Everything posted by ivans imports
1999 Impreza L Trans question
99-01 legacy / impreza
97 2.2 Eng Low Oil Pressure
ivans imports replied to rdjeep's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck thrust bearings for play
Why are the center Head Bolts Tighter than the others?
ivans imports replied to JohnM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe heads warp from center out mostly on middle were ex is they were trying to prevent this. The ex part of head gets hotter and more likely to come loose
justy block studs
Found out this cool swap was able to use Ea 81 head studs in my 1.2 justy fit perfect and was way better to line up gasket and head. Was room for the 17 mm nuts and I think it will help prevent headgasket failure on turbo justy. Also at same time opened up chamber in head to drop ratio. Works good no more ping at 7 psi
- I'd like to try to make a side by side buggy.
Overheating Forester
ivans imports replied to CFab's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhead gaskets
EJ22 throttle body help
I use a tiny bit of vasoline or light grease allows it to come off without tearing
98 Forester Stalling, Dying, Intermittent Spark, to No Spark
Check main engine ground on intake and power supply on bottom side of under hood fuse box also cam senser
heater blower circuit?
whoops on newer on old one is just above heater coolant valve
3 inch from blower motor
- Experienced mechanics, help me with timing belt change
Change the blower resistor is next to fan held in with 2 screws and has 4 wire plugin
97 impreza outback lift quick project
I used 98 outback struts all the way round had to also use the rear trailing arm front holding bracket. The rear strut mount holes had to be sloted slightly gave me a good 2 inch. I also added ej22turbo front x member / engine and a high low 5 speed just for fun and twin Ebrakes on for each side
4x140 to 5x100 bolt pattern adapters
I live a cell phone free life so no ability to post pic's matt did put one of the 80 brat with 16's on this thread
boiling overflow coolant
head gaskets
Overheating '01 Legacy L, Clogged radiator?
ivans imports replied to beamsbox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeadgasket's have 4 booked next week all same rads do not go bad often but headgaskets do every day
- 20 replies
- overheat
- colant
- radiator
- 2001 legacy
Tagged with:
Splittin Dual range trans Help
The trick to the rails is the have to be together when you put the middle shaft thru then can put 2nd shaft in then snaprings and pin a bit of sticky grease will keep ball's / detents in place
Install a 1/4 inch washer between the reverse idler and case on front side of gear will prevent reverse kickout
- 77 Wagon Car Door Window Seal Replacement
Fuel Level Woes
ivans imports replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhad this on forester other day a new sender unit fixed it
all summer driving brat around no problems gets looks like crazy loving the 16's
Won't start. No Fuel and No Spark
ivans imports replied to nmos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck wire harness at bottom side of fuse box for corroded wires
