is about $30 and is guaranteed to work properly in your Honda. In my mind, it's foolish to trust such an important job to an aftermarket part. Changing it every 5 years is excellent preventative maintenance. A good link with more info. "Jack" is not the best writer, but he's got lots to say: http://www.users.bigpond.com/jack_stands/automotive_advice/cooling_system/engine_cooling.html#TSTAT Electric fan not coming on The engine's heat is removed from the coolant through the radiator. When you drive, the motion of your car is enough to push sufficient air through the radiator to effect proper cooling, but when you are stopped, or moving slowly in heavy traffic, your radiator needs help. This is what the fan does: It pulls air through the rad when the rad isn't moving. The problem is that, in order to work, it needs to be turned on. There are various fuses, sensors, switches, relays, and several yards of wiring and connections concerned with turning the fan on, and they do go bad. The fan motor itself is very robust, and rarely goes bad. The fan switch is immersed in coolant. When the coolant gets hot enough, the switch closes, and grounds either the fan itself, or a relay, which then provides power to the fan. In some cars, if the coolant in the rad iCs too low, the fan switch may not be fully immersed in coolant and would thus sense a false temperature and not switch the fan on. Some cars have the fan switch deep at the bottom of the cooling jacket, others have it higher up. Higher up is more prone to this issue. Keep in mind that all but the very newest Hondas use two Wiring and connectors on older cars begin to corrode and break down, which cause their own headaches. Older Hondas (my '91 Integra for instance), have no relay for the fan switch. The switch simply grounds the fan, allowing current to flow, and the fan to come on. (The fan itself still has a relay though.) Here is some troubleshooting information on this setup. Newer Hondas use a relay to help insulate the switch from having to carry the full current that the fan's drawing. The idea is to help the switch last longer, but the downside is a bit more complexity and more parts to fail. Thanks to poster Remco, here is an extensive troubleshooting guide for this type of installation. switches: One for the fan, one for the temperature gauge. This means that a gauge reading will not necessarily coincide with what's actually happening inside the engine. Bottom line: Check your coolant level in the rad AND the expansion tank, just in case. (Note to users of Netscape, Mozilla and Firefox: Remco's page was designed for Internet Explorer. If you have trouble with the text being jumbled and difficult to read, reset your Fonts down one size as shown below, view the page, then set it back up again). *************************** Failed head gasket When the gasket goes, typically the first thing that happens is that combustion chamber gases are pumped into the water jacket. You will see this as bubbles in the expansion reservoir. This will quickly lead to low coolant level in the engine, and overheating at idle, even if the fan comes on, since the water pump can't move the coolant around properly any more. If the engine starts to overheat at idle, or in heavy traffic, and the gauge goes down when you rev it, the coolant is low. The symptoms are similar to a failed rad cap. If you top up the rad, replace the rad cap and the problem persists, the head gasket is definitely questionable. To confirm this, a garage can apply a pressure test (NOT a "compression test"), where air is blown into each cylinder in turn until the technician sees bubbles in the radiator. If no bubbles are seen, the problem is elsewhere, such as an external leak. This can be accompanied by an expansion reservoir level that is much higher than normal, and which does not go down once the engine cools off. If you choose to simply add fluid and ignore the issue, eventually oil and coolant will begin mixing together, and coolant will get sucked into the combustion chamber. Ignoring this is a good way to toast a perfectly good engine. Get it fixed early and there will be no further issues. More on coolant and how corrosive coolant can cause problems, from Car and Driver magazine's Patrick Bedard: http://www.caranddriver.com/article.asp?section_id=27&article_id=2334&page_number=1 http://www.caranddriver.com/article.asp?section_id=27&article_id=2264&page_number=1 Bad seal between radiator cap and expansion reservoir, or too much air in system after fluid change When coolant expands, it needs to go someplace temporarily so it doesn't burst hoses or blow the rad. The expansion reservoir is where it goes. The fluid pushes out of the pressure seal in the rad cap, and travels down the skinny rubber hose at the filler neck to the expansion reservoir. As the engine cools off after you shut it down, the return seal in the cap opens up, and the coolant is sucked back in through that same rubber hose. If the reservoir has run dry, the amount pushed out may not be sufficient to cover the bottom of the reservoir's intake pipe, leaving the system unable to pull the coolant back in, so you'll end up with air in the rad, and resulting loss of pressure. If the rubber hose is disconnected or split, the expanded coolant may end up on the road instead of the in the reservoir, leading to the same situation. And air in your rad is a bad thing. If you've just changed the coolant, there will be some air trapped that will work its way loose back to the upper radiator tank. If there is a lot, there will be too much for the expanded coolant to push all the way into the reservoir. What this means is you'll have a situation similar to that immediately above, where the engine will be unable to suck in coolant from the reservoir. When you change the coolant, take the car for a drive after. Let it cool down, then check the rad for air. Top it off, do the same thing the morning after the next drive, and you should be OK from then on. Regular checks of your coolant level, both in the expansuion tank and the rad, are important in any case. Lower radiator hose collapsed If you're using genuine Honda hoses, you'll never see this problem unless your rad cap has gone bad and won't allow coolant back into the engine. When the water pump is turning, it's sucking water through the thermostat and the lower rad hose. That suction can cause the same sort of hose collapse as you get in a drinking straw when you try to suck a thick milkshake through it. If the hose is insufficiently reinforced on the inside, it can get sucked flat and coolant flow will stop. When you let off the pedal or shut the car off, the hose pops back to normal. If you use aftermarket hoses, not all of them will be of high quality, and may be prone to this phenomenon. To check for this, rev the car hard with your hand on the throttle in the engine compartment, and watch the lower hose. If it doesn't collapse, it's probably fine. This can also happen as the car cools off, if the rad cap return seal has gone bad. Water pump impeller corroded The only time you'll ever see this is if you're using a low-quality aftermarket water pump, or you've mixed incompatible coolants, or the coolant has never, ever been changed. If the impeller is gone or much reduced in size, coolant can't be pumped into and out of the rad, so it will boil and overheat.
  18. Everything is surgically clean. Brake clean, then long electronic q tips. They are spotless.. Boots were in good condition, also cleaned. Brass wheel cleaned them up pretty good, I have always used black high temp gas grill paint to protect them a little, works well. Just not pretty. Got to love NY!
  19. Nipper, I have not put them back together yet, I'm hitting everything with a brass wheel to clean them up and then going to paint them black to try to keep them from rusting..I live in the north east and NY loves to salt the roads. Pins were bright gold in color, and when I cleaned the old grease out of the caliper bracket also smooth and clean. The pins moved very freely when I took them apart. My first thought was they were sized also, but I don't see how, all the pins were free and clean. I have done many brake jobs, and never seen the slide pins that were different. The Subaru pins were 2different pins. 1was a solid pin and the other was a solid pin with a black plastic bushing on the tip. When I took them apart I did not pay attention to the orientation because they are normally the same pin. Do you happen to know if the pin with the bushing goes on the top or bottom? I will add some pictures of the rotors tomorrow, I think I'm missing something.. Should I have the shims that the manual shows? I don't think that is the problem, but you never know.. Mine did not have any shims This is my first Subaru. Thanks Geo Update.. I found out what pin goes where, the one with the rubber bushing goes on bottom. Found it here on USMB. http://www.ultimatesubaru.org/forum/showthread.php?t=82176
  20. Got a question on rear brakes on a 2000 legacy sedan. I have a problem with both sides. Both sides the outer pad no longer contact the rotor. The outer surface is rusted from no contact. Both sides are the same way. The inside surface shows normal ware. I have them all apart now, the slides were very smooth and grease was clean. No binding. The pade were tight in the clips, but I still think they should of moved with the pressure of of the system. The only thing I did notice was there was no shims, just pads. I did read some other post and got my manual out and it does show shims used on the back of the pads. Could this be a issue? I'm sure they were not the oem pads and rotors. Any suggestions? George
  21. I don't know what help anyone can give you here, I think you need to divorice you mechanic, or at least start seeing other people for a while. There is only a few things that cause the over flow to pressurize, if he can't figure that out with the car in front of him, I would have doubts about his ability. If the system has a air in it, he should be able to figure that one out, but I highly doubt that is the issues. I don't know what you are so afraid to take it to someone other that your trusted mechanic, you have been dealing with this for some time. You are making it way too complicated. My feeling again is with out looking at the car is, if you are getting enough pressure in the overflow to push fluid out and you are not overheating you most likely have a head gasket leaking. I don't know anything in the cooling system that can make that kind of pressure other than the combustion chamber. I can't explain why you can't smell it. Why not just take it to the dealer? They have delt with it enough, and you will have your answer. This way if the gasket is bad, you can take it up with your mechanic. When your mechanic did the gaskets, did he pull the motor out of the car? Did he resurface the heads even if there was no warping? -I am not loosing any coolant. You may not get a coolent loss -I have no exhaust smell in my coolant. Can't explain this one. -my exhaust has no coolant smell. Unless coolent is getting pulled in the cylinder you won't. -no overheating. It may not always cause over heating depending on the condition of the system -no coolant in my oil or vise verse. Again... You may not get either one. You have to remember, if there is a leak between the combustion chamber and any coolant passage only, high pressure from the the cylinder on the compression stroke will push exhaust through the leak into the coolant system thus pressurizing the system and pushing air/coolant in to the over flow. Just like putting a straw into a glass of soda and blowing. This type of leak may not show a coolant loss, will not put make your exhaust smell, will not get coolant in the oil or oil in the coolant. And if your system radiator and the rest of the cooling system is good you may not get over heating. You should still smell it in the overflow...can't explain that. Do your self a favor take it to a Subaru mechanic and be done with it Also, highly agree with "the dude's" posts. People here have given good advice, but does not seem like you are taking it. you can be a good mechanic and still have a repair fail. Look how many people have done theirs more than once. You see a lot of HG repairs fail from the dealer, I believe that is because they will not remove the motor to do the HG very hard to clean the surfaced correctly and torque correctly in the car. All it takes Is a gouge in the surface, small piece if missed gasket, even a small piece of dirt to cause it to fail. Here is a post I was reading and though of you. http://www.subaruforester.org/vbulletin/f88/big-bubbles-radiator-overflowing-coolant-40835/ One last thing.. You say 3 good mechanics looked at it, and said it's not the head gasket. If they can tell by looking at it, if they are so good...why can't they tell you what the problem is?
  22. Thanks for the info, sorry I forgot to mention it is. 2000 legacy sedan. I do have a spring compressor. I expect it to ride a little taller. Its funny, it rides perfect now, I had no idea it was even broke. atleast its an easy job.. Spring should be here Friday.
  23. Totally agree on the exedy from amazon. I just did my 00 legacy and very happy with exedy and amazon.
  24. Thanks, No movement seen. I ordered the springs, I will do both sides. Still debating on doing the struts all the way around. Thanks for the info. I guess I will just have to wait to see how everything looks when I take them out.
