Everything posted by baccaruda
Head Gasket screwed, Carb sucks, god hates skeet
baccaruda replied to skeet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oh crap! I'm going to see if I can get some money back on the engine in light of this news.. also, you might consider doing both head gaskets at once instead of one at a time.. cause sometimes it turns out that way. which side has the bad gasket? passenger's side? how sure is he that it's a head gasket leak? could you SEE the oil coming out of the HG or something? give me a call.. -
it's nice, isn't it? I have front and rear XT6 bars and I'm thinking about putting a stock front bar back in to see how it feels..
This Saturday, I'm driving up and buying Tyrel's rebuilt engine from his wrecked XT. I'll be putting it in my wagon in a few weeks. any problems getting my stock wiring harness to fit with the spider intake? which distributor should I plan to use? 1987 XT or my stock dist? The XT engine does not have A/C and my car does. Will the A/C and alternator brackets from my engine fit on the XT engine or do I need to go bracket hunting at pull n save? Thanks...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33617&item=2433065135 Has anyone ever seen these before? It seems worth a mention.
gonna put 180 back in!
baccaruda replied to tompalushock's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this way -
Changing Ride Height on Brat
baccaruda replied to DPDISXR4Ti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sometimes forcing that extra inch out of the torsion bars or front struts can whack the camber out so it's all positive (the tops of the tires lean out when looking at them from the front or back) . handling can be weird and it's bad for tire wear so keep that in mind... -
First Axle change completed
baccaruda replied to Hogsubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cool! they only get faster, the more of them you do when I put the pin back in, I tap it in directly with my hammer until the hammer won't clear the axle or trans, then I turn the punch around and tap on the narrow end, holding the fat end against the pin. "works every time".. -
copper head gasket info from old USMB
baccaruda posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was cleaning out my favorites and found this info in a thread I bookmarked from the old sleazyboard USMB. ---------------------------- Thanks to Skip, we now have the AutoCad files needed to make the gaskets without paying a setup cost. Skip created two styles. If you look at a turbo head gasket, there is one hole that has an o-ring as part of the gasket. Skip made one file with the hole the same as the inside diameter of the o-ring, and the other with what would be the hole diameter without the o-ring, so that you can get an o-ring to install there. So, if you want one, you just have to call Gasket Works USA, (mention Corky) 626.358.1616 voice/page, or 626.358.7971 fax, tell him which one of the sizes you want, and thickness (I think .043 is the correct thickness), he takes either Visa or MC. I'm going for the one with the larger whole, and finding an o-ring to fit. ----Corky---- hmmm, I was quoted about $70 per set (2 gaskets) from him, Gasket Works (a year ago) plus a $60 template fee, so it was $130 to me. I thought then follow on sets would be at $70. He is located in Irvine, CA, about one hour from me. He is strictly mail order, and does not have a store front, so one cannot visit. Prices may be up over the year, but I think $100 is high. There is no right or left, so one gasket fits all, and 0.043 is what I used too. Shipping should be near $10 CONUS. I made a set for $20 parts and many hours labor, using a drill press, cutters, and files. Not cost effective for me to do, but a CNC would be easy. Check him on price as these are small (under 7" x 11" sheets) and if can get them for $20 for two, then he should get or have big supplies of copper sheet for less. The cost is mostly labor (and having the RIGHT tools, i.e. CNC, etc). Just my ramblings. R/ Patrick. ---PK Davis--- -
I think using automatic transmissions would be much easier; another reason to use a newer engine series as the transmissions are better too. 2 EJ20Ts with 2WD autos beat 1 EJ20T with a manual!
Back-up-light switch...
baccaruda replied to DerFahrer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think the switch is in the tranny. are all of your related wiring connections clean? -
thanks guys.. I'll talk to these people and keep this thread bookmarked.
oh yes. I would love to throw another EA82T in the back of an 86+ wagon. As long as I'm pretending I'm rich, I'd rather put two EJ20Ts in an EA81 wagon and trick it out.
HELP PLZ Skeet's stuck in Missoula, MT...
baccaruda replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
darn, he made it back.. I mean, Glad to hear from you! how was the rest of the drive? you should have a nice pork chop sandwich before you go to bed. PORK CHOP SANDWICHES!!! -
if you take out the battery (and maybe the alternator, been a while) you can get it. I think I used an elbow and probably an extension right above the spark plug socket on some plugs too. don't forget some anti seize on the new plugs! I use the gray stuff in the little tube and love it.
EA82T crossmember available, SpoVegas
I'm getting rid of this thing by the end of the weekend if nobody wants it. EA82T crossmember from the RX i scrapped. I left it under the engine but I'm going to separate them and put the engine on a HTKYSA wooden stand with castors in the bottom. If anyone wants it, post here. I'll be tossing it in the dumpster at work monday morning. -
drilling rotors for venting?
baccaruda replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
uhh, don't, actually.. I have a guy in Spokane that I need to get some subaru info to.. and he takes lots of meaurements and plots the drilling pattern on autoCAD to avoid the vanes in the middle and such. It could affect the balance and cause heating or warping, I'd think. Good idea though.. -
Hi everyone.. I have two friends with subarus and both have nearly dead engines. One car is an 85 with carburetor (has a bad knock), and one is an 88 with SPFI (drove it without enough coolant too much and now it overheats baaaaad). Do any of you nearby have an extra EA82 available, the cheaper the better? Please and thank youuuuuuuuuuuuuuuuuuuuuuuuu
220k EA82T engine rebuild?
coolness, that's what i was looking for. I think the budget will be the ultimate deciding factor as I'd rather do the SPFI-T thing but i needed to know if it was worth the time to deal with the RX engine. thanks! -
Hi Jon. That's a bad question to ask me mwahahaha I don't want to go too expensive, really, as I'd rather sink serious bucks - assuming I had them - into a WRX engine swap. But I think for peace of mind I'll need to replace the engine sooner than the actual upgrade will be possible. Although I could probably sell a hotted-up EA82T to someone here for a reasonable price.. so as far as cost is concerned, the engine I already have is cheaper since I already have it. -
87 turbo mods, update (w/pict)
baccaruda replied to Skip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Skip. How fast exactly is your car? Maybe larger injectors would work? Maybe it's time for some dyno work. You might also try trolling the ausubaru.com board.. the aussies seem to hot rod their EA82Ts harder than we do over here... -
my girlfriends idea of a test
respectify, suckas! -
Hi Blue Train.. thanks for the endorsement! I told Skeet and he was glad to hear it.. He'll be rolling out in a few hours. Hopefully this will be the only HELP ME thread for this trip thanks for the input guys.
