Everything posted by Moosen
Yeah i wanna average around 25 at least around town just driving hard. i drive up and down the mountain a lot. and then on the highway to and from town i wanna get like 30+. so we will see
Oh i already had taken the old linkage off. it's all figured out now got the oil pressure figured out. Wasn't connected but appeared to be till i reached my hand down there. ahaha silly me. Yeah I am loving my new weber. just a couple more tweaks and she is there! Excited to see what my gas mileage is going to be like! now onto the cv axle. hopefully that gets done quickly
Just re jetted to I'm running: Primary main: 130 Secondary main: 140 Primary air corrector: 190 Secondary air corrector: 200 Primary idle: 50 Secondary idle: 45 it is running a lot smoother. and it dies less when i slam on the accelerator. Which is good. but I don't know if that means I should keep increasing jet size and air corrector size. also plugges the asv and egr intake. Still can't figure out why it shows I have no oil pressure.
Okay i really need help on this one. My throttle keeps getting stuck and i have to quickly turn off the engine. The part at the end of the throttle cable that pushes into the bracket to hold the cable to it keeps sliding out to the left and getting hung up on the linkage to the choke plates. How can i prevent this? has anyone else had this problem? If I get this http://www.webercarbsdirect.com/product_p/101.099.htm would I be okay? edit: Gonna try a spot of duct tape for now edit: tape works awesome! Gonna do a more permanent solution sometime soon.
found it
The search function on forums are not the greatest. I am searching for stuff on them but not finding much.
yeah i am gonna go to 140 primary 130 secondary jetting. and then bring the air jets down maybe? idk
oops my bad i thought you were the one that posted kanury's post as well. anyways I don't think that my timing is bad and I have the disty hooked upt o the righ vacuum port on the weber
I could swear there is already something plugged into that? but I will check again tomorrow. It has a lot more power which I like. and sounds beautiful. But tuning is annoying... and I am interested to see how my gas mileage becomes
this!? and do i need to plug the asv or can i leave it open? I think it kinda sounds cool?
I am confused what you are telling me to do
so what do i need to do?
it shows no oil pressure. I don't know how to adjust timing? I am running main 130 secondary 135, air primary 200, secondary 190, idle main 50 secondary 45. Is the ASV causing any harm cause I kinda like the sound vacuum advance?
FUSE! good thinking. gonna go check now edit: nope! dang what else could it be?
but it happened when i replaced the carb?
asv's? but my oil pressure gauge says i have no oil pressure? and I just re jetted it to make it way leaner? that black soot is from before
just re jetted and it idles better. But when i hit the gas pedal abruptly from idle the car actually dies, as if it is not getting enough gas? i only stepped down one size. ay yi yi. this is annoying. ahaha so am I running too lean?
both of those are plugged in?! and it still shows no pressure
So i just put in my weber carb and everything is good, still need to rejet (running a tad rich) but it says i have no oil pressure. I think the cable for the sensor came unplugged but im not sure. Where is the sensor and what does the wire look like/ where does the wire come from. I have a spare wire hanging out over by the oil cap but i cant find where it goes and the oil pump (or what i think is the oil pump) down by the oil filter already has a wire plugged into it?
Moosen replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Got the jb weld on. not super smooth but tomorrow I will just sand/ file it smooth hopefully this fixes it. Will i be able to put my carb on tomorrow morning at like 9?
How to: Incressing Boxer rumble? (EA82)
Moosen replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bumping this thread. Cause i am wondering if I can get this http://www.jegs.com/i/Cherry-Bomb/545/16804/10002/-1?parentProductId=769809 cut off right in front of my muffler put a 1-7/8" adapter to 2" and use this guy? -
Thank you! i will try this tomorrow! hopefully this fixes it!
