Everything posted by Moosen
	Thanks for all your wonderful help with my 87 ea82 guys. But I have just sold her no less than an hour ago sad to see her go but I needed something safer and more reliable. So I recently acquired this bad boy. she's a 2005 2.5rs and it's called the gravel wagon. Full skiplate and diff protector, K sport gravel spec coilovers, light bar, lightened pulleys, strut braces, swaybars, fender braces, roof scoop, 04 wrx hood scoop, bumpin system, apexi exhaust. I love love love it!!! currently it's lowered 1" and stiff for track use but in the winter I will be putting my hankook studded ice pikes on and raising the car 2" above stock.
	Yes where is a link to these?
				Weber Fuel Economy Question
Moosen replied to benjamachine's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am constantly driving my weberized ea82 at 6000-9000ft elevation and I get 20-24 mpg. I just live with it. I have tuned that thing so many times and can't figure it out. 20 degrees advanced on disty, and i am running a 135 and 140 main jets and 190 and 200 air jets. I diesel a little bit when i turn the car off sometimes. but other than that she runs fine. would be nice to get better fuel economy though. I have the disty advance hooked up to the port on the right front of the weber? under the choke linkage. is that correct? -
	Really liked the second look!
Moosen replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What the what? What kinda car is that? -
				Trick to remove balljoint from control arm? FWD EA82
Moosen replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is it possible to remove the ball joint fromt he control arm without a pickle fork. I removed it fromt he knuckle already easily, but i have just been banging up on the castle nut to try and get it to pop out of the control arm? is that possible? -
	That is sooooo sick!
				Trying to find a balance with my choke
Moosen replied to Moosen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you saying I should advance my disty even more to rid the bog? I am already running around 12 or 13 degrees. I am just tired of this tuning! Urgh..... -
hello? -
bump? -
weber -
	So i finally have been adjusting my choke. I closed it up and it starts actually now. and on a dime. But was restricting when driving. So i opened it more and it started and drove pretty well, some chugs every once in awhile. So i just drove home (7min drive) and checked the choke plates when i got home and they werent all the way open. engine temp said warm. So shouldn't they be vertical and all the way open? So I opened the choke till the were vertical, but then I get a problem where when WOT from Idle the car bogs, and or dies? So what do I do about this?
	Success! Fuel pump works!
	never heard of it ahaha
