Everything posted by Moosen
sexy as ************!
Do you know anything about knocking noises pertaining to, cv axle, wheel bearings, type stuff? ahaha CALLING GENERAL DISORDER!!!!! now we sit and wait
replaced my wheel bearings and that still didn't fix the knocking. I am about ready to sell the car. Anyone in the portland oregon area want to look at it for me?
I would buy this if you lived in america. and then throw a beautiful 2.5 rs apoiler on it.
Weird rattling/ clicking noise
so fed up!!!!!!!!!!!!!!!!!!!!!!!!!!! Urgh replaced, cv, cone washer, and now the wheel bearings and nothing happened. Still clicking. WTF IS IT!?!?!?! Is there anyone in Portland that is willing to take a look at it with me?
How was that lowered!?
Portland metro meetup
Just got back in town. Wanna show off my 87 gl finishing up replacing the wheel bearings tomorrow then i am down to meetup next week sometime. Anyone?
Can bad wheel bearing cause more damage until serviced? Cost Parts & Labor?
Moosen replied to mountainwalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi just drove 800 miles on a clunking front bearing.... ahahaha gonna replace it today. had a guy tell me he drove a hummer that had 500k miles on i with a bad wheel bearing thousands of miles till it caught on fire! ahaha:Flame:
inside and outside. so go buy 2 of those then walk into a shop and have them put them in? I am down.
hmm. but i need to find the bearings still
so replaced con washer. helped but it is the wheel bearings at least the parts are cheap. now hmm.... i am in portland right now, anyone have a wheel bearing assembly or know of a junkyard where i can pick one up? les schwab quoted me 189 for parts and labor (100 in labor) but i think i can do it myself? and i just would rather do the whole hub then take it apart and do the bearings i think.
Weber carb for my 87 gl?
so once i got the timing right the car wouldnt start ahaha. only when the idle mixture was turned 3 turns out. so..... BIGGER JETS! Muahahaha boosted up that secondary air jet so it sucks like a mother when i throttle it. and then bigger main. runs good at 1 1/4 turns out. so it's a little rich. but i am at 6600 ft elevation, and tomorrow i am road tripping at probably around 3500 ft so it should be muy bueno! Yipeee!
Cool story. Just ************ing shocked the ************ out of myself because when i undid the distributor bolts, i pulled off one of the spark plug cables and reached down to adjust when the car was running.....Ouch!!!!!!!!!!!! ahahaha But now i am running at 11 degrees advanced sounds smooth.
Yes the sound changed. And it most definitely is not a cv axle anymore. I think it is the cone washer. I am almost sure of it. Because the sound is irregular.
see above pictures. and i just replaced my cv. wheel bearings seem fine to me.
where am i pointing the timing gun to check timing degrees?
alright sweet, my boss is loaning me his timing light. So on that note, which spark plug is my number 1? Where are the marks that I am looking for? And What degree is ideal for me?
On my way right now!!!! EDIT- ahahaha forgot i am jb welding my cat and muffler right now, fixing holes....
Gave it to her!
Damn you have a hell of a catch! Most girls would scoff at something like that. I think it is sexy though
Light Bar / Brush Guard / Bull Bar / Skid Plate
87 gl interested
ooooh it very well could be the timing. i backed it off quite a bit. is there a way to tell exactly how many degrees i am at? also my disty cap attaches with two clips as well.
oh also it wasnt pinging. I read up online on some other forums and found out that it is just my heat shield. rusted through the bolt and now the heat shield is loose and rattling against muffler. Easy fix
yes i did use the transadpt. Still had to bang in the power steering reservoir though. I just put a bigger secondary main jet in. 135 primary 145 secondary. And i am at 1 1/2 turns out. runs really smooth and at about 700 rpm's. But now when i floor it from idle it actually backfires? what does this mean?
What size roll pin.
will do boss! You think that is what is causing the knocking? it's only when i turn right and the pressure comes off the wheel enough to make it like wobble and pop/knock. when it is under pressure the wheel tracks straight so no issues there.
What size roll pin.
hehe woops gonna get one tuesday and put it in on location then drive to portland and crossing my fingers that my problem is solved.
