CoupedUpSubie
Everything posted by CoupedUpSubie
I want to say that second is commonly ground on occasion. I bounce mine every now and then when power shifting, don't think its even near 1/40 shifts. More like 1/100 shifts, but I spend most of my time in 3rd-5th. Try slowing down your shift times and use only two fingers to shift so you aren't putting as much force on the shifter to get it to go into gear. It will slide into gear more so then slamming it into gear. My trans doesn't like going into reverse all the time either. If it really doesn't then try putting it in first and then into reverse(I've heard that helps). I don't believe anyone makes a short shifter for anything older then '97 but I may be wrong.
18 mpg with a fwd 1.8? You definitely have a problem. It isn't the on off ramps doing it. I have the same setup and have never been below 25 mpg. Check all your vaccum lines, clean the MAF and throttle body(use the cleaners made for it). Does the CEL come on when you start the car? It may have been disabled. What is the mix of ethanol in the gas you have been buying? Try other gas stations as well, find the newest one and try the first. Your hard shifting is exactly what you think it is. Thats just how the transmission is.
I can drive my 1.8 with a 5speed pretty hard and never get below 27 mpg. Thats driving up and down the Maine coast. For those who don't know it has lots of hills. It is a coupe with FWD so that helps. I know people who say they get 30 mpg with a 2.2 and 5 speed. The auto's seem to get worse mpg. If he really wants to get all he can then a manual is what he should get.
What brake setup is on the car (ie disk/drum or all wheel disk)? From the sounds of it that could just be how your car reacts with the tires locked. Also depending on the roads it could be the crown put in the middle to shed water causing the rear to want to continue moving and the easiest route is down the bit of slope. I run into the same problem driving on snow. My front wheel drive impreza will track with the rear out 6 inches or so with the handbrake engaged going in a straight line.
What are you running for fuel? Some stations have 100% gasoline while others have E10 gasoline. The switch to E10 happened in Maine before I got my subaru so I am not sure what I would be getting with straight gas. The jetta with a 2.0L got 33-35 mpg on straight and dropped to 28-30 mpg with the E10. Also look into if your local stations run a "winter" blend as this also effects my fuel mileage. Once you replace your fuel filter I reccomend running seafoam or some other fuel system cleaner made for the fuel you use. E10 fuel requires special formulas. If you find that your filter is clogged after this then you know the cleaner did something for you. Yeah it is another $25 but if you are getting 4-5 mpg more then the savings will return.
A front wheel drive isn't all that odd. Many parts swap over but a few don't depending on if its auto or manual. I believe there are a few adjustments in the rear end but don't quote me on that. Some cars do only require the front to be aligned. If you need any help figuring out what parts will swap send me a PM, chances are I have figured it out.
I am curious how the timing being off 1 tooth would effect the compression. To me it sounds like the heads needed a good amount taken off or the person doing the work took too much. Also the two different HG thicknesses could be the culprit. Thinner gasket and higher pressures could have caused your quick HG failure.
Considering they don't make the HP in 175/70/14 that my car requires I have run the RT version of the tire. Same basic tire but non-directional. They are both 440AA tires. Personally I don't like them for anything but dry pavement. Due to a college students budget I buy the cheaper tires instead of the ones I would really like to have. The traction isn't there for me, then again I do drive a front wheel drive impreza.
Noise is back. I was really hoping I had solved it. I only heard it briefly but its there. Hopefully next friday I can have someone ride in my car with me and help pinpoint where its coming from. I honestly think its the passenger CV shaft this time. Is there anyway I can test the inboard joint for failure? It doesn't have any rips or anything so I don't think its loss of grease.
:facepalm: I should have mentioned that I replaced all four bushings. The rear ones weren't a problem. The front ones were a pain. I had to remove the front bushings myself with no press. The new ones went in most of the way in a vise but required a 3lb hammer against the huge washer type piece I had to hit the outside sleeve. I put another washer under it with a larger hole. All of it was set on the tailgate of a 1ton dump truck.
CV joints are all good. I have checked them 100 times in the past 3 months. The transmission noise is way too fast for my noise. Now the silicone leaking from a bushing. That makes sense. When I first discovered the noise I was told to check all of that and saw some white substance coming from my drivers side rear bushing. :facepalm: My father looked at it and didn't think anything of it. He isn't familiar with Subaru though. When I changed the drivers cv shaft I seperated the ball joint and pushed the control arm down out of the way. Could this have temporarily tightened the bushing, the noise went away for about 50 miles.
When something has to be said twice it really bugs me. If it isn't useful for the problem at hand then there is no need for it to be brought up. I give a clarification statement after the initial info. After that anyone who continues to mention something like driveline ujoints on a front wheel drive car deserves it. /rant.
