10
Everything posted by ivans imports
have tons but need to know grey or black what tip design i think there are 3 different ones do you just need a set or a specific set ?
Whens the bachlor party ? any new projects ? just started working on the 77 red brat im done the 80 brat looks like new came out realy good. Do you have a use for 04 wrx 2.0 heads have a good set came off knocker but compleate with covers and cam gears ext cheers.
i modd them up a bitt you can put ea82 turbo rods and pistons in it helps alot. Use a soilid lifter block the one with extra two head bolts. Theese engines will rev higher than the hydroilic ones you can also use a 2.0 ej piston but have to remove the piston pin bushing. I also like to put the ea82 tbi onto them if has turbo pistons can go tbi turbo thiss works well to but is diffacult to set up my 81 brat is tbi with full deul exhaust pulls about 40% better than my 80 brat with ea 71 dont use the 1600 pistons they have weak ring lands and break when pushed above 7000rpm use a piston that has the thin ring on top ring theese are alot stronger and hard to break i have some ea 81 parts still mostly crank and rod assemblys i save them for airplane guys
