Everything posted by subaru_styles
RX Performance Rally Car
subaru_styles replied to Do It Sidewayz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
[crowd yelling] More pics!![/crowd yelling] -
Symtoms: car will only start when it's cold...it will idle fine(sometimes), you can "move" it but you have to keep the revs high and it feels like it has 30hp, real boggy.. other times the idle will fluxuate between 2k and like 400! up and down almost ready to die(which it usually does)...once you turn it off it will not start back up unless you wait like 6 hours..the computer is throwing codes for nearly everything.. Motor: EA82 turbo, spider intake, new HG, and the heads are in awesome shape. new timming belts and timming set correctly, all new seals. RX wirring harness and ECU Actions taken: replaced hot cams with stock cams the fix the variable compression issue. replaced thermo unit tried a stock intake manifold, so rule out bad sensors on the top end Whats left to try: try a different ECU so please throw out some suggestions as this car has made quite a few people pull their hair out... and yes i have lubed the muffler bearings!
Finished the tailights for the coupe!
subaru_styles replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah i snuck that in the pic one of the few things i kept off that RX -
i see them around, granted not as often as EA82's
well i got my wagon towed to day....as some of you know the interior of my car was sweaty and growing its own mold forest...it's on everything let me tell ya the pictures do not do it justice..and it is very wet inside since its been "sweating" the past months. i picked up a vapor mask and some golves and dove into it. so so far i removed all the trash/objects from the car. i pulled out the seats..ive tore up all the carpeting too..it's all going in the trash. tom. going to chuck the seatbelts and some other random pieces as well. Scrubing everything down with bleach..hopefully this will be able to get rid of it all. as mold can be very dangerous to a person..here's a couple pics...if anyone has any suggestions regarding cleanup i wouldn't mind hearing them..my steps are:throw everything out, scub down with bleach, air out, rebuild
how to rewire an 82 for a cd player
subaru_styles replied to seth3030's topic in Old Gen.: 80's GL/DL/XT/Loyales...
whats not in the factory location that you need to find/run: constant 12v to the deck, you can splice in at the ignition... you can also use the test light to find the haedlight hot for your dimer i just suggest running new speaker wires from the deck to the speakers whats there already: use test light to find 12v keyed on ground -
Launching an RXTurbo
subaru_styles replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
take the revs up to 6500 then instantly let out the clutch -
I started my custom grill....teaser pics
nah..i just started in today.... once i get to the fiberglass i will post pics of the build up -
hahahah i had to fix the pic....sorry for the ones who saw my "man-ness" while i was wearing sweatpants -
well since i have alot of free time, and my dremel back, i decide to start my grill project. still have alot of fiberglass, bondo, and sanding to do. here's a quick pic to see what a badgeless rx grill would llok like.. they look like this.. I cut out the emblem with about 2in of the slat on each side then form another 2dr grill i cut out the middle slat big enough to sill the opening. it's my first time trying this, so i got alot of gap to fill...
lots-o-questions: 3-door vs. RX and more
subaru_styles replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
#1 Yes #3 yes #4 YES #5 you could do it but i suggest getting parts from a lowridder mailorder type place. run you own lines, compresser, vavles, switches #6 Hell no -
dumb 4wd question
subaru_styles replied to SubaRust II's topic in Old Gen.: 80's GL/DL/XT/Loyales...
its the 4wd for dirt, mud, snow, sand, gravel, etc -
Mid 90's Integra VS. 88' RX..& Thanks!
subaru_styles replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you didn't offend me..i just wanted to comment.. I just wanted to point out. if that unexpeirenced kid had happend to loose control of his car he could have hurt someone bad . now you are liable. you will face criminal charges and lawsuits the will end up in very high 6 figure settlements. you'r insuraance will only cover so much..anything beyond that amount you would be acounted for...it would suck to go to jail and then have 400,000 dollar debt. even claiming bankruptcy will not fully wipe your slate clean. it's even worse if you are younger..even if your over 18, if your parents bought your car, pay your insurance(basically any support to you) then they can also be held liable... the only reason i am saying this is i have been involved in a case were someone inoccent got hurt and i had no direct cause in the accident..2 years of my life were ruined to do all the stess from that..investigation, courts, etc...which also ending up in a larger settlemnt against me... al i say is that it was some thing that i would never think could happen to me, but it did -
i don't think racing on streets should be bragged about or posted on the board.. it puts innocent people in danger. i have had people in my life including myself be invovled when cars are speeding each other on the roads. plain and simple it = death, jail time, and lawsuits just my .02 -
got a RX rear shock question..>.corky??
i would belive that subaru just ween'd out the RX struts...i highly doubt you can order them anymore.. OASN I heard they stop manufacturing 2wd xt6 front struts -
well here's mine.. Kenwood eXcelon head unit Kenwood eXcelon 8" touch screen lcd monitor Blaupunkt dvd/mp3 player Coustic design reference crossover (3) Coustic 100x2 amps Coustic 6 1/2, Coustic design reference 5 1/4, and tweet Coustic 8" and tweet (2) Kenwood eXcelon 401m momo blocks (2) 2ohm Boston Acoustic Pro 12" subs---subs are getting 600w RMS a piece (2) Optima blue tops
