Everything posted by nickb21
Washer nozzles not adjustable?
nickb21 replied to adwolf1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe put a piece of foam inside the tube before the nozzle? I think you're going about this wrong; you should turn them around so you can spray other cars and people in crosswalks! Happy Holidays!
need mechanic in north west New Jersey
nickb21 replied to ron917's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, so it took me a month I stopped up to the place in Broadway yesterday, it's name: Broadway Automotive, go figure. google maps is off by a bit on the address: http://maps.google.com/maps?q=broadway+automotive,+broadway,+nj&ll=40.733275,-75.049614&spn=0.002773,0.006034&t=h&hl=en Tele: 908.689.2226 I talked to a nice lady there for a few minutes; the two mechanics are ex- flemington subaru guys who opened up their own shop. They were busy, so I didn't get a chance to speak with them. I think they only they can't do are alignments. If anyone ends up going there for some work i'd be interested in their experience.
That noise ...
nickb21 replied to hawksoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike Setright mentioned; does it do it when you turn the key just to ON, or when you go to START? One time my t-belt tensioner failed to pump-up properly and it made quite a racket, only lasted a second or two. I don't think that's a common problem though..
a pillar pod
nickb21 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny luck yet? I found this: http://www.coximports.com/store/product/itemdesc.asp?ic=AUT-23910 it's a double, but not sure if it's a full a pillar pod, or just goes onto the pillar. This one says RHD, but the pic is left, maybe you can just have your navigator keep an eye on them? http://www.egauges.com/vdo_acce.asp?Subgroup=Subaru_Legacy_Right_Hand_Drive&Cart=1 No luck yet finding one for my '02 either...
1999 legacy estate handbrake details.
nickb21 replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is also an adjustment on the back of the backing plate. Just pop out the rubber piece and use a flat bladed screwdriver and LOTS of light. I believe UP makes things tighter. Here's a thread describing both procedures: http://www.scoobymods.com/forums/showthread.php?t=2779 I also found a blow-up of the rear brakes: http://www.mytempdir.com/313874 Good luck.
new oil filters AA09A
Hi All, I did a quick search but didn't notice this information posted here, so I thought I'd share. I picked up some oil filters the other day and was confused when I was handed a smaller/different filter. From what I understand all non-H6's will now use the same filter (AA09A). http://tinypic.com/ieh6ja.jpg AA060 in left, AA09A on right (serial #F10R28E1) In my googling I found an interesting NASIOC thread, it's definitely worth a quick read. (In short; some of the newer AA09A's were defective, but the new ones that you get now should be fine.) http://forums.nasioc.com/forums/showthread.php?t=864075&page=1 I'm hoping I wasn't the only person to wonder what was going on.
Seat belt knob thingy
nickb21 replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI ended up getting this part from the dealer (probably because napa/advanced had no idea what i was talking about). I think it was only a buck or two, and the package label says it's a "tang stopper". I can get you a part number when i get home if you want. The subaru one you push through the belt webbing and then I used a heated flat bladed screw driver (not too hot) to squish the pin flat.
argg.. brake caliper
nickb21 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFinally got things back together when I got home from work. Apparently having some patience is important From what I can tell the rubber was swollen, that's why it kept riding up. I trimmed a sliver of rubber off the end so it fit better in the groove. Then I unbolted the pins from the piston assembly, so they'd be easier to work with, this turned out to be key. Greased everything up, and with moderate forced "tapped" the pin into the bracket with my hand. I'm guessing that because of the swollen rubber too much air was getting trapped in there forcing the boot out. Anyway, thanks for the help, maybe this will help someone in the future. On a side note, what do those boots do?
nickb21 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAttached is a pic of the rubber thingy. I already put the caliper back on.. was planning to go get another rubber sleeve. The rubber piece sits in a cut out area on one of the pins. What was happening was when i putting the bracket back onto the pins, the rubber piece wasn't tight enough and would ride up out of the groove.
So I decided to replace my front and rear pads, and front rotors tonight. Figured it shouldn't take me more than an hour or two... little did i know. The backs came off and went back together perfectly. The fronts came apart just fine, but I am having some trouble with reassembly. The rubber "sleeves" that sit on one of the guide pins, will not stay in place no matter how i try to put things back together. They always ride up too far so i can't compress the caliper. What do these rubber sleeves do? I'm guessing they are just worn out/too loose. Can I get these parts seperate or do i need to get a whole rebuild kit? Lastly, how do you get them on without going crazy?? Thanks for the help... Almost forgot.. '02 OBW (Legacy)
dissapointed with the obw mud performance
nickb21 replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked through the owners book and all it mentions about manually selecting 2nd is that it'll skip first gear for better traction in slippery conditions. I called SOA, but apparently you need to be a dealer in order to talk to their tech guys... Sooo I tried calling a dealership and the service guy asked their mechanics who "have no idea" (i'm not surprised). I searched google groups, but just found conflicting info... http://groups.google.com/group/alt.autos.subaru/browse_thread/thread/19bc1688b22b3383/30baa873d3afa705?lnk=st&q=50%2F50+split+subaru+what+gears&rnum=3&hl=en#30baa873d3afa705 http://groups.google.com/group/alt.autos.subaru/browse_thread/thread/cc4cc9203bf215a/33bf11a1b2f36371?lnk=st&q=50%2F50+split+subaru+what+gears&rnum=1&hl=en#33bf11a1b2f36371 I'm inclined to believe the folks who've posted the 1st and R only.
nickb21 replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom what I have read, it will be a 50/50 split when you manually select "1", "2", and Reverse.
'99 Outback Limited Brake Pads
nickb21 replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found this website the other day when trying to lookup a part number (why doesn't 1stsubaruparts list part numbers when you search by model?). http://www.subarupartsforyou.com/cp_partlistbymod.php Anyway, it lists: Part No. Fits Model Category Item Description MSRP Our Price 26296AC041 Outback 1997-1999 Brakes, Front Pads OEM FRONT BRAKE PAD SET with shims & clips FOR 97-99 LEGACY OUTBACK (NOT 6 CYL OR Limited $80 $59 26296AE220 Outback 1998-1999 Brakes, Front Pads OEM FRONT BRAKE PAD SET with shims & clips, For Legacy Outback Limited & 6 cylinders $88 $64 To verify, I would call a dealership, give them you're VIN.
first subaru + snow= changed man
nickb21 replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgreed. I wouldn't make having LSD the main selling point. If you're putting winter tires on they will help you more than the LSD. I have a LSD on my Outback, it's nice to have for the power slides, but i'm not sure how much it really helps other than getting going off the line. Figure out if you'd rather have a new car, or if you need the extra room the Forester provides. Happy shopping!
AT filter on 2003 FOrrester
nickb21 replied to lytnin88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the Forrester/Impreza ATF filters different from the Legacy's? When I changed it on my Legacy L it was a piece of cake. I put in synthetic ATF and gear oil (both Mobil1) since the car was going to be up in cold VT. Definitely noticed some smoother shifting w/ the Mobil1.
NJ/PA salvage yards
nickb21 replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre your summer tires near replacement time? I'd say get some WRX 16's for the summer (pretty cheap on ebay or nasioc). And use the old rims for the winter tires. There is a place over in Easton, first exit off of 22 once you cross the bridge (it's on the right side of the highway). I think it's called the Hubcap and Wheel Store. It's a pretty shady looking warehouse, i've "wheeled and dealed" there before... just be careful that you make sure the rims are straight!
nickb21 replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have the stock RE92 all seasons still on? I've made it through ~13" of snow out my driveway with them, but I would never have guessed they'd grip enough to tow. Nice!
Wagons only - post your pictures here!
nickb21 replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice. Is it tinted? I can't tell from the pic. Want to get mine tinted, but I wasn't sure how it would look.
nickb21 replied to ron917's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure why I didn't think of this before... but there is a Subi place up in Broadway off of rt 57 (just west of washington). They always have a bunch 2nd gen legacies around. I don't have any personal experience with them, but it would be worth a call. I don't know the name/address off hand, lemme see if I can find it..
tool for rear differential
nickb21 replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can put it on ramps to drain it, just make sure it's level when you fill it.. I drained mine on the flat and got probably 90% of the oil out. I believe there is a breather tube at the top of the diff, maybe there is a small leak there.
NJ/PA salvage yards
nickb21 replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey, I live just down the road in Union. What kinda parts are you looking for? There are a few local places I've been to, but I'd say the amount of Subaru stuff is fairly minimal, but I doubt there are many people looking either. Cozze Bros. is closest, it's up past the walmart make a right on race st. Brass Castle imports is up in Oxford. Last time i was there they had a lot of VW stuff, worth a call. Columbia Too is pretty big, and well sorted, it's off 57 just northeast of Washington. I've heard Harry's U Pull It just opened up a place in Allentown, probably some good stuff there. Do a search through the meet-greet forum too, every so often some folks in the NE run out to a couple yards in eastern PA.
Need part # 2002 Outback
nickb21 replied to Chris Kueny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFound this place when I was looking for a real skid plate to replace the plastic one... Pretty good price, i would assume it's used. http://www.writerguy.com/primitive/catalog8.htm item #8032 --Nick
Engage FWD Required with Chains?
nickb21 replied to Quest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHaving understeer from too much power to the rear wheels makes sense, hopefully slowing down would help get the fronts more grip though. If the snow is pretty deep, i would think it would be best to manually select 1st or 2nd since it locks the power split at 50/50. At least that's what I've read, not sure if it applies to that year 4eat.
Which tires will you pick for your Legacy 2.5GT?
nickb21 replied to njchen24's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm in NW NJ, looking to replace my RE92's soon (OBW has 60k on them and i don't think they'll do well in the snow this winter). What kinda price range are you looking for? Two of the guys I work with have A4's one with Pirelli PZero Nero and the other with Continenal ContiExtremeContac, they're very happy with them in the snow and they perform well in the other conditions. Those are a bit high in my price range so I've been looking at the Potenza g009's ($98), Traction T/A's ($100), and Yokohama Avid V4's ($107). Non-chain local tire shop price includes mounting/balancing/disposal. As others have mentioned the Traction T/A's are a solid tire, great dry/wet performance and good snow grip (have them on my sisters legacy). I'm going to try something new though, I've read lots of good things about the Yoko's but my wallet might make the decision with the ~40$ difference with the g009's. I'll stop blabbing now
Super-Fast IACV Cleaning!!!
nickb21 replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome timing, I was hoping to remove and clean my IAC this weekend. I'll definitely try this first!
