bonvo
Everything posted by bonvo
  1. well i got a clutch for it and for free non the less! local subaru guy had it laying around i asked how much he wanted for it and he said free get it out of my life so for 200 bucks plus the cost of registration i have a 4x4 for the winter can we say winning? cause i can
  2. it has definatly been a long road this winter now that i have the subaru to drive this is getting some body work done as well as a cam and side draft carbs
  3. well today after work my dad and i bled the brakes and i installed a tach now that i got to drive the car faster then 5 mph the speedo doesnt read past 20 and the clutch slips baaaaad but other then that its a solid car a few questions one why would the speedo only read up to a certan point? number 2 the gas gauge doesnt work i put 1 and a half gallons in it todat and it didnt even budge on a tank that is only 11 gallons it should register something right? my temp gauge kinda works i know there is some corrosion in the connecter to the sensor but are they any other causes that could be causing me to have these instrumentation issues?
  4. as tempting as that is i want whatever wheel i put under it to fit in the wheel wells this wagon is to clean to cut it up a mild lift and some 14 inch datsun wheels will probibly do the trick with some meaty snow tires give it the rally going look i want
  5. i think i scored with a price of 200 bucks even if i have to put another 200 or so into it ill have a running driveing 4x4 for the winter and a cool little rallyer in the summer all for about 400 just a win win situation
  6. thats just normally how loud they are? if so damn there loud bastards lol one thing ive noticed and im starting to like alot about this car is that its spunky and it sounds pissed off
  7. before anyone says anything i know it needs a valve adjustment and head gasket
  8. today was cleaning day i washed it cleaned out the interior scrubbed the engine bay cleaned up and painted the push bar the rims with the best tires on them started bleeding the brakes but when my sister prooved to be less then helpful at working the brake pedal i gave up ill try again later i also replaced all the vacuum lines going to the carb and put a new radiator cap on it so the cooling system will hold pressure ignore the chunk of vacuum line on the seat then i remembered i had the stock hubcaps from shelly and that they were 13's im glad i hung on to them cleaner engine bay
  9. ill snag some interior shots tomorrow when i go over there to bleed the brakes and who knows maybe a test drive
  10. alright i got it home!!!!!!! loading it trying to get out gave up and crawled out the passenger side which was no small task whos tailgateing me... casper destination reached i have got to do something about the seats they sit to high and the steering wheel is in my crotch unloaded the goodies these may be all aluminum but damn there still heavy next to michelle i looked at them side by side there is somthing wrong when my station wagon is 3 inches shorter then my 2 door coupe so today we filled the radiator adjusted the carb and wired the fan to a toggle switch since the stock thermo switch is dead also fixed the temp gauge all in all a good day
  11. thought you guys might enjoy my other build its a long read http://community.ratsun.net/topic/3434-610-street-demon-resurection/
  12. if you have the ability i would sand blast it and go from there
  13. thinking about just drilling mine out to 6 lug i can find 6 lug slots all day long
  14. slot mags in the correct bolt pattern:eek::eek: must...... find....... sorry i have a fetish for slot mags there my favorite rim very clean car man i dig it ok heres mine 1978 stocker im guessing 4 speed single range 4x4 mileage i have non clue paid 200
  15. yeah i know i was considering converting it to 6 lug simply so wheel choice was easier i just used the rims in the photoshop cause they had the tires i liked on them
  16. if your thinking about cutting and welding i agree thats probibly the only way to fix it
  17. so i think i have a plan of attack stock the plan a slight lift of about 2 inches bigger more agressive tires but not so big that i have to cut the body some extra lighting on the front and rear im going for a rally kind of look something that looks like it can go anywhere but not look like a rock crawler
  18. this is the wagon with the mangled hood right? im thinking after it got tagged the hood wouldnt open and was forced cause that doesnt look like rust damage what i would do is take a chunk of 1/4 inch plate and brace along where the hinge should mount then mount it to the 1/4 inch plate would require drilling 4 holes in the car where its not damaged and 2 holes in the plate done deal and a rather strong fix but then again i like to build things to the point of overkill i made seat mounts out of 3/4 inch plate once
  19. lol i drove threw k falls on the way here progress will happen as soon as i get the trailor over there to drag it home i have the keys and title just need to get the car home
  20. thanks for the link i would still rather deal with a private party though and yes another ratsuner has gotten a subi we need to get 69fjwagon and farmer joe over here
  21. i already have a build thread of sorts in the historic section check there to see how much i paid for all this subi goodness
  22. i can get 200 for that thing? i was thinking about taking it off i have a matching skid plate to go with it to
  23. well shes paid in full and the title is in my hand 200 bucks for all this subi goodness
  24. sorry for sounding stupid but will this lift work with my 78 wagon? from what i can tell the drivetrain and suspention is dang near identical
  25. alright im picking this up some time this week needs brake work but all in all its solid and a cool little 4x4
