Moosen
Everything posted by Moosen
  1. Hoozie you were right. I just grabbed the cable and pulled it all the way out. it was snapped. also took off the clutch pedal as you can see. really wasnt difficult. will it be more difficuly to re run the cable? ordering it tonight.
  2. Alright guys! I got some really good pictures. Unfortunately or fortunately ( i don't know) the cable is actually attached to the pedal still. I went to the engine side of things and took off my spare. and the bracket where the cable runs is just mangled it looks like. What do i need to do? Is this the culprit? Do i need a new bracket? new cable? or can i jerry rig it to hold the cable back? and i dont know if you can see in this picture, but this is the clutch pedal assembly and the cable is still attached to the pedal.
  3. I was at work all day. just got home. I will take a look tomorrow maybe.
  4. the part in red is not there. i think that might be where the cable attached and a pin goes through? but i may be way off. i just know there is no cable attached to the pedal anywhere that i can see. and it looks like there is a hole about 3/4 of the way up with nothing there. i believe that is where the pin should go throught o hold the cable to it? i will take a picture later. i have to go to work though.
  5. Does anybody have a picture of what it should look like? i cant tell but it looks like the cable isn't even attached?
  6. Thank you so much!. I will get on that. man it is cold outside though. haha.
  7. How hard is it to replace myself? oh and mind you it is like -5 degress outside... so the cold probably had something to do with it. is this it? http://thmotorsports.com/exedy_clutch/exedy_oem_clutch_cable/cc894/i-130150.aspx cc894 because of the 4wd right?
  8. So i just went outside literally like 5 minutes ago to go to work, push in the clutch pedal and start the car. I am holding in the clutch letting the car warm up. then put the car in neutral and let out the clutch. Then i push back in the clutch and hear a metal kind of breaking sound and boom my clutch is on the floor and loose. its like there is no tension on the pedal and its not doing anything. just flopping around? will get some pictures in a bit, when it gets less cold outside. Really hope this is an easy fix cause I can't afford much and I absolutely need my car!
  9. NICE! haha i love montana!
  10. I was only here for new years. and I flew out here. :/ so didn't have my lil subie with me! This summer i might drive out though!
  11. Nice can't wait to see what you do!
  12. Was back home in Portland Metro area over new years and saw this car at madison's in downtown portland.
  13. yeah i think i might get it. Hopefully i will figure out how to install it.
  14. so yes or no to being the right one?
  15. http://www.amazon.com/Kats-11405-Watt-Frost-Heater/dp/B000I8YORY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1325038015&sr=1-1 so just that right there? I can tell you one thing. MY car has started every morning. even when -20 degress F. However that morning i couldnt let out the clutch and go anywhere. But i think that my car just would be better with one. I think driving on a cold engine is affecting my gas mileage. Cause I have been getting around 16 mpg...? How exactly would i install it?
  16. If i was to get a block heater. what size should i get for my 87 gl? http://www.amazon.com/Kats-24150-Watt-Universal-Heater/dp/B000I8TQD6/ref=sr_1_5?s=automotive&ie=UTF8&qid=1324970125&sr=1-5 http://www.amazon.com/Kats-24100-Watt-Universal-Heater/dp/B000I8VL3O/ref=sr_1_4?s=automotive&ie=UTF8&qid=1324970125&sr=1-4 http://www.amazon.com/Kats-24050-Watt-Universal-Heater/dp/B000I8YPQ4/ref=sr_1_3?s=automotive&ie=UTF8&qid=1324970125&sr=1-3 are those the right things. and where do they go?
  17. ahaha i am just going to go into sears. but yeah we will see.
  18. well i am not looking strictly for my subaru. something that i will just always use. ya know. i do need some good magnetic screwdrivers.
  19. http://www.sears.com/shc/s/p_10153_12605_00934118000P?mv=rr so not that? haha i wanted a block heater cause it gets freaking cold here but they only had one for $100. I have a tow strap, work gloves, vice grips, phillips, flat head, needle nose, spark plug socket.
  20. I got a $50.00 sears giftcard from my dad to keep my suby running. what tools should i buy to keep her in good shape?
  21. got a new head unit in. sounds fine. I am satisfied. just want bigger tires and the lift. eventually. this summer maybe
  22. gave it and ice bath haha
  23. just not working. i push the defrost button and nothing happens. and i push the wash button and nothing happens. the wash one used to work, and the defrost has never workd?
