Everything posted by subaru_styles
86 gl 3-door= light truck
[chewing tobacco]oohhhwee I got dern soobaroo dast registered like my big ol chevrolet!![/chewing tobacco]
I'm gettin cams!!!
oh don't get me wrong, i am not discouraging anyone from getting them..but i don't know if this was one bad set or if there were a couple more
I'm gettin cams!!!
im still waiting for john to talk to delta...appreantly on the cams there's was a "dead" spot that did not let the one valve on each clyinder seat all the way...the cams still need to be sent to delta for them to evaulate
I'm gettin cams!!!
well I am not going to amke any claims against delta.i believe there a good company. however the cams I bought were not properly ground.
Finished the tailights for the coupe!
well they were "lighter" red before with orange lens fro the turn signal... and yes you could do it to a xt6 rear lens...Pm me if you are interested in doing it..
I'm gettin cams!!!
hopefully you won't have the same problem as i did with them
New Wheel combo...
7 wide with 0 offset, they will stick way out past your fenders..
Lightweight wheels? Accurate weights on 4X140 wheels
you have too many wheels laying around then!
Its back on ebay again...
i emailed the owner.... i am trying to find out what is the deal with that model. i have never seen a european EA82 with thoose bumpers..is listed as a kombi, but i don't know if that refers to wagon?
How rare was a "awd" ea82t wagon
lets see some interior pics!
i want that wagon soooo bad...and stock BBS's are the shiznit
yeah where is it
Thanksgiving Weekend Projects
wouldn't it be easier and more cost effective just to get another scoop for the RX?
wanna see another WRX powered brat?
up past 3am...whats wrong with us
Why and where!?!?
have you checked the fuse for the rear defrost? and make sure any harnes's in the rear aren't dis-connected
CAH-LICK ONNA MEE
attn chemistry geeks - need correct solvent
i know of alot of shops that use like an eraser type thing on a dremel...it gets off decals and stripes
Does '87 GL alternator have internal/external regulator?
internal-----you need a new alternator
R15 tire advice...
IMO kuhmo's are crap
R15 tire advice...
they are $57 each with free shipping--->click me foe nitto tires i have to say after using this brand i really like them
R15 tire advice...
if its for an ea82 i would suggest a 195-50/55-15 or 205-50/55-15 you will retain stock tire diameter that way
is there anyway i could make or find a cold air intake for an 86 gl hatch??
well since your hatch is a carb...go with the weber
hahhahahha when i was removing the perfect tailights from the rx i broke both of them
Mechanics...help figure out whats holding back the RX wagon from running!
the disrtubuter and timing are all normal(it is not 180* off) oddcomp...if you ever in the area i was thinking about trying the MS alltalk- alltiming s are fine...compresssion has been checked, as far as the cold start thing..last month we driving my car all around...turned it off, then it would fire back up no problem..then it went ghey again... WJM-i used a turbo spider manifld and its harnress...it's intake harness has been pined out to prove it's the same as the stock unit.we have also tried the tps from a stock turbo manifold naru- we have tryed unpluggng the maf or tps while it's running. fuel pressure is great..it does run rich. alternator has been replaced with a good unit... i will check the ground on the computer archemitis-allready tried unplugging the O2, not the water temp though...no flapper..i have hot wire maf RenaissanceMan - nope plug wires are fine i hope i got everyhting...that was alot of replies to do!
my wagon is back! MAJOR moldy pics inside
thanks you guys for all the suggestions!
